Review - Imalent RT70 XHP 70.2 5,500 Lumen Monster!!!
40 posts / 0 new
Rolz
Last seen: 13 hours 5 min ago
Flashlight Review
Imalent RT70 Cree XHP70.2 Flashlight Review
In this review I look at the new Imalent RT70 flashlight powered by a CREE XHP 70.2 LED. According to the specifications this model is capable of producing 5,500 Lumens with a range of 903m. The brightness of this flashlight is well above any other one that I've ever used in the past and as such I was very keen on working through the review to see how well it performs.
The Imalent RT70 is one of the more powerful flashlights on the market today and it's design is consider a "soda can" type as it's main body accommodates 4 x 18650 Batteries in parallel. This model also comes with an inbuilt USB charger which saves needing a separate charger.
My findings suggest this is a very powerful flashlight which performs really well too. Read on for further details.
Thanks to Banggood for providing this flashlight for review. No compensation received for this review other than the item for the review.
Sellers/Manufacturers Specs and Product Description
Specification:
Product name: IMALENT RT70 XHP70.2 5500LM Multi-functional LED Flashlight
Brand: IMALENT
Model: RT70
Emitter Type: XHP70.2
Material: Aerospace grade aluminium alloy
Mode: Low,Mid Low,Mid,Mid High,High,Turbo
Lumens: 60LM,400LM,800LM,1200LM,3300LM,5500-3300LM
Runtime: 96H,18H18Min,7H18Min,3H25Min,110Min,8+96Min
Battery Configurations: 4x18650 Battery (Not Included)
Switch Type: Clicky
Switch Location: SIde of the flashlight
Peak Beam Intensity: 203800cd
Impact Resistant: 1.5m
Range: 903m
Max Output: 5500LM
Waterproof: IPX-8 Standard
Color: Black
Weight: 420g without battery
Size: 86mmx51mmx161mm(Head diameterxTail diameterxLength)
Features:
-Utilizes one American XHP70 2nd generation LED.
-Exquisite, powerful, long throw.
-Maximun output up to 5500lumens.
-Built-in intelligent temperature control module can automatically adjust the brightness output.
-Built-in magnetic charging. High grade and portable.
Built-in multi-functional charging indicators:
-Function 1:Lower power warning.
When the battery voltage is lower than 3.2V,the red indicators will turn on, and if users try to activate turbo mode, the red indicators will flash three times to remind users battery too low to activate it.
-Function 2:Charging.
The indicators will be red when it is charging and turn green when it is fully charged to 4.2V.
First Impressions and Unboxing
The first impressions were very good. The box containing the flashlight and accessories is a sturdy one and is well labeled with the key features of the flashlight along with a carry handle.
Included in the box was,
1. Imalent RT70 Flashlight
2. Magnetic USB Charging Cable
3. Holster
3. 2 x Spare O Rings
4. Instruction Manual
The sides of the box showing the attached labels.
The items were well packed in the supplied box with foam inserts to protect the contents from damage. Below are unboxed items. My immediate reaction to holding the flashlight was real excitement. The flashlight body is medium sized flashlight that sites well in a normal persons hand. The weight is reasonable too suggesting a good quantity of aluminium which I'd expect given the rated 5,500 lumen capacity. The switch did look odd/different as the button appears to be stainless steel. This is quite different to what we normally see in flashlights. The glass lens was also covered in a protective film which was pleasing to see. The overall packaging was excellent. For a premium priced product it's what should be expected.
In the image below we see the contents removed form the box. The plastic box contains the USB charger and O Rings. Holster case appears to be of reasonable quality too.
A closer look at the glass lens with the protective cover still fitted.
Below are the spare O rings and the proprietary USB charging cable.
The lanyard include is somewhat unique and is made of a thin cord. The cord thickness is approximately 2mm in diameter.
The contents included are what would be expected at a minimum for a premium priced flashlight. Although this kit is lacking the 4x18650 batteries needed an alternative version can be purchased with Imalent batteries.
The supplied manual is A4 sized sheet folded up. On one side is the English version and the other Chinese. The details are clear, easy to read and complete.
The manual states clearly that unprotected battery cells are not supported and that batteries must have a button top. It also suggests that using less than 4x18650 can result in Turbo mode malfunctioning.
Flashlight Build and Disassembly
Below is an image of the host beside a Convoy C8 and S2+ for comparison purposes. It's clearly not a small flashlight however it does fit nicely in hand. The build is really good. The finish is perfect with no damage or scratches. The body host knurling is good and not slippery. The flashlight is approximately 160 mm in length. The battery section of the host is approximately 51mm and the head section is 86mm.
