GB Clone Offically "SOLD OUT" 10/21/18 XPL HI 1300LM Focusing AKA Cometa 2016
804 posts / 0 new
nottawhackjob
Last seen: 5 hours 33 min ago
“For the price this is a good host but nothing like a real Z1, period.”
I don’t have a real Z1 so just how much better is it over the Cometa in real life terms?
“In many things in order to truly understand the small picture you have to understand the big picture first.”
DENGOH
DENGOH's picture
Last seen: 2 months 1 day ago
Tom Tom wrote:
DENGOH wrote:
US$14.95 (Earn 14 BG points)
Sold Out
Ships from CN Warehouse
Is EU warehouse still in stock?
Yes, of course. Still showing 143 in stock.
Maybe get a VPN where you can choose the end-point from around the world.
And use a private browser window so those pesky cookies don’t persist.
The same applies when trying to book flights etc.
The mind-games continue Wink
I am thinking Banggood oversell clearance price stock and pick the one with lowest shipping cost for them in order to save cost.
cool i'll see you when you get there
Alen
Last seen: 6 days 7 hours ago
The point is that once the problems on the Cometa are fixed
Which are the Pro of the Z1?
vidramon
Swap the plastic ring to the right one and see if you get the same results.
If not the left one is somewhere set up differently than the right one and thus doesn’t necessarily prove that the plastic ring will tend to work for all samples recently received out there.
Worth a shot for others to try the same experiment though. Couldn’t hurt.
I presume you know to read… I told that is on my tested sample and tell people to test on theirs if they want, so your post have no point..
Satan@103TFS wrote:
Mine come with 2 white plastic rings on both LED side and driver side out of the box.
Hmm my only one pastic ring on driver spring. So they are selling different batches probably, one come with both rings and one with only one..
As regards of the host that some of you tell that this is good/excellent host, I can’t agree, why, because last night I have just a little time for testing but what I saw on hurried, a b158 stock host ( with nanjg 105c and XP-L HI ), performing similar to this cometa with fet driver on full zoom mode !
I will do tests when I have more time and post here but what I saw on briefly b158 host is much more better for full zoom that this one !
teacher
teacher's picture
Yeah T18, that was quite a time for everyone….. to say the least. In fact, if you’ll remember; the RUDE button was created toward the end of that time.
I’ll just leave it at that….. Wink
As far as the difference between the Cometa & Jaxman Z1, what do you think? Besides the Z1 was an original design of Paul’s of course & the Cometa was a knockoff.
To me the ‘differences’ are mostly subtle.
I think the pill & disc of the Z1 are no doubt better designed. They both work of course, but as far as I am concerned the Z1 is much more refined & thought out.
The overall tolerences of the Z1 just feel tighter to me in general. Wink
Those are my thoughts on the subject……
nottawhackjob
Ok I get that there are subtle differences it appears more so in the overall quality of materials and workmanship, but as far as raw dog performance the differences then are also subtle?
Just want to hear your opinion in that particular aspect. However, I f that’s all you want to say on that specific could-be-touchy-subject-in-view-of-the-past-circumstances, I can also understand any reticence. Shocked
teacher
teacher's picture
I have not measured the numbers of each, but IF I had to choose only one (leaving out cost & all the BS of the Jaxman design being ripped off, etc., etc.) I’d go with the Jaxman Z1.
That’s about all I can tell you. The Cometa is good enough, the Z1 is a bit more refined to me.
A VW will get you where your going, so will a Porsche. Your choice… Wink .. Big Smile
Alen
Also 22 mm size driver or more is better on 26650 host like Z1 I agree.
This 17mm need to be perfect fixed on pill and put in secure
to avoid shorts problems,tollerance are too smalls.
The head threads loose a bit and don’t have O’rings (Jax z1 have?).
Is rought when turned,need Grease
and can slip on the Led when head is hot
Lawried
Last seen: 1 year 1 month ago
I ordered on Monday when they said they had stock back in and my order just went from processing to backordered. Shenanigans afoot….
waynestractor
Last seen: 1 month 1 week ago
Mine says the same. I just messaged them, if it is BO I will cancel the order.
Fenix HP30 Headlight...Fenix LD75C...Fenix 3500mAh 18650's...Eagletac SX25A6...Armytek Partner A1 V2...Imalent DN12...Imalent D70...Utorch UT02...Convoy C8, Convoy L2 XPL HI U6 4B, Nebo Redline, Nebo Redline Blast, The typical $10 3000 lumen XML-T6 Zoomy...So far anyhow!
Tom Tom
Last seen: 10 months 6 days ago
Back ordered probably doesn’t exactly mean that, since I very much doubt that Manker are making any more of them, even if Banggood would touch them with a sh*tty stick if they did.
I expect it just means that they are moving stock around between warehouses, of which the UK one still seems to have loads.
But with BO, you might just have to pinch your nose and wait, if you really want it. You do, don’t you ?
Well, that’s my theory, but, who knows ?
Lawried
Can you post the reply? I’ll likely cancel too if it is a backorder.
Lightbringer
Lightbringer's picture
Last seen: 1 hour 12 min ago
Oh, what fun to pay extra for shipping (USA Express), and not get a tracking number.
First order, free, came with a tracking number.
Second order, paid almost 4bux extra (was supposed to have the cells, so wanted fewer complications with “better” shipping), and no tracking number.
I have a back’n‘forth in email, which is pretty much like “blah blah blah Ginger blah blah Ginger blah blah blah blah Ginger”.
