Nitecore MH20 vs Klarus XT2CR
12 posts / 0 new
Valharth1031
Valharth1031's picture
Last seen: 8 months 3 weeks ago
Hi. I’m looking to buy my second light and I’m kinda down to these two. I’m looking for a good balance between throw and spill probably leaning towards throw. I’m going to use the light mostly while camping and hiking. If anyone can share their experience with actual usage on these it would be great (I’ve yet to find direct comparisons online). Also, I’m concerned about how long you can use either turbo modes before it dims down. If anyone can also explain the difference in characteristics between their LEDs, it would also be greatly appreciated since I’m still new to the jargons used. Thanks Smile
Edited by: Valharth1031 on 04/06/2018 - 20:51
Itsme
Last seen: 3 hours 33 min ago
I have an MH20GT and an XT2CR. My preference is for the MH20GT. I like the UI better even if it is less tactical because of the button layout. The MH20GT has a tighter hotspot and a bit bigger spill. With my two lights, I find that the MH20GT will run on high for longer than the XT2CR. My XT2CR steps down a bit after about 30 seconds. If you try and go to the highest level it will step down again after a second or two. It is still a bright light even with the slight step down. If you are looking for a “budget” version of the MH20 or MH20GT, take a look at the Nitenumen NE01
Valharth1031
Between the MH20 and MH20GT, which would you pick as a good balance between throw and spill?
Itsme
I only have the MH20GT, not the MH20, sorry.
Valharth1031
How about the difference in LED characteristics (ie XM-L2 U2 vs XP-L HI V3)? Might you, by any chance, be able to enlighten me?
Itsme
I am not good with any of the technical stuff. I just like flashlights, sorry
stephenk
stephenk's picture
Last seen: 6 days 12 hours ago
The Klarus XT2CR steps down gradually after 30-75secs depending on heat. My review of this light is in my signature. The Nitecore P10GT is worth a look as well.
Valharth1031
No worries. Thanks for answering Smile
Valharth1031
I forgot to mention that rechargeability is a must for me especially in the recent weeks where I find myself not having access to an outlet. It’s also a bit of a hassle to carry a dedicated charger so I mostly carry a powerbank when charging stuff. The P10GT looks good but is a no-go for me because of this. As for the XT2CR, turbo usage seems too short for me especially when route finding while hiking. I appreciate your review. Thanks for answering Smile
asaf000
Last seen: 7 months 1 week ago
Hey,
I’m also having the same debate although I have also put the KLARUS g20 on the list,
it’s a bit heavier and more expensive tough
here’s the full review: http://budgetlightforum.com/node/53441
Thanks.
sesgum
sesgum's picture
Last seen: 5 hours 36 min ago
I have both mh20 and mh20gt. I got mh20 first and was so happy with it that I got a mh20gt. But the gt version is a little more different than just a HI emitter. It is slightly longer, with a deeper reflector. This improves throw a little, but also made the spill narrower. Also there is a ring in the beam. So I am more fond of mh20, which is about perfect. Good spill and throw. Clean beam. Good modes. USB charging. Battery check.
I also have a zebralight sc600 iii hi. That is one of my all time favorite. Worth looking at if price is not too much a problem. I believe it has been on sale on zebralight website since there is version 4 now
gottobegeek
gottobegeek's picture
Last seen: 3 hours 56 min ago
I have the mh20 and its pretty awesome.
The GT model is just a bit more throwy, meaning the main hot spot will go farther down range with the XP-L HI so the peak intensity is higher than the mh 20 but with the same output. Otherwise they are exactly the same.
I also have the lumintop sd mini which is very similar to the GT to add another option for you, and maybe cheaper if that matters, but its really sold and I like it too,
g