A decent quantity of cooling fins in the head and upper body section.
A view of both sides of the flashlight. The flat stainless steel switch works well. It's a firm press switch with an audible "click" sound. In the image on the left next to the switch are 3 spots in a triangular formation. This is where a visual indication of battery charge via a red/green led light can be seen. The view of the other side of the flashlight shown in the right image. shows the magnetic charging port.
Again for comparison purposes are included a Convoy S2+ and a C8. Also a view of the XHP LED and smooth reflector. The glass appears to be coated although not absolutely sure from what I can see.
The Holster provides good coverage of the flashlight
The flashlight weight without batteries was measured at 425 grams.
With the head removed from the body.
Another view of the inner head section
The battery section when removed revealed some plastic protection. Not sure if needed but good to see that again Imalent have taken extra steps to protect the flashlight.
Another view of the body battery section with the protective film removed.. The threads are square and lubed. Included in an O ring for water protection. The HAIII coating is well done. The finish is a quality mat black. The design of this flashlight is such that it requires button top batteries. IN this review I used 4 x 18650 Samsung 30Q cells, which are 67mm long.
The inner working of the body section showing the 4 brass springs.
Bottom section of the flashlight body showing the mounting holes for the supplied holding cord.
Closer view of the bottom of the flashlight with printing describing the brand and model. Flashlight is very stable when tail standing.
The image below shows the flashlight with the supplied lanyard/holding cord. It seems to work and can remain fitted and allow the user to store the flashlight in the provided holster. Overall a good solution that works well.
USB Charging Feature
The Imalent RT70 has an inbuilt charger that is rated at 2A. In tests performed charging 4 x Samsung 30Q (unprotected) batteries the charge measured was around 1.5A.
The battery charging was tested and it was noticed that the charge current peaked at approximately 1.5A. The final charge voltage of the battery was measured as 4.17V on all 4 batteries which is a very good result, just short of the ideal 4.20V
The magnetic charging head was problematic initially as simply attaching the magnetic USB connector to the port on the flashlight head did not result in a working connection. A few attempts were required to enable correct charging function. Once working I was careful not to bump the flashlight as it would easily result in disconnection.
User Interface
The user interface is simple and relies on the use of a single side button.
Turn on - Press the side button once.
Turn off - Press the side button.
To cycle through the normal light modes, first press on and hold button down to cycle slowly through the modes.
Eco -> Low -> Middle Low -> Middle -> High
To enter turbo mode double press the button, then another double press to enter strobe mode.
Below the switch is a LED which indicates the battery charge level in a simple manner. When the flashlight is on, if the LED is red it indicates the battery voltages are less than 3.2V, otherwise the LED will be green.
The RT70 has last mode memory.
Another feature included is the ability to lock or unlock the switch. WIth the flashlight off press and hold the switch for 3 seconds. To unlock press and hold the switch button for 1 second.
Beam Shots
All photos taken with the following Camera settings,
F 2.8, Shutter 1/1600 ISO 100, Lumen figures stated are as per the manufacturers figures. The output produces a clear and strong hot spot, and with higher modes the spill increases. Around the hotspot is a donut which has a yellowish/greenish coloring. It's very minor and only noticeable when shining the flashlight at a nearby wall.
The tint of the output is at the cooler end of the scale, likely over 6000k.
Eco (60 Lumens)
Low (400 Lumens)
Middle Low (800 Lumens)
Middle (1,200 Lumen)
High (3,000 Lumen)
Turbo (5,500 Lumen)
Outdoor Photos
2.7, Shutter 2.5s  ISO 100
Location is at a park with the distant tree approximately 60m from the camera position. All light levels produce good to great levels of light output. High and Turbo are where the RT70 really impresses. The flashlight has a smooth reflector and a strong hotspot which assists with the throw however there it's still somewhat of a floody flashlight too. Outdoors it lights up the immediate area and with it's power extends the beam into the distance. I cannot confirm it can throw to 900+ m but it does definitely produce lots of lumens, and likely over 5,000. The lowest mode "Eco" appears brighter than the specified 60 Lumen. I would suggest it's closer to 150 Lumens. I'm unsure as to whether the unprotected high drain batteries played a part here, unfortunately I could not compare against another type and set of 4 batteries.
Eco (60 Lumens)
Low (400 Lumens)
High (3,000 Lumen)
Turbo (5,500 Lumen)
Light Output
Three test measurements were collected on the Imalent RT70,
1. Ceiling Bounce measurements
2. Run time test with 4x 18650 Samsung 30Q Unprotected batteries
2. Host Temperatures over first 25 minutes.
Firstly the Ceiling Bounce test. The purpose of this test is to assess the amount of light produced.
