Is there a good resource that shows which LED’s are the most efficient at various levels?
For example, for travel, which would be the most efficient for running mostly in a low-medium mode at around 1-30 lumens? (probably 0.1-0.3 amps I’d guess?)
Yes, it is between the XML2 and the XPG2, seeing as the XPL HI has the same die as a dome XM L2 inside of a smaller package and domeless from the factory, and the XPL HI has a bigger die than the XP G2.
Yeah, but the die size is a ‘bigger’ difference, meaning that you’d still be losing intensity with the XP-L versus the XP-G2. Lost intensity means less throw. So, you have to decide if you need the throw of the XP-G2 or the lumens output of the XP-L HI. Have you done your comparison with the XP-G2 vs. XM-L2 lights to decide which beam profile you like better?
Planning on doing that tonight when it gets dark.
I have 5 lights that I really like. 2 have XPG2 2 have XML2 all stock. 1 is XML2 neutral swap with DC-Fix and I love it.
So, I was thinking of maybe swaying a XPL Hi into one of the XPG2 versions to be like the one with DC-fix with possible more throw. Do I need it? Not not really , I have other light that throw better then both.
