Review: Thorfire VG-10s
7 posts / 0 new
aginthelaw
aginthelaw's picture
Last seen: 37 min 51 sec ago
This is what happens when you give free lights to flashaholics. I’ve noticed there’s already a few reviews up on the new version of this light, so here’s another:
I’m not even going to attempt to compete with the quality of other reviewers out there. Even the worst of them out do my studio’s capabilities since it does double doody as my bed. The light is well built, with thick walled battery tube, thick bezel, and tail switch with solid click. I don’t do mods, so breaking it down completely will end with me curled up in the corner sucking my thumb trying to figure out how to put it back together. There are indentations for using split ring pliers to unscrew the pill and tail switch.
It has springs at both ends so throwing a flat top in got me up and running immediately. I don’t have reason to doubt the 1100 Lumen claim coming from the xp-l led while using on a vtc5a. You can not however use 2 x cr123a’s in it because of voltage limitations.
Not the latest, greatest, or best of the bunch, but I purchased the original vg10 for $12 each. For Somewhere between $12-24, It would make a great disposable tactical light that you could throw anywhere (bag, car, closet) while unscrewing the tail will prevent battery drain assuring it won’t turn on wherever you store it.
Thank you Thorfire for the substantial discount. Sorry Thorfire for my lousy review skills. Something gets lost between my what I’m thinking and what I’m writing.
never fear shadows…it means a light shines nearby
Edited by: aginthelaw on 04/15/2018 - 20:16
everydaysurvivalgear
everydaysurvivalgear's picture
Last seen: 1 hour 53 min ago
Great review mate!
I have a new edition also its a great light super bright. I have not been able to get the retaining ring undone it probably needs some heat to open.
Scallywag
Scallywag's picture
Last seen: 54 min 15 sec ago
everydaysurvivalgear wrote:
Great review mate! I have a new edition also its a great light super bright. I have not been able to get the retaining ring undone it probably needs some heat to open.
Both of the retaining rings on my VG10S came off quite easily. The driver retaining ring is reverse-threaded, so turn clockwise to loosen. I haven't been able to get my bezel off to check the MCPCB, though...
EDC Rotation: ZL SC62 | Jaxman E2L XP-G2 5A | Purple S2+ XPL-HI U6-3A | D4 w/ Luxeon V | RRT-01
EagTac D25C Ti | DQG Slim AA Ti | UF-T1 by CRX | Olight S1 | Klarus Mini One Ti
L6 XHP70.2 P2 4000K FET+7135 | Jaxman M8 | MF02 | Jaxman Z1 CULNM1.TG | Blue S2+ w/ ML Special
In-progress: Supfire M6 3xXHP50.2
Others: Nitecore EC23 | Nebo Twyst | Streamlight ProTac 1AA | TerraLux LightStar 100
My retaining ring is glued in. I can see the glue it’s like loctite stuff. My bezel came of easy lol.
aginthelaw
Forgot to add, the light has mode memory. I turned it off on low and it comes on in low.
aginthelaw
I have one use only coupons for the vg-10s if anyone wants one. Make sure you want it because once used it’s no longer valid.
chadvone
chadvone's picture
Last seen: 1 hour 23 min ago
Thanks for the review. Is it really that skinny compared to the Doberman ??
