C8 modding (first flashlight mod, help)
22 posts / 0 new
mikelights
mikelights's picture
Last seen: 2 days 4 hours ago
so I am just starting to get into modding lights and I thought I would start out with a thorfire c8 as a host. I pulled out the old driver and led and I am replacing them with this and this and I am just wondering if they will work together. I did some research and I am basically following vestureofblood’s tutorial on youtube and I am also wondering if there is anything else I should know before tackling this project. keep in mind this is the first time I have tried such a project so any info or tips (no matter how trivial) would be great.
Current collection Olight -S1R turbo S -I3E EOS -S mini brass -S2A -X7R -S mini copper Sofirn -SP33 Nitecore -TM06S Thrunite  -TN42  ThorFire -S70S -TG06S -TK05 Manker -Mk35 Noctigon -Meteor M43 -Emisar D4 -Emisar D1 -Emisar D1S Rofis -TR31 Lumintop - BLF GT -GT Mini -IYP365 -Tool AA 2.0
Product Reviews
Chargers:
Opus BT-C3100MiBoxer C4-12MiBoxer C8Folomov A1
Flashlights:
BLF GTTN42TG06SEmisar D4GT MiniS70STM36EDC-C4BLF Q8
Custom Builds
XPL-HI C8, Aspheric XHP-70OSLON D1S
Edited by: mikelights on 08/01/2018 - 17:11
Fady
Last seen: 6 months 1 week ago
Never had a thorfire c8 but assuming it’s similar to a convoy c8, you’ll need a 17mm driver instead of 20mm you linked too, just check the size of the current driver in it, as far as the emitter choose I personally prefer a cooler temp in throwers like xpl hi V3 1A may be v3 3A/B/C but that’s a personal preference, you’ll also need This if you don’t have an AR lens and This , you may have to file the base of it to achieve the best focus… so get a few of them.
mikelights
So I measured the driver that came in the c8 and it was 20mm outer diameter and the space it sits in is a bit bigger than 20 mm and it comes with a retaining ring it’s not just a press fit so I’m assuming that means it’s a 20mm not a 17mm driver right?
Product Reviews
Chargers:
Flashlights:
Custom Builds
Fady
Correct, if you measured 20mm than that’s what you need, never had a thorefire c8, I just assumed it was similar to the convoy version.
mikelights
Awesome, I appreciate your feedback. if I Have any more questions may I ask you?
Product Reviews
Chargers:
Flashlights:
Custom Builds
Fady
Sure! BTW you not limited to a 20mm driver, A 20mm OD copper washer with some dremel work soldered to the front side of a 17mm driver can be done.
mikelights
Awesome idea I’ll make sure I remember that.
Product Reviews
Chargers:
Flashlights:
Custom Builds
Swib
Last seen: 1 day 4 hours ago
Unless you are really committed to the 5D tint I would suggest the V3 3C as it has better output and a great rosy colour. You should check to see if the thorfire host already has an AR lens first. Under a ceiling light rotate the lens and if it shows purple or blue you already have an AR lens.
Edit: added link to led.
If you don’t like what it looks like on the wall, take it outside.
mikelights
Yeah i wanted to make this warm white because I am getting the mini gt in cool white and I wanted this c8 to be unique, if it really sucks I will just buy the 5000k. The host doesn’t have an AR lens where can I find those?
Product Reviews
Chargers:
Flashlights:
Custom Builds
Fady
Measure the lens currently on your host, if it’s 42mm, than the one I linked to in post #2 is what you need.
mikelights
Just finished the light and it’s amazing, can’t believe I managed to make it work on the first try
Product Reviews
Chargers:
Flashlights:
Custom Builds
Fady
Nice! What led you ended up using? Did you file the gasket or used it as is?
DB Custom
DB Custom's picture
Last seen: 3 hours 53 min ago
Nice work. Now you’re a flashaholic and you’ll never ever be able to stop. Silly
Jack Kellar
Jack Kellar's picture
Last seen: 6 hours 36 min ago
I intend to put a new driver on my C8, so keeping an eye on this thread. Swapping a 3/5 driver for a Biscotti one may be a dead cinch for some, but when you’ve only used a soldering iron once, burned your finger something good and can’t even be sure you did the solder right, well… heh.
mikelights
Used the spacer as is and it worked great, I also used the 4000k V2 5D and I like the color it looks amazing
Product Reviews
Chargers:
Flashlights:
Custom Builds
mikelights
Haha thanks can’t wait to make another already
Product Reviews
Chargers:
Flashlights:
Custom Builds
mikelights
Watch adventure sport flashlights video on soldering it looks like a good video, I had prior knowledge when it comes to soldering but his video looks good for beginners
Product Reviews
Chargers:
Flashlights:
Custom Builds
MRsDNF
MRsDNF's picture
Last seen: 38 sec ago
If only you knew how true these words were. Smile
Nice work. Thumbs Up
mikelights
I may come to find out how true they really are soon enough Big Smile
Thanks
Product Reviews
Chargers:
Flashlights:
Custom Builds
mikelights
Is it alright if I use a Samsung 30q cause I see that it is a high drain battery and from browsing mtn electronic website some leds shouldn’t be used with a high drain battery. I just don’t want to ruin the bulb.
Product Reviews
Chargers:
Flashlights:
Custom Builds
Swib
You won’t hurt an XPL-Hi with a 30Q but it will draw more amps than lesser batteries. This will increase output but also put out more heat. You will likely end up with 6 plus amps. If it is a stock tail spring it might not like it. A bypass or beryllium copper spring from Mountain would help.
Jack Kellar
Thanks, dude. I’m a fan of ASL, he’s super helpful and fun to watch.