The score 320 is a massive result compared to any other flashlight I've tested in the past. I anticipated a figure over 300 given the spec of 5,500 lumens.
Below is the run time test on Turbo mode. The test run progressed until the flashlight output began to flicker. A freshly charged set of 4 x Samsung 30Q batteries were used. These were charged with a Xtar VC4 battery charger. The manual for the RT70 does not recommend unprotected cells.
The measurements commence with a figure just over 110000 lux at 1m (or cd) which isn't quite the 203800cd as specified. The performance of the flashlight on turbo was super impressive for me as a person who has never experienced a flashlight producing over 5000 lumen. After 8 minutes the output level dropped to 75,000-90,000 for around the next hour which is a wonderful result. The level then dropped sharply to 33,000 and slowly reduced to 28,000 at the 132 minute mark. At this time the flashlight output started to flicker briefly, so I decided to end the run. At this time the battery voltages were measured at 2.91V.
During the Turbo level run temperatures increased sharply to a peak of 62.4deg C at the 25 minute mark. This was very hot, and beyond what would be expected acceptable as it's too hot to hold. The overall peak measured was 64.5 deg C which was a real concern for me as I've not had a flashlight at the temperature which presented a risk to the batteries inserted. The flashlight specs suggest that it has thermal control module, however if it does the settings are too high. I would not consider this to be a major flaw of the flashlight although I do would expect that such a it should not exceed around 50 Deg C.
Final Summary
This is one super bright flashlight that impressed me greatly. The powerful output on turbo mode of 5,500 lumen lights up large areas easily in the near and medium distances. I was excited ahead of receiving this flashlight and was thoroughly very satisfied with its performance.
If you are looking for a powerful flashlight of this type this is a very good choice. The quality is excellent overall.
The charging via the internal feature worked ok, however I did find that the magnetic connector was too sensitive and it was easily disconnected.
Overall an excellent flashlight from Imalent.
Pros:
> Build Quality
> 5,500 Lumens on High!
> Internal USB battery charger
> Can Tail stand
> Good set of accessories included in the package.
Cons:
> The lowest brightness mode produces too much light.
> Thermal feature seems to be set too high.
> Supplied magnetic USB charging cable connectivity to flashlight port is very prone to disconnect
> Requires button top batteries. Imalent recommend Protected too.
Key sites to see more about the Imalent RT70 Flashlight
Link to the flashlight Imalent RT70
Discounted price is $98.99, via code: 19bcbc
See link below for Banggood APP
Banggood APP Download
1st June 2018 Mid Year Sale
Early bird sale up to 80% off,
Link:https://goo.gl/Gwa1xa
APP ONLY
Even cheaper than the PC version
Exclusive Benefits Are Revealed
Link: https://goo.gl/SfSfpu
Get a bonus 10% off coupon the first time you log into Banggood's online shopping site app
Link: https://goo.gl/pgzaho
dchomak
Last seen: 2 years 3 months ago
Nice review and flashlight. I want one!
Zyll
Last seen: 2 years 2 months ago
Thanks for confirming unprotected button tops will work. I was under the impression from a test on the RT35, that only protected were going to be long enough to make contact. Been waiting for actual readings on this. Hmm..5,000+ lumens is close to spec, but 900m throw isn’t. So it’s more like 660m for 110Kcd??
SKV89
Last seen: 2 hours 32 min ago
Thanks for the review. I wonder why they didn’t shave the dome like the Acebeam K65. The tint on that emitter also looks very green. I hope the bezel is not glued so at least modders can have access to replace the emitter.
AlexGT
AlexGT's picture
Last seen: 1 week 5 days ago
Thank you for the nice and detailed review, I wonder how that lanyard was tied, would love to have that for other lights. Anyone knows how to tie one of these?
Got anymore pictures? I am assuming is a slip knot on the flashlight bezel, right? Got anymore pictures?
Thanks!
AlexGT
Rolz
My measured cd was lower as stated so probbaly more around 600 or so as you say, still a very powerful flashlight, but not as stated I suggest
Rolz
Thanks for reading. I was really exciting to have the chance to review one as I’ve got so many flashlights in the 1000 or less Lumen range and only one over 2,000, so to have one over 5000 was something I was looking forward to. The amount of light produced at this level blew me away.
Rolz
Thanks!
