piggybacking driver to p60 module
4 posts / 0 new
mnursy8353
mnursy8353's picture
Last seen: 1 year 8 months ago
does anybody know if i can piggyback a driver to a p60 module and if so what driver do you recommend
Steven W Rhea
FPV
FPV's picture
Last seen: 3 months 4 days ago
When you say “piggyback”, do you mean “integrate”? As in, build it into a P60 pill? yes, you can.
https://www.fasttech.com/product/1208509
This simple pill takes 17mm drivers with low depth, as an example.
I would recommend a linear driver that draws up to 3A. You could try more, but the traditional P60 pills might not be able to cope with the heat.
kramer5150
kramer5150's picture
Last seen: 8 months 1 week ago
You could do that, but P60 pills are so cheap it would be better to just build a new module with the driver.
What exactly do you mean by piggyback anyways?
ggf31416
Last seen: 7 hours 38 min ago
I guess you want to change the UI without too much effort by somehow appending a new driver. I don’t think you can add a new driver easily without removing the original, at least in a way that the module will still fit. Also this should be either in the 18650 or in the Modding section.