Fun… Enough to turn anyone off ordering stuff for a while.
Anthon
Last seen: 3 hours 31 min ago
Just received mine. Ordered on 09/23.
Thanks for the deal
Measured at 950lm and 800m stock
-X3-
-X3-'s picture
Last seen: 12 hours 43 min ago
Don’t drop it on concrete floor guys Facepalm
"-X3-, is there any place in your house without a flashlight ?"
My Flashlight public album (mods, emitter swaps, eye candy)
My reviews channel (French language, Olight, Thorfire, Sofirn, Lumintop : 60+ lights tested)
My personal channel (including Olight SR mini, S1, S2, S1A and S-mini disassembly)
M4DM4X blog, saves you $$$
djozz
djozz's picture
Last seen: 4 hours 17 min ago
Ai, that’s bad. It is such a nice lens Crying
-X3-
-X3-'s picture
It still is, fortunately only the lip is broken.
Once it’s installed in the head I can’t see any defect and it doesn’t affect the beam…
Anyway I have a second one “processing” on BG right now Innocent
lampliter
lampliter's picture
Last seen: 8 hours 47 min ago
Backordered also.
I’ll play the waiting game; just to see what happens. Glasses
"The sun, with all those planets revolving around it and dependent on it, can still ripen a bunch of grapes as if it had nothing else in the universe to do." ~ Galileo Galilei
eas
eas's picture
Last seen: 1 day 1 hour ago
I ordered one (without batteries) on 9/24. After a bunch of back and forth, including 18-24 hours when it was supposedly backordered, despite them showing multiple pieces in stock, I got a notification it had shipped on ~9/29/. It took until ~10/5 for a tracking number to show up.
Their site says there is no tracking data, but checking the number on USPS shows that the label was printed on 9/29 in SLC. It’s been like that for at least a week. Current ETA, according to Bangood’s site is 10/28, which is probably two weeks later than what I’d originally been led to believe.
Oh well. I’ll give it more time.
In the meantime I ordered another. There were three in stock when I ordered & two after. Now my order info is showing backordered. But the site says there are three units in stock.
I’ve never had anything close to this much hinkyness from Banggood before, at least not at this stage. I’ve had things take forever to get here. I’ve had them ship the wrong thing. I’ve had them be incredibly reluctant to make (sufficiently) good on their mistakes or product problems. This though, this is new to me.
chinooker
chinooker's picture
Last seen: 46 min 47 sec ago
I ordered W/battery on 9/20, I cancelled the order a couple days later once I got the cancel button. They had already shipped the 2 free 18650s which haven’t shown up. Then I got a notice they had shipped my order on 10/9. I guess I’ll take a look at it and decide iffn I want to mess with it or flip it. I’ll no doubt keep the 26650 iffn it’s in there.
DENGOH
DENGOH's picture
Be careful with the lens, lucky for me I dropped mine from about 5mm height where it already sat on my table, when open the bezel, make sure the lens is facing down so that it doesn’t drop out of the bezel. The lens is loose inside and not holding itself on the bezel.
Nachtfeuerzeug
Nachtfeuerzeug's picture
Last seen: 37 min 35 sec ago
I turned up the heat allowance and now the driver-side anti-short ring is pretzled. It'll still do the job but it's loose now. I'm going to add some kapton tape just for kicks.
nottawhackjob
The main reasons I bought this flash in multiple quantities is for the AR glass lens, the short 26650 tube, the twist zoom, the pocket rocketability and of course the great BLF price.
But must of all I bought it to piss off TOM TOM. LOL
TheOnlyDocc
TheOnlyDocc's picture
I really do not know what BG is playing. They still sell the light China warehouse but my order switched to backorder yesterday.
Also i had to contact the support for some questions in the last two month (pre sales product information). The answeres i got were not the answeres to my question. Not even close! If i had asked my postdelivery guy the questions i would have gotten a answere that is more usefull! It was always bad but not this bad!
@nottawhackjob Beer Thumbs Up Beer
New WildTrail (former LuckySun) D80v2 Sale has Started http://budgetlightforum.com/node/66255
T18
@nottawhackjob LOL Thumbs Up Thumbs Up Beer Beer Beer
DENGOH
DENGOH's picture
Beer Beer Beer
Mine also back order even though it is still in stock status now. I asked CS and was told it is in processing. No proper direct answer, are those CS actually AI robots?
teacher
teacher's picture
It appears the ordering process on this one is kinda like a ‘box of chocolates’… you never know what your gonna get. Or when your gonna “get” anyway. Big Smile
teacher
teacher's picture
BROODMASTER wrote:
I turned up the heat allowance and now the driver-side anti-short ring is pretzled. It’ll still do the job but it’s loose now. I’m going to add some kapton tape just for kicks.
“Pretzled”? . Did it melt??
Lux-Perpetua
Lux-Perpetua's picture
Last seen: 6 days 8 hours ago
teacher wrote:
It appears the ordering process on this one is kinda like a 'box of chocolates'... you never know what your gonna get. _Or when your gonna "get" anyway_. :D
Well spoken!  Thumbs Up  Beer
Or to say it in different words...maybe it's all just floating around accidental...like on a breeze. Wink
BTW: Mine is still stuck in Xiamen, China for more than one week.
DENGOH
DENGOH's picture
Mine is shipped. So it took about 48 hours from processing to back order to shipped. Finger crossed.