AlexGT
Thanks. I made lots of photos, are you wanting more closeups of the lanyard? If so confirm and I’ll post some
sp5it
sp5it's picture
Last seen: 2 hours 5 min ago
Facepalm Terrible tint shift. Mike
Think of how stupid the average person is, and realize half of them are stupider than that. George Carlin
 Anyone offended by my signature please fill Complaint Form. Thank you.
Rolz
Thanks for reading. A shaved dome would have really extended the range closer tot eh 903m mentioned. Still a great flashlight in my opinion as it puts out so much light. The Acebeam K65 would be an awesome one too I suspect.
Rolz
I’m not an expert on Tints to be honest so not sure how to respond to the comment
Speed4goal
Can you check to see if the bezel is glued. Remind of a slightly larger head mto7s with charging. If the price comes down about 30 dollars eventually I’ll get one.
2/9 Fox Co (2009-2015) Semper Fi 0311/0331 Rifleman/Machine Gunner
Blf has changed a lot since I've been here. Lots of snow flakes and easily offended over nothing. When the forum use to be great and people joked around and could take a joke. It's a forum it's not that serious. Let's make BLF great again!
Rolz
Just tried and it seems not, however it requires lots of effort and decent gripping/rubber gloves to remove. I managed to turn a small amount with bare hands.
blueb8llz
Last seen: 19 hours 55 min ago
Great review. Can turbo be memorized?
AlexGT
AlexGT's picture
Thanks!
AlexGT
Yes, please! Smile
SKV89
That sounds good. Thanks for testing it.
Rolz
Just tested, seems not
Speed4goal
I wonder why they went with 4 parallel instead of 4s. With the haikelite version of this light 4s the voltage never drops enough so you get the full 5000 lumens until the batteries are depleted. Just seems odd they would choose a boost driver when they could have uses 2 or 4s
I guess with 4p there would be plenty of amps between the batteries for the boost driver for most of the discharge
Lexel
Lexel's picture
Last seen: 14 hours 17 min ago
A german friend measured his with ony 3200 Lumens
5500 manufactury spec is way too much from what it delivers
Speed4goal
Lexel wrote:
A german friend measured his with ony 3200 Lumens 5500 manufactury spec is way too much from what it delivers
If I’m not mistaken hasn’t a good bit of imalent lights been a good bit underspec? Maybe a couple other people can test them. If they all test like that then we know
Rolz
I dont have the equipment to measure lumens however with my ceiling bounce test it blew away other flashlights that I’ve tested before. The outdoor performance was amazing too, it’s significantly brighter than anything else I’ve tested. I cant be sure that it is above 5,000 but it wouldn’t surprise me if it was thereabouts. What batteries did your friend use?
Rolz
AlexGT wrote:
Thanks!
AlexGT
Yes, please! Smile
Speed4goal
I’m interested in lexels response. But just my opinion if lexel says it underperforms I believe him 100% that guy knows his stuff. And has contributed so much info to this forum. Even if yours made 4000 lumens 5500 wouldn’t seem a whole lot brighter to the naked eye. Even if he used crappy cells which I highly highly doubt. For test everyone uses high drain cells. Even with crappy cells as long as they can do 4 or 5 amps it would power it long enough for 30 seconds on Max. I doubt it’s drawing more then 20 amps. Probably not that much.
From what I’ve seen on other lights from imalent they never reach their specs. Look for yourself on the last 4 or so high powered lights. I’d still like to own this one though even if it under performs. I’m sure lexel could design me a driver for it. It’s just to expensive right now. When the mt07s can hit 5000 lumens for 46 dollars. And has 4s driver in it. Which means it gives that 5000 lumens until the light shuts off. The voltage never drops low enough to not provide full power. Like with 2s2p drivers. The one thing I like about this head is bigger and the bezel isn’t glued with a shaved dome and a lexels driver this light has major potential to be a monster. Like 7000 to 9000 lumen monster
Lightbringer
Lightbringer's picture
Last seen: 1 hour 20 min ago
You questioned whether/not it be AR-coated glass. If it’s hideously green, it likely is.
I actually don’t use some lights anymore because of that sickly green tint. It nasty.
But yeah, while I’m not so much a “tint snob” (getting there, but not quite yet), I despise green-tints. It’s even worse than Angry Blue™ or Angry Purple™.
So, yeah, green is a sore point to a lot of people, myself included. It could ruin an otherwise amazing light.
Lightbringer
Dunno about anyone else, but I get squeamish with even a 2S arrangement in an L2 using unprotected cells. 4S seems that much more to go off-balance with whatever cell might be the weak link. And protection needs to be high-amperage to not also be the limiting factor.
