26650 battery recovery
3 posts / 0 new
Zulumoose
Zulumoose's picture
Last seen: 12 hours 16 min ago
So I ordered a pair of these Sunway 26650 5000mAh from the Sunway store on Ali.
They arrived at almost exactly 4V, which is higher than any batteries I have received before.
I immediately tried them in my L2, and they just fit width-wise, seem perfect length-wise with the included magnets between them.
Light worked well so I put them in my Lii500 for a normal discharge cycle test.
End result 4506@4.2v and 4499@4.19V. Took about 15 hours to charge/discharge/charge since the discharge is limited to 500mA.
I thought at first these are 4500 models being sold as 5000, then I thought, maybe they are old, or were stored at too high a voltage, let me try again and see if they improve with another cycle.
End result about 4570 and 4607 (from memory – I forgot to record). I haven’t tried again yet.
Thoughts?
Old? badly stored? overrated?
Should I just continue to cycle and see what happens?
I’m not disappointed, just curious about the discrepancy and the reason for it. Other batteries I have received have always been within 5% of rated capacity, and never over 3.8V on arrival. Maybe I’ve just been lucky? What is a reasonable expectation?
Beam me up!
Speed4goal
Last seen: 7 months 1 week ago
If they were charged and stored at FL voltage for several months it would lose several hundred mah. I’ve seen it happen in my own cells.
Or the cells could be 4500s rewrapped as 5000
And sometimes cells will increase mah after a few charge discharge cycles. Do the the discharge rest 2 or 3 more times and see if it gets any higher
2/9 Fox Co (2009-2015) Semper Fi 0311/0331 Rifleman/Machine Gunner
Blf has changed a lot since I've been here. Lots of snow flakes and easily offended over nothing. When the forum use to be great and people joked around and could take a joke. It's a forum it's not that serious. Let's make BLF great again!
snakebite
snakebite's picture
Last seen: 1 week 1 day ago
run a few cycles to “break them in”
those cells are among the best if not counterfeit.
they usually exceed their ratings sometimes by a large margin.
