6th Annual BLF Handmade Entry (Finished!) - gchart
76 posts / 0 new
gchart
gchart's picture
Last seen: 2 hours 29 min ago
Ok guys, this is the first time I’ve entered. And I’m going to start small (I have four small kids, so my only “work time” is after everyone is asleep and I can sneak off to the garage). In looking at past entries, even the idea in my head doesn’t hold a candle to the wonderful creations from years past. But alas, you have to start somewhere, right?
Behold, the flip-lantern! Well, at least a sketch of it.
I’m thinking a small cylindrical housing of frosted glass or plastic (whatever item I can find of appropriate size) with flat caps of wood or metal at either end. A cap can be removed to access the “light engine” inside, which will likely be a sandwich of two custom PCBs held together by copper rods, holding a 18650 between them. The plan is for the PCBs to have 4× 80+ CRI 4000K 2835 LEDs on each one (8 total) being powered by a single 7135 for approximately 150 lumens. Also mounted on the PCB will be a mercury tilt switch and a LDO+resistor combo Current Regulating Diode (Semitec S-120T) to drive the LEDs at around 1mA when you flip the lantern upside down. Flip it back upright and the mercury switch will enable the 7135. Pretty basic, but it should be a fun first build.
Stay tuned!
Tasks Completed:
  • Initial sketch done
  • LEDs ordered
  • Components (minus LEDs) received
  • PCBs received
  • Housing completed
  • Prototype built and tested
  • Final PCBs have been populated
  • Battery guard cut, sanded, and polished
  • Solder battery guard in place
  • Solder conducting rods in place
  • Final touch-ups
Tasks In-Progress:
  • Nada
Future Tasks:
  • Nada
Final Pictures
PCBs before assembly
PCB labelling
Internals, front
Internals, back
High power
Low power
Here’s a proper shot of it, before the diffusion foam:
GIF animation
Highlights:
  • Custom PCBs using white solder mask for reflection (Oshpark link)
  • ~150 lumens from 8× 4000K 80-CRI 2835 LEDs (in High mode)
  • On-off switch for traveling/storage
  • Uses a mercury tilt switch to switch between High and Low modes
  • High mode uses a single 7135 to driver 350 mA to the 8 LEDs
  • Low mode uses a 1 mA Current Regulating Diode (Semitec S-120T) to deliver 1 mA to the 8 LEDs
  • End caps are cut from a Poplar plank, shaped via sanding, and then polyurethaned
  • Housing is plastic (cut from a seasoning shaker), roughed up with sandpaper, and sprayed with Frosted Glass spray. Additional diffusion provided by some sheet foam.
  • Battery guard was cut from a 3/4” copper pipe and shaped with a drill, angle grinder, files, sand paper, and then Mother’s Mag Polish
  • Connection between the two PCBs consists of two copper rods. This also provides a bit of structural integrity in addition to the battery guard.
PS – I have 6 extra PCBs from PCBway. I will likely never use them, so if anyone would like to build their own version of this, let me know and I could probably send you a set (sorry… US only, international shipping would be prohibitively expensive).
Edited by: gchart on 11/30/2018 - 13:07
CRX
CRX's picture
Last seen: 2 min 17 sec ago
Cool, looks like a nice idea Thumbs Up
MascaratumB
MascaratumB's picture
Last seen: 2 hours 59 min ago
Subscribed Thumbs Up
EDIT: don’t forget:
the wrote:
Contestants: Please remember to PM me with a link to your Build Thread.
REVIEWS: AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 /// SOFIRN: SF14 & SP10A / SP32A / SP10B /// NITEFOX: UT20 / ES10K / K3 /// ODEPRO: KL52 / B018 /// ACEBEAM: H20 /// BLITZWOLF: BlitzWolf BW-ET1 /// DQG: AA Slim Ti /// HC-LIGHTS: SS AAA /// XTAR: PB2 Charger /// OLIGHT: M2R Warrior /// WUBEN: TO10R / E05 / T70 /// ON THE ROAD: M1 / i3 / M3 Pro /// ROVYVON: A2 & A5R / E300S / A8 ///
 Tricks: 1 / 2 / 3 / 4 / 5 / 6 / 7   TIR Lenses: 1 / 2   Others: Biscotti 3 & 1*7135     Triple TIR & XP-G2
 MY GIVEAWAY (FW3A)
gchart
gchart's picture
MascaratumB wrote:
don’t forget: …
Thanks for the reminder; done!
_the_
_the_'s picture
Last seen: 23 hours 28 min ago
Cool idea! Thumbs Up
Subscribed to see how this proceeds. Smile
=the=
MtnDon
MtnDon's picture
Last seen: 4 hours 43 min ago
Looks cool!
BLF Member Map Add your name and location.
MRsDNF
MRsDNF's picture
Last seen: 1 hour 43 min ago
Sounds like you have a plan. Smile
Maybe you could fit in one of those little usb chargers as well?
Ok, I’m back in my box. Silly
DBSAR
DBSAR's picture
Last seen: 22 hours 48 min ago
subscribed because its a lantern build! Smile
gchart
gchart's picture
I like the idea (a TP4056?). I dunno if it’ll fit well into the design, but I’ll definitely keep it in mind if it looks like it’ll fit!
FmC
FmC's picture
Last seen: 3 min 20 sec ago
Nice idea, looking forward to watching the progress.
