Best charger that can charge over 1 amp other than Opus and Miboxer?
29 posts / 0 new
Mikeadoo
Last seen: 1 week 4 days ago
Hi all, it’s your favorite person here with Miboxer C4-12 problems…… AGAIN…
I am reading the forum about chargers but would like opinions of good chargers that can charge over 1 amp if needed. I have the C4-12 and Lii-500.
I would like advice from people that know about good chargers for the money without paying $200- $300.
Miboxer C4-12 measures brand new cells at 999 ohms. I’m getting pretty frustrated at this charger. I even got “—-” today for the ohms on Miboxer.
Thanks in advance.
Mike Big Smile
Mike
maukka
maukka's picture
Last seen: 13 hours 27 min ago
Get a couple MC3000s and you don’t have to think about shopping for chargers for a while.
Mikeadoo
How much is a MC3000? Never heard of it before
Mike
Pete7874
Pete7874's picture
Last seen: 2 hours 43 min ago
If MC3000 is too expensive, then also look at these:
- Folomov A4
- Xtar SV2 Rocket
Mikeadoo
Wow I’ve never heard of any of these lol. All on Amazon? Do any Xtar chargers come with power brick plug things if that makes sense? Or do I just use my phone charger?
Mike
Pete7874
Pete7874's picture
But does it prevent you from manually setting the desired charge rate?
Mikeadoo
Sometimes yes. I tried setting it to 2 amps charge and it went back down to .92A charge.
Mike
Mikeadoo
Does not do that with my LG HG2 cells though. It’s strange
Mike
ChrisGarrett
ChrisGarrett's picture
Last seen: 2 hours 28 min ago
Anywhere from $95-$110 shipped to Americans in America.
It’s ‘probably’ the best consumer charger, extant.
It’s not a charger for dolts, however.
Chris
Pete7874
Pete7874's picture
What was the cell’s voltage when it happened? Once the cell is close to full, the charger will automatically reduce current – standard CC/CV algorithm thing.
Mikeadoo
3.6V.
Mike
Mikeadoo
Pete I’ve had 2 cells in there charging for 51 minutes now and it says 4.2V but the charger also says the cell is 28% charged.
Mike
Gebe
Last seen: 5 hours 5 min ago
Pete7874 wrote:
If MC3000 is too expensive, then also look at this- Xtar SV2 Rocket
Can’t beat the Rocket! Press of a button shifts between 1amp to 2 amps and it is relatively inexpensive.
Enderman
Enderman's picture
Last seen: 10 hours 43 sec ago
Nitecore has some that do 3A charging IIRC.
Mikeadoo
Chris
That’s a bit much for me. Right now at least. I dont need a charger with bluetooth and an app.
I will look at some of the mentioned chargers.
Mike
Mikeadoo
Is that the Nitecore VS4 or whatever it’s called? New charger (I just seen it) looks like D4 just bigger, tells you if the battery is “good” and such?
Pete I guess I shouldn’t say it’s “too expensive” since I did buy the Maha Powerex for NiMH over $100 lol.
Mike
pennzy
pennzy's picture
Last seen: 4 hours 48 min ago
Try some alcohol on the contacts . Should drop the ohms .
Mikeadoo
Hey pennzy I actually just did clean them last night with some rubbing alcohol. Worked good at dropping the ohms. Seems to be either the protected batteries with issues or the charger. Idk anymore. The percentage did just change from 28% to 81% just now so idk what’s up with that.
That Xtar Rocket looks really nice. Might buy one just because I like the idea of a smaller 2 bay charger like for traveling or whatever. Looks like a nice little charger.
But yeah I don’t get what’s going on with whatever is causing this problem.
Could I just be the batteries?
Oh btw I cleaned the charger with alcohol last night. Used a pencil eraser on the battery contacts today.
Mike
pennzy
pennzy's picture
Unless it’s preventing you from selecting higher charge currents, I would not be concerned with what it reads. I have exactly one cell that reads low. All others read high . The 26650 is the one that reads low . I think it is also the longest, putting the most pressure on the contacts. With this theory , resistance should decrease by pressing on the slide with my finger but no, it doesn’t so I don’t know whats up with it.
Mikeadoo
Ok. It seems to be working now. Maybe I just put em in and just let it do whatever it wants to do.
Lol. Thanks all for the help.
Mike
Pete7874
Pete7874's picture
Such a drama queen. Smile
Mikeadoo
Only me Pete! Only me haha Big Smile
Mike
Enderman
Enderman's picture
SC4 I think.
Check the specs, I’m sure it has protection against faulty batteries like all good quality chargers do.
Mikeadoo
Thanks Enderman. I’ll check it out. I said other than Opus because I just bought the BT-C3100 from liionwholesale. I’ve heard (on YouTube) that it’s awesome but sucks pretty much. So I just want a decent charger without breaking the bank. Nitecore chargers are usually priced fairly I think. I’ve only had their old I4 and a few D4 that I gave away as gifts.
Mike
Pete7874
Pete7874's picture
Why do you think the Opus one sucks?
Mikeadoo
I don’t. I just see lots of U tubers commenting that it melted and arguing about stupid stuff. I bought it because I was told and read it is a great charger. If I thought it sucked I wouldn’t have bought it lol.
I don’t mind that little fan noise. Dunno what it sounds like, but if it works then that’s good with me.
Mike
d_t_a
Last seen: 2 days 20 hours ago
Will also suggest the Miboxer C4-12 (charge current is selectable, and it shows IR relatively reliably — for checking conditions of various cells).
The SkyRC MC3000 is probably the top-of-the-line and it’s about twice or more as expensive as the C4-12, but MC3000 seems to be the best (or most functionality that the common people probably won’t get to use).
Both of the above can charge 4× 26650 at 3A at the same time. (both come with a beefy 60 watts power supply brick)
Andrew_Debbie
Last seen: 1 month 1 week ago
How about an ISDT-C4? You should be able to get one for under $60. It is good for charging pairs of 18650s quickly. You can set the current anywhere between 0.1A and 3Amps per slot. Total charge power is limited to 25Watts combined.
The C4 does not have sliders. Cells that stray too far from the standard won’t work. It is limited to two 18650s or a single 26650. Short cells would need a DIY spacer. It can also charge 4xAA or 2xAAA but not at the same time.
For me, the biggest drawback is the single 26650 slot.
HKJ tested it but not with the latest firmware. The current firmware fixes some of the issues he reported.
http://www.isdt.co/c4.html
Mikeadoo
Ok everyone it’s the drama queen again lol.
Really like my Opus BT-C3100 V 2.2
But dug my C4-12 back out (i also bought the SV2 Rocket which is awesome)
I was emailing back and forth with Thrunite customer service who were VERY helpful and quick to get back to me about cleaning the cells.
Guess i used the wrong alcohol. So i went and got me some of that isopropyl alcohol (not sure on that spelling) the 91% stuff from Walmart.
Cleaned all my batteries. I haven’t checked this thread in forever but i got some brand new protected panasonic NCR18650B and the IR is crazy again.
Should i try cleaning the contact points on the C4-12 with alcohol and not the pencil eraser which i think i said i did?
I contacted Miboxer on here PM and they said to make sure the charger is completely dry before i go to charge again. So my stupid question is…… how long should i wait for the charger to dry to make sure it’s completely dry?
Never cleaned a charger or any electronic device with any type of liquid form before.
Thanks anyone.
I think this is the thread when JasonWW solder blobbed my Samsung 30Qs. Not sure. I just didn’t want to start another thread about the same thing pretty much
Mike
