On its back are 4 usb-out charging port, and a type-C female port.
I know the 4 usb ports are ‘voltage out’ ports to charge a 5v device.
However, the I cannot understand what is the purpose of the type-C female INPUT port?
I know one of my phones now has a type-C INPUT connector (currently used in more smartphones, moving away from the usual micro-usb) when I want to charge it from a USB connector charger.
I am aware of the type-C are for higher currents, but as an input port? …. while the rest are 4 usb out ports. including the QC 3.0 out.
My OnePlus 5T has Dash Charging (high current) type-C INPUT port at the bottom. The OEM cable used of course has the type-C input (connected to the phone) and on the other end of that cable is a USB connector, connected to its special high-current adaptor/charger.
but the subject of this thread is: The type-C connector—- what is it used for?..
In other words, if my OEM cable eventually fails, this Anker type-C to type-C unit used with my Tutuo charger can do the job, though I am very surprised to see that now they making same end charging cables.
