Astrolux A01
94 posts / 0 new
Agro
Agro's picture
Last seen: 4 hours 44 min ago
unrealrocks wrote:
Just ordered one of these, looks like an interesting little torch (especially for so little money!).
One question for those who already have one of these, do you have any thermal issues with running a 10440 in this guy? I love my BLF 348 but it just gets too hot too fast if you use a 10440 rather than an AAA.
I have a copper one. Gets hot a bit but never even slightly uncomfortable.
BTW recently I noticed that it has a low voltage protection. Smile
At 700 mV, even with LiIon. Sad
Guess how I found out….
mortuus
mortuus's picture
Last seen: 30 min 51 sec ago
shame the copper version is sold out Sad would like one..
...where Frugal meets with Flashlight!
Macka17
Last seen: 17 hours 37 sec ago
I bought 2 of these first (Astrolux) Batch Grey.
MAGIC….. Just opened the one on my keys Soshine 10440.
They’ve Been on these since new. NO prob’s so far.
I got a coupla each, BLF 348 and Singfire They running on a mix of
10440. Ni-Cads and Duracell.
NONE give a problem. and I find minimal difference in output.
No matter which one I switch on.
Just ordered another 3 too. Yellow. Blue. and Red.
Different one on each keyring. So i know which keys I picking up hey.
House. Boat or car.
BillyBobJoe
Last seen: 3 days 3 hours ago
Does anyone know if you can get replacement glass for these? If so, what size and from where?
Thanks!
Lightbringer
Lightbringer's picture
Last seen: 33 min 10 sec ago
Dunno the size, but I got planar glass from FT and AX recently. Eg, needed 31mm, decided to chance 32mm, and it fit perfectly.
Agro
Agro's picture
Kaidomain has lenses too.
My A01 lens is shattered as well, I don’t want to play with glass particles to measure the size….not this week.
I think it’s about 12 mm but I don’t want to make an order based on measuring bezel ID…
everydaysurvivalgear
everydaysurvivalgear's picture
Last seen: 44 min 36 sec ago
Agro wrote:
Kaidomain has lenses too. My A01 lens is shattered as well, I don’t want to play with glass particles to measure the size….not this week. I think it’s about 12 mm but I don’t want to make an order based on measuring bezel ID…
I just checked its 14mm so the 12mm might be okay?
mortuus
mortuus's picture
so u can run a 10440 battery in this light or is there risk u fry the driver?
Lightbringer
https://www.fasttech.com/products/0/10001022/5422711-14mm-ar-coated-glas...
BillyBobJoe
The glass is 14 or the bezel is 14?
I measured the glasss as 14mm with a ruler
BillyBobJoe
Awesome. Thank you!
Lightbringer
Did you see the link I posted?
BillyBobJoe
I did. That’s what I ordered. Hope it works. Thanks lightbringer.
bidas
Last seen: 19 hours 55 min ago
In my plastic caliper the Astrolux A01 Glass seems like 13.5mm
Agro
Agro's picture
Thank you both for the measurements. Smile I wonder is the maker changed the lens at some point…
I fail to find a 13.x mm lens anyway so I think that a 14 mm one is the best bet. It can be filed if too large…though I hate filing.
I see the same diameter also available from KD, in 1.5 and 1.6 mm thicknesses. But much more expensive. I think I’ll go with fasttech (and BLF coupon which shaves 9 cents off the price) Smile
BillyBobJoe
Rats! You mean I overpaid by 9 cents?!? What is this magical BLF coupon I’ve been missing out on?
Cosmodragoon
Last seen: 4 months 1 week ago
I had one of these on my key chain for maybe a year. It served me well enough. It never failed but there were things I didn’t like about it. First, the twisty mechanism operates by closing a gap but there is some play when not closed all the way. This means that the mechanism can be triggered by pressure when close. Because it is a multi-mode flashlight, it could cause rapid mode change while twisting one-handed. I already hated having strobe in rotation but this meant occasionally activating it. This problem was aggravated by the presence of firefly mode. I appreciate the situational value of firefly but as far as my normal EDC needs go, I almost never needed it. So I was already in the habit of double-twisting for usable light. I also didn’t like that “medium” used PWM, since that ended up being my most-used mode.
Besides that, I really liked the shape. It came in handy and I used it a lot. I was fond enough that I didn’t want to permanently retire it to a drawer. So I sent it to another forum member who I hope will give it a good home.
