hi guys, can you tell me which flashlight should i buy?
here is what i’m looking for:
-tailcap switch (preferably one touch to turbo)
–500=>600m throw
-medium reflector size (~40mm-50mm)
-onboard charging
single 18650 or 20700 or 21700 battery
i like Acebeam L16 and Klarus XT12GT, can you compare them?
All you need is Convoy C8+. 570 meter beam distance. Save your money for other toys. Just order it with momentary on switch.
This mode is OK for tactical use:
11. 100, 20, strobe
L16 is good light. But I will never buy flashlight offering only cool white tint.
Especially for thrower best tint for me is around 4000K. If you have smoke, fog, dust in air, you are done with cool white tint.
The lumen output is very stable after the temperature sensor reduces power because it uses a BOOST driver, meaning power output is constant for the LED.
This means that until the battery is completely empty, the brightness runtime will be completely regulated and stable.
