BLF Q8 Driver
24 posts / 0 new
khas
Last seen: 4 days 18 hours ago
BLF Q8 Driver
BlueSwordM
BlueSwordM's picture
Last seen: 1 hour 53 min ago
Yeah, if I want to buy a replacement Q8 driver, I would just buy Lexel’s FET+7135+15×7135 driver.
It has NarsilM 1.2, along with constant current operation up to 6A. And you get to support them.
Win-Win.
djozz
djozz's picture
Last seen: 9 hours 47 sec ago
A good driver to blow up your cheap SRK clones Party
But it is nice to see this driver as a separate part although I can not think of a use for it yet.
BlueSwordM
Yeah, I don’t really know.
If there was a BLF Q8 host however, that would be just amazing.
thijsco19
Last seen: 15 hours 8 min ago
How did it end up at sofirn???
BlueSwordM
Sofirn and Thorfire share parts suppliers. They must have gotten the drivers from the same place as Tgorfire.
Bob_McBob
Last seen: 8 min 56 sec ago
Is there anywhere you can buy the stock MCPCB?
BlueSwordM
Not really.
However, there is the new Q8 MCPCB which support XM L2 sized LEDs, meaning you can easily make your own LED array, although you need to cut ye reflector to size, and get some washers.
ryukin2000
ryukin2000's picture
Last seen: 1 hour 25 min ago
My Q8 replacement driver came in and it has one thing different than the stock one. What is the purpose of this? It sits on top of one of the caps.
BlueSwordM
Oooh another cap.
It’s probably there for additional bump protection.
ryukin2000
BlueSwordM wrote:
Oooh another cap.
Ah ok. Wonder if new production Q8’s come with it now too.
RoboEgg
Last seen: 1 day 21 hours ago
I was hoping to put this driver in my SRK 10T6 clone but after reading your post I’m having second thoughts? Is this driver safe to use in a clone?
Tom E
Tom E's picture
Last seen: 17 hours 46 min ago
Why wouldn't it be safe? Who's post? It's a good deal on a good driver, wayyyy better than stock SRK clone drivers - I've seen/worked on a few.
Lightbringer
Lightbringer's picture
Last seen: 3 hours 3 min ago
Hmmm, with a Q8 reflector, mcpcb, and now driver, anyone know if the combo would fit into a Mag head?
RoboEgg
There is an SRK driver plus spring PCBs and switch on AliExpress. It’s described as a K10 version.
RoboEgg
Thanks. I ordered the driver Q8 for my 10 led SRK clone. The Q8 driver arrived today, excellent quality – impressed with the battery ring. I checked it for size and it does fit. I think the leds are LatticeBright XK 7 Watt. I think they would probably take the drive current. Just
need to work out how to get the driver out.
Tom E
Tom E's picture
Latticebrights on a cheap alum MCPCB with a Q8 driver? Hhmmm, you might get a few hot secs out of it - careful with the LED's desoldering themselves - if not a good heat path, all the heat stays at the LED's and that's not good. Of course I'd try it smilecool
DavidEF
DavidEF's picture
Last seen: 3 hours 13 min ago
If it hasn’t been tried yet, somebody should ask VOB to try it and see if it works. Wink
- The YKK Philosophy
Lightbringer
Mmmm, he might’ve already tried it by now. LOL
I have a rather pristine 2D Mag (that I can’t quite find right now Sick ) going unused for years, that I could measure the innards and see if the Q8 innards would fit, but…
Problem is, okay, so I got a nice chunk o’ reflector and the LED board… now what goes under it? I’ve got zero machining/metalworking setup here, so would have to farm out something, or else do it “manually” (ugh).
Eh, it’s a nice idea. Imagine if I wouldn’t push it too hard it could still beat the Magbulb output by at least an order of mag-nitude (haha).
HONDARIDER
HONDARIDER's picture
Last seen: 3 hours 6 min ago
Where does one go to purchase drivers from Lexel?
Lexel
Lexel's picture
Last seen: 8 min 47 sec ago
BLF Send PM button
RoboEgg
Tom E wrote:
Latticebrights on a cheap alum MCPCB with a Q8 driver? Hhmmm, you might get a few hot secs out of it – careful with the LED’s desoldering themselves – if not a good heat path, all the heat stays at the LED’s and that’s not good. Of course I’d try it smilecool
Thanks for the warning. I’m not planning to run the Q8 driver flat out. I will just put one protected 18650 to get in to programming mode (without drawing too much current). Then I can set it to low-medium-high mode with no turbo. If I do break it I’ve got an excuse to get a Q8 – so win-win. I need a powerful little torch because my wife doesn’t like me taking out my Trustfire J-20. She calls it a lethal weapon.
Tom E
Tom E's picture
Eeven using stock ramping, just use it smartly - not too long on max. I would add thermal grease where the mcpcb contacts.
Stock wires are usually thin so that helps. I would say keep them thin, maybe make longer. Lots of those cheap srk drivers route long traces just to add resistance, keeps the amps down.
HONDARIDER
Lexel wrote:
BLF Send PM button
Wasn’t sure if maybe you had your own store. Be in touch.