BTW, they are still advertised as having a 219B but I thought they changed over to 219C. Heck, I think they changed over before I got mine. This wouldn’t be the only case of a company switching over without mentioning it. Massdrop changed from 219B to 219C and didn’t update the product pages until I emailed them about it!
Agro
Agro's picture
The coupon is “BLF” and it works for all flashlight related items, all the time, reducing the price by 5%.
Macka17
I have 2 of mine in hand both running Li-Po 10440.
Both fine.
Also have 1 x BLF 348. and 2 x Sinfire.?
Neither are as interesting or handleable as the AO1.
219 B or C. (I have couple each of that too. old/new models)
mortuus
mortuus's picture
Both fine.
does flat tops work in this light?
bidas
The positive contact in the driver side is flat so you might need a little blob of solder there.
Rexlion
Last seen: 14 hours 51 min ago
Not knowing about the next mode memory, I ordered 7 of the A01. Mostly for gift giving. Dang! They all have NMM, although 1 red one has changed from 2 hours’ recovery to just a few minutes for some reason. I never would have ordered them if I’d realized. And after writing to Banggood, their reply left me feeling like they just got the last money from me, ever.
Today 3 Sofirn C01S twisties came (Amazon order). Much nicer lights for just a buck or two more, and they work as they are supposed to (high, then low, and no annoyances).
I guess I can still give the Astros away to the unenlightened…
Lightbringer
Didja try the infamous Pencil Trick™?
I bought two of the original copper edition gave one to my best mate then an old lumens edition which both of mine have seen no use except to try out. No patina for me lol.
If you lads are trying different lights with 10440 add to my old thread. Ill try and fix the pics up if i can log into flickr.
http://budgetlightforum.com/node/47796
BillyBobJoe
Pencil mod worked for me. Improved the light vastly. First time didn’t work, so I pulled it apart and darkened the line. Amazing!
Macka17
Sorry.
Can’t help with the “flat top“battery question. I got a 4 pack of Soshine Li-Po
Buttton tops.
Buy a small pack of 5×2 or 8×3 magnets. I think I paid aroud $2.75 for a pack of 100 a while ago.
Just stick one on top[ Bingo…..
I’m actually using a few on rear face of knife block in Kitchen for missus.
Bread knife didn’t fit.
NOW. Half a doz shallow holed drilled in line. Epoxy magnets in.
Knife holds nicely. (Just a little distraction that MAY come in handy to someone)
Maybe.
I’ve got a few if those AO1’s.
My old eyes don’t notice any “flicker“So I don’t have a problem with them.
Everyday…………………………..
Do you want to sell that Copper. or tóther if not using.
I love the little things As do Grandkids. (I need a few more)
Queensland 4703. Regards.
Rexlion
Nope. As they are now, I can give them away to non-flashaholics who probably won’t care about the issue. If I take a light apart I might muck it up so it doesn’t work at all or only on moon mode. I don’t have much confidence in my ability to work with very small parts.
If it were one I planned to keep, I’d try it just because. But that red one is losing memory quickly enough… I’ll keep that one! Wink
Barkuti
Barkuti's picture
Last seen: 52 min 31 sec ago
Saw this light again recently at Banggood. Cheap but, at what price? The driver is a turd, and while the “pencil trick” can do away with the next mode memory (a ≈100KΩ resistor across its terminals is a better fix), it has PWM and strobe. It clearly is a flashlight for the rabble.
Also, what the @#$% is the emitter being used now? 5000K? WTF?
I do not think it is hard to design a good boost driver with a li-ion compatible “linear and resistor” mode of operation, after all the boost engine needs a sense resistor and a switch (MOSFET). The MCU would detect above 2V of input voltage and set the driver in linear mode. Sensing 1.5A in a 200mΩ resistor drops 0.3V, and whatever else excess voltage would be dropped at the MOSFET switch by tuning the gate voltage. Wow 1.5A mmm maybe too much heat LoL, 1A or a tad less maybe. And of course, 2.5 - 2.8V undervoltage warning and shut-off or thereabouts.
Cheers Smile
The Light Innocent I am
Deleting a post and redoing it causes the forum thread answer notifications to become invalid. Thus, if you need to change your just published post, edit it. Thanks.
mortuus
mortuus's picture
@barkuti, ah i thought its 4000k emitter in those ? i have on its way lol Big Smile for the price its hard to resist it…
