If anyone has an Olight S10R Baton II Charging Base could you see if there’s a part number on it you could post?
It seems like there is a difference between this one and all of the others.
Contacted Olight and got no response, figure it would be easier going to the users.
With a part number I stand a chance of finding one.
Thanks for any info,
Robert
Thanks saypat, there’s more than one model Olight charger and some of the other ones I looked at said
“ATTENTION: This Charging Dock can be only charging S1R/S10R III/S30R III/S2R/H1R/H2R/M2R, It can’t charge S10RII,S30R II 3200mAh,S30R II 3600mAh,S15R,S20R,S30R.”
Those have a blue ring around the top of the charger, your link doesn’t and doesn’t have wording to the effect that it can’t charge the S10RII.
Thanks again!
Hope it helps. GoingGear always has coupons to save a bit more
Process of moving has eaten the one that goes with the light I sent you. Could suggest you wait, but I feel its gone.
Sorry.
Chadvone, no complaints here!
Awesome package and I’m having a blast working on them.
Tail cap is the point of failure on this one, required tweaking and cleaning.
You rock!!!
To my knowledge, there have only been three versions of the Micro-dok.
The original had 750mA output, and I believe a fixed center contact, to work with the first generation of those tailcaps had the problematic sprung center contact.
The Micro-dok2 has a sprung center contact pin, after Olight changed the tailcap design to a fixed center contact. Output was raised to 1000mA.
The current Mirco-dok3 has suction cups, but is otherwise the same as the 2. Both v2 and v3 have the ring around the pad.
There was a rare white version that shipped with one of the special edition lights, which I think was a series 2 only in a different color.
My S30RII came with v2.
