Olight I3T EOS review (180 lm, Philips LUXEON TX, AAA)
3 posts / 0 new
viperxp
Last seen: 3 months 5 days ago
Greetings,
This review will be dedicated to a new AAA flashlight from Olight, the I3R IOS.
Flashlight page on Olight website
What’s interesting here? Well, the light manages to be able to output 180 lumen from alcaline AAA battery. It’s really great, Olight can be really proud by such achievement. Also, the price is nice for such a light – MAP of less than 20$.
Let’s start?
The light comes in a small mostly white box, just like other new Olight models.
Inside the box you can see a warning, about the need of removal of the protective insulating film (the light won’t turn on unless it’s removed). The light comes with Alkaline cell preinstalled.
User manual scans. This is one of the light where you can just skip reading the manual, as it’s very easy to use.
The light is being controlled by reverse clicky switch, meaning that you can switch modes before actually setting the mode. The light always turns on in low mode, and half clicking the button switched modes between low and high. The button itself is made partly from resin/silicone and partly from plastic – very nice and sturdy feel.
Regarding the feel and positioning – the light may look like a classic keychain light, but according to Olight it’s not. For once – it misses the ring to be able to fix it to the keys. Second – the T in I3T stand for Tactic, meaning that it’s supposed to be some king of tactic backup light.
The knurling is very unusual – the light surface is smooth, but has a double spiral on it – double helix design according to Olight. Well, it does it’s job, the light feels nice and stable even in wet hands. Notice the double way clip – you can also fix the light to your cap if needed.
The TIR optics are located behind a protective glass – a solution we don’t see often. Too bad the glass does not have AR coating.
The taicap seems to be made from brass, has much lubrication from the factory. The tailcap is easily removed, thanks to the horizontal lines applied.
Action?
Well, it surely delivers.
The low mode can be enough to be used indoors, but outside you better use the maximum mode. There is no PWM on any mode. The tint is classic CW, not too cold and surely not warm.
Conclusion, final words
Great, especially considering the price. What was just a dream couple of years ago – 180 lm from aaa alcaline – is now a reality.
willc68
willc68's picture
Last seen: 41 min 49 sec ago
Good review!
I’ve had mine for over a month now and it is a handy little light.
I should have my copper one any day now, I doubt that will get as much carry time just because of the weight factor.
The i3T is much better than the Microstream imo, I carried that for a while but the hard to engage switch really killed it for me.
The Olight switch is way nicer plus it has 2 modes.
x-ray
Last seen: 18 hours 37 min ago
Nice review viperxp Thumbs Up
Just a minor point but the first line of your review has a typo – you refer to the light as I3R instead off I3T