MRsDNF
MRsDNF's picture
You are the man, to do this that is. Smile
Enderman
Enderman's picture
Last seen: 3 hours 6 sec ago
Do many LEDs in parallel, so they all get a smaller bit of current, that way you get much higher lumens/W and you can get longer runtime Smile
Phlogiston
Last seen: 3 weeks 6 days ago
Ingenious Smile
Agro
Last seen: 19 min 37 sec ago
Love the tilt idea, though some kind of lockout would be useful. Smile
Flashy Mike
Flashy Mike's picture
Last seen: 30 min 4 sec ago
Subscribed.
Good luck!
gchart
gchart's picture
Have any of you tried PCBWay or AllPCB for your PCBs? I’m leaning towards PCBWay for this project. I always use Oshpark but I’m looking to get ones with white solder mask. They’re both in China, but seem to have good prices, lots of options, and pretty quick turn around time.
MRsDNF
MRsDNF's picture
Cant help you there. I’ve only used Oshpark.
gchart
gchart's picture
Ok, I’m still learning about proper driver designs, so I’m going to throw my schematic and PCB out here for critique before I order it. The PCB has been uploaded to Oshpark, but I will likely be using a different service (see above).
https://oshpark.com/shared_projects/zMUnQFCd
Another note… I decided to simplify a bit and spec out a Current Regulating Diode (1ma version) in place of the LDO+resistor. I’ve never seen one used but they appear pretty basic.
Oh, another thing… While this is one board, I’m basically designing it as if they were two separate ones, the circuitry is independent of each other. One side will be used as the main board of the lantern while the other will be a slave board.
DavidEF
DavidEF's picture
Last seen: 8 hours 24 min ago
Why is there a ring around the center pad? What purpose does it serve?
Reason is not automatic. Those who deny it cannot be conquered by it. Do not count on them. Leave them alone.
-Ayn Rand
DavidEF
DavidEF's picture
Looking at your schematic. Can you describe to me in words how you expect it to function? I’m having a hard time trying to understand it. Facepalm
EDIT: In particular, the switching doesn’t make sense to me. I understand the slide switch disconnects the ground and turns the light off, but what is the tilt switch supposed to accomplish?
-Ayn Rand
gchart
gchart's picture
Hey David!
  • Ring around battery pads: my plan for holding the battery in place is to have a ring of 3/4” copper pipe (perhaps 1/2” tall) attached to the top of each board with just enough of a gap that the battery can be slid into position and then be held by the spring on the neg pad. The exposed ring on the PCB will allow me to solder the copper pipe pieces in place.
  • Switches: the slide switch, as you said, will disconnect the ground and completely disable the lantern. When that’s switched on, the mercury (Hg) switch will turn the 7135 on or off.
  • Functionality: When the primary board is face up, the mercury switch will be On, enabling the 7135 and pushing 350mA through the LEDs. When you physically flip the lantern over, the mercury switch will turn the 7135 off. However, current will still be able to flow through the Current Regulating Diode (Semitec S-102T) sending 1mA to the LEDs for a dim glow (akin to the illuminated tailcaps I’m so fond of Wink ). I am debating, however, if 1mA might be too bright. Most of my tailcaps operate at around ~0.15mA, but then again, this lantern is much larger than a tailcap.
DavidEF
DavidEF's picture
OK, I get it now, the two power deliveries are wired parallel to the LEDs. Either just the 1mA source or that plus the 7135 will be on. Thumbs Up
-Ayn Rand
gchart
gchart's picture
Yup!
gchart
gchart's picture
The PCBs came in today. At this point, I’ve got all of the parts except the LEDs.
Next up: preparing the housing (probably the most difficult step for me, limited access to proper tools)
gchart
gchart's picture
Even though my 4000K LEDs aren’t in yet, I couldn’t help but build a prototype while I wait! I have some 5000K on hand, so I used those – I just wanted something warmer for a “lantern” style device.
Differences between this light engine and what I have envisioned for the final version:
  • 5000K LEDs instead of 4000K
  • Used a 1800 Ohm resistor instead of the 1mA current regulating diode. Assuming a supply voltage of 4.2V and a LED forward voltage of 2.43V (as measured), that should give me roughly 1mA on a full battery: (4.2V – 2.5V) / 1800 Ohms = 0.00098A = 0.98mA
  • Jumped the switch pads with a wire instead of a switch (like the CRD, I only bought one switch)
  • Stranded copper wire for the conductor pillars instead of the copper rods (only bought enough for the final version)
  • Battery is only held in place by the spring tension. I plan on having a partial copper surround and then a velcro strap or something to make sure it doesn’t budge.
Dim mode, Bright mode
Action video:
Another tidbit… assuming a 3000 mAh battery, this should last 8.6 hours on high or 4.2 months on low/moonlight.
pinkpanda3310
pinkpanda3310's picture
Last seen: 3 days 6 hours ago
Nice progress. Is the battery going to be removable?
FmC
FmC's picture
That’s pretty cool. You are certainly making some headway into the build.
Flashy Mike
Very nice!
electricjelly
electricjelly's picture
Last seen: 3 days 11 hours ago
Very cool idea. The build looks like its coming along nicely.
gchart
gchart's picture
Thanks all!
Yup, battery will be removable. It may not be super easy, but reasonable enough.
MtnDon
MtnDon's picture
Thumbs Up
