Flashlight Torch, 600 LM Torch Light, Handheld Flashlight LED Flashlight Tactical Torch IP67 Waterproof, 3 Light Modes Flashlight for Camping, Fishing, Hiking
- Superior Performance - IP67 Waterproof, Dust-proof, Skid-proof, Anti-pressure & Shock Resistant. Hard and durable aluminum alloy material to ensure that the service life of the flashlight is longer.
- The Cooling Groove - Heat dissipation is faster and more resistant to heat. Improves the working efficiency and service life of the flashlight. -Non-Slip Handheld Flashlight - Non-slip handle design. It's more stable and convenient for use on rainy day and snowy day, and for wearing gloves to use.
- Tail Tactical Switch & Copper Plated Spring Contact - Beautiful design. Better tactility. More sensitive. It avoids the short circuit caused by loose battery and bad contact.
- Irregular Shaped Tactical Lamp Head - The Hexagonal diamond-shaped aluminum alloy attack lamp head can be used to break out objects and for self-defense in an emergency.
- Packing List - LED flashlight * 1, opp bag * 1, packing box * 1(18650 battery is not included)
The flashlight's packaging contains no batteries.But if you are a member of the BLF, you can contact me after purchasing the flashlight.We can send you 2 rechargeable 18650 batteries for free.
IPX6 Waterproof Headlights Led, Rechargeable Headlamp with Red Light, Kids Headlamp for Reading, Running, cycling - Three colors are optional
- MULTIPLE MODES & MEMORY FUNCTION - Five working modes with memory function, when used again, it will start with the previous brightness mode you used. No need to cycle through all the modes to turn off the lights. It’s very suitable for kids and teenagers for reading, dog walking, camping, barbecuing, fishing and so on.
- PORTABLE & ULTRA-LIGHTWEIGHT - Weighs only 1.4 oz. It's so light you won't even notice wearing it!
- WATERPROOF & DURABLE - IPX6 waterproof, will continue to work non-stop in rainy day or any condition that’s in moisture or humidity. But it is not recommended to use as a diving prop.
- SUPERIOR QUALITY - Made of skin-friendly and high quality materials, 100% child friendly. XPG2 LED bulbs, soft lighting, eye-protection. Comfort stretch headband with high flexibility, ensures perfect fit with your head.
- USB CHARGING - Rechargeable headlight, no need to spend more money to buy replacement batteries. Please do not let the water flow directly into the USB interface to protect the head lamp to be properly recharged.
Ultra Bright Adjustable Flashlight, Rechargeable Zoomable Handheld Flashlight, IP67 Waterproof Flashlight, 5 Working Modes Flashlight for Hunting, Camping, Hiking
- Zoomable & Rechargeable - The telescopic lamp head can be stretched up and down to transform the focal length. Powered by 2*18650 rechargeable batteries (not included in the package).
- Superior Performance - Ultra Bright 1000 Lumens Tactical Flashlight; Five working modes: High/Medium/Low/Flash/SOS; CREE T6 LED Light Beads; Ultra long irradiation distance.
- Durable & Reliable - IP67 Waterproof, Dust-proof, Skid-proof, Anti-pressure & Shock Resistant. Hard and durable aluminum alloy material to ensure that the service life of the flashlight is longer.
- The Cooling Groove & Non-Slip Handle Design - Heat dissipation is faster and more resistant to heat. More convenient for use on rainy day and snowy day, and for wearing gloves to use.
Intelligent Light Sense Headlamp, Zoomable Rechargeable Head Flashlight Adjustable Head Light LED Waterproof (18650 Batteries/USB Charge)
- Intelligent LIGHT SENSE - When switching to light sense mode, the main lamp will automatically change the brightness depending on the surroundings: dim down when surrounding is bright; light up when surrounding turns dim.
- Zoomable & Rechargeable- Just need to pull out the front part of the middle main lamp, then you can rotate to adjust the focal length. Powered by 2*18650 rechargeable batteries.
- High Brightness & Wide-Spread Illumination - T6 LED bulbs deliver sufficient brightness. The beam distance is up to 656 feet, it brights up to bring you the farther vision.
- Multi-Mode & Multi-Purpose - Five lighting modes: Main light/Side lights/Main light+Side lights/SOS/Light sense mode; Suitable for hunting, hiking, camping, climbing, caving, fishing and daily emergency.
- Good Performance - IPX4 Waterproof, Anti-pressure & Shock Resistant. Hard and durable material to ensure that the service life of the flashlight is longer.
STCT Street Cat company is committed to selling high-quality, high-performance and popular outdoor products. In order to meet the needs of the majority of outdoor sports enthusiasts, STCT Street Cat constantly introducing new products with new ideas, providing better and better service. Put customer's needs and customer experience in the first place,serve customers with heart and soul.
