Convoy Copper S2+ question
11 posts / 0 new
Funner
Last seen: 1 month 4 weeks ago
Will the Copper Convoy S2+ at the Convoy Store Aliexpress of Simons tarnish? For anyone who has one.
I want to get one but only if it will tarnish. It would be nice if it had no clear coat and was raw copper. Or is it a copper anodized finish?
Edited by: Funner on 10/06/2018 - 14:47
BlueSwordM
BlueSwordM's picture
Last seen: 1 hour 12 sec ago
It is raw copper, although a different type than we usually see so it is easier to machine.
So yes, it will oxidize.
My very own high current Beryllium Copper springs: http://budgetlightforum.com/node/64047
BobbyMK
BobbyMK's picture
Last seen: 32 min 39 sec ago
It is coated with something. Not sure if it is anodized or some paint lacquer or something else but it wont tarnish.
Here is mine, few months old now and still shiny as the day i got it.
 Olight i3s, Olight S1, Olight S Mini, JetBeam Jet-1, BLF 348, Astrolux S41S, UF SK-98, Convoy S2+ 3*XP-G2, Convoy S2+ 3*XPL, Convoy S2+ 219CT, Convoy M1, Convoy C8, Brinyte B158, Courui D01, Convoy L6, Noctigon M43
SKV89
Last seen: 19 min 42 sec ago
I bought one from the initial batch few months ago. It didn’t tarnish but I stored it away in a dry place and haven’t used it so I can’t tell if it is coated or not. You should ask Simon. He responds quickly on Aliexpress.
justanotherguy
Last seen: 3 min 34 sec ago
I got one of the first ones stateside. I forget which one of the two i have it is….
That said neither has appreciably tarnished yet and I EDC them in a maintenance job…
Funner
Thank you all for the needed input and answering my question.
Have a great rest of your weekend, stay safe.
Out
timbo114
timbo114's picture
Last seen: 8 min 17 sec ago
Simon told me this morning that there IS a protective coating on the copper.
I used straight acetone (on a microfiber cloth) to remove the coating.
chinooker
chinooker's picture
Last seen: 1 hour 1 min ago
Be aware that acetone will dissolve many rubber type switch covers.
I lost an UltraTac K19 to submerging it in acetone.
Best to wipe it down.
LAB
Last seen: 4 days 12 hours ago
I like the coating myself.
freefly
Last seen: 3 weeks 2 days ago
The S2+ is easy enough to completely disassemble. When I got mine, I stripped it down to the bare copper pieces (head, body, & tail cap), then went at it with acetone and a toothbrush.
Took a bit of work, but finally got all of the clear-coat off. Thumbs Up
contactcr
Last seen: 31 sec ago
chinooker wrote:
Be aware that acetone will dissolve many rubber type switch covers. I lost an UltraTac K19 to submerging it in acetone. Best to wipe it down.
Good advice either way but the convoy boots should be fine. I dunked an M2 for quite some time and it was fine. With that said I would still wipe it cause this clear coat may not be as resilient as ano and you dont want that acetone on any longer than it needs to be.
