Q8 Parasitic drain
8 posts / 0 new
jigsaw
Last seen: 8 hours 47 min ago
Q8 Parasitic drain
Has anyone experienced parasitic drain with a Q8? I bought 3 of them almost a year ago. One of them was for a friend and his has bad parasitic drain.The other two work perfectly. It will completely drain a set of four cells in about two days if left alone. I have not done any major testing yet. I have disabled the led in the side switch and there doesn’t seem to be any light coming from the emitters when turned off. Any ideas of where to start testing?
BlueSwordM
BlueSwordM's picture
Last seen: 4 min 4 sec ago
A small short somewhere could cause a current drain, which would drain the cells in less than 2 days.
Otherwise, I do not know anyone who experienced this.
Until the problem is resolved, mechanically lock out the light to get rid of the problem.
My very own high current Beryllium Copper springs: http://budgetlightforum.com/node/64047
ImA4Wheelr
Last seen: 23 hours 28 min ago
Maybe check to make sure all 4 of his cells are healthy and not self discharging.  Check the driver to make sure there are no solder bridges and that there are no components on R1 and R2.  There should be some good pictures of the driver around here somewhere to compare against.
jigsaw
Thanks guys. The first thing we did was check the cells. They were a brand new set of 30Q. Had the same problem with a different set of known good cells. I’ll open it up and look at the driver. Yes, he has been mechanically locking it out since we discovered there was an issue. I need to look for some pics of the driver, or I suppose I could compare it to myQ8 .
Calaveras
Last seen: 2 hours 25 min ago
I keep the green lighted switch on at all times and never noticed any drain after a month
Calaveras
No drain after two months in mine and I leave the switch on 24/7.
Mikeadoo
Last seen: 21 hours 42 min ago
3 months no drain on mine either. 30Q. Switch also on 24/7 like Calaveras ^^
I like flashlights!!
jigsaw
Well its pretty obvious that the problem in not in the switch. Hopefully something obvious on the driver.