Speed4goal
Not as bad as you think. I’ve had a cell not make contact and it ran off 3 cells. Before I removed those spacers it just effected the run time. Unless your over heating the cells to 150c all that will happen is shortened run time. The driver won’t get enough voltage it runs what it can until it can’t. I had to remove the spacers to get proper contact sometimes only 2 would make connection when it dropped out of turbo in a couple minutes I could tell something was wrong. Cells weren’t anything past warm they just gave what they could. Lithium is safer then people give it credit for. Worst case scenario for your name brand cell is a vent, no flame or explosion. Direct short no flame or explosion. Over charged at 12v and 10 amps for hours same result. Heated to 150c for hours at 5c per minute no flame no explosion. Shaken violently and dropped on oak boards. Crushed laterally and vertically. No flame or explosion. Every spec sheet has the results of the test for the cell. Pretty much have to throw them in fire. Get them around 450 degrees Fahrenheit and you’ll get a nice bang. So I don’t worry to much. Even with my 2 series 6 amp L2 with dedomed xpl v6 1a Just stick with name brand cell that have gone through the united nations regulations for safety.
Example people freak out when a cell goes to 2.5 or lower. Most LG cells get there mah rating by being discharged to 2.0 volt. In the 25r spec sheet they pulse discharge it at 30,45,60,95 amps and do a cycle life test and they discharge it to 1.5volts each cycle. I’ve recovered hundreds of 1v cells out of tool packs as well with no problem use them a couple hundred cycles and recycle them back. The hype doesn’t live up the real life. When there is a incident they make as much hype they can about it. And it’s “usually“cheap old technology Chinese cells that cut corners andbhave no cid or ptc inside the cell. Even with the dangerous Chinese cells. To only have a handful on instances yearly to the amount of lithium batteries and devices is less then a .001 failure rate. To the billions of batteries made yearly
The only cell I’ve had a problem with was a Imedion nihm with about 30 cycles on it. Turned my nitecore ea41 on low about 2 seconds later it vented and bubbled my switch up. I’m talking the lowest mode the moon light from off button. I was pissed and never bought that brand again.
Lightbringer
Was that for me or someone else?
I’m not concerned about having a Li cell go supernova, mainly just ruining it and making me buy a new one. Sick
Figure if anything, it’d just vent and blow out the switch-button or something.
I never understood the big fuss about how far a cell gets discharged when rating its capacity. I’ve watched my almighty and not-quite-almighty chargers run down a cell for hours as it hangs in the upper-3s for so long, but from 3.2V on, it nosedives, and from 3.0V down, I can actually watch the voltage-readings decrease in realtime. So out of, say, 3000mAH cutting off at 2.8V, discharging it a whopping 2min more down to 2.5V (or 2.0V) might scare up a few dozen mAH, but that’s it. To me, it’s statistical noise.
But, after having weak-link alkaleaks take a dump in my lights after getting reverse-charged, etc., I just plain don’t want to brick a perfectly good Li cell by running it down so far. A Crapfire cell, who cares?, but a nice shiny 30Q or VTC6? Nah.
Rusty Joe
Rusty Joe's picture
Last seen: 5 hours 4 min ago
Wouldn’t have it if it were given to me. Luggy, unattractive, expensive, fugly beam pattern, step-down, and below spec performance. Blah!
Thanks for the review, though!
gaetano76
HELLO ,I WRITE FROM ITALY ,SO I BUY THIS FLASHLIGHT A FEW WEEKS AGO AND I SEE AFTER A FEW DAY , THAT WHEN I USE TURBO MODE THE FLASHLIGHT TURNS OFF!!! I WANT TO ASK YOU INSTEAD IMALENT ORIGINAL BATTERIES ,WHAT OTHER BATTERIES I CAN USE TO REPLACE THE ORIGINAL IMALENT 3000MAH 15 A =?MORE POWERFUL =?
hIKARInoob
hIKARInoob's picture
Last seen: 8 hours 7 min ago
Hi!
The Imalent batteries are really more than powerful enough for the single XHP70.2 emitter. The cells (Samsung 30Q) are 15A rated, but can handle more current for a brief moment.
I think you have a problem with the flashlight if it cannot stay in turbo mode, not with the batteries.
gaetano76
SO ,I DONT’T KNOWN IF IS PROBLEM OF FLASHLIGHT I TOUGHT THAT WAS IN REVERSE ,BUT THE FLASHLIGHT IS ABOUT 3 WEEK THAT I BUY IT!
