Recommend me a charger, please.
22 posts / 0 new
dealgrabber2002
Last seen: 12 hours 18 min ago
Can you recommend me a charger that chargers li-ion, lifep04, and nimh that has a refresh/discharge feature? 2 slots, inexpensive.
I already have a Nitecore i2.
Have some old li-ions and eneloops I want to refresh.
Thanks.
DavidEF
DavidEF's picture
Last seen: 9 hours 22 min ago
I’m also interested in a decent, low-cost charger as described by the OP, except I’d rather have 4 slots. Big Smile
- The YKK Philosophy
Funner
Last seen: 4 weeks 23 hours ago
I believe Gearbest through Fin’s coupon code has the Liitokala has a 2 slot charger for $5.99. I have the 4 slot and it has been perfect. Very happy with it. Mine came with the wall and car adapter plug. I got it because my nitecore charger over heated and stopped working.
Good luck
Funner
BLF topic but must click on charger pic through BLF for discount, Member is Fin17, coupon post date 10/4/18, item is Liitokala Lii-202: http://budgetlightforum.com/node/52547?page=111
Code is still working $5.99: https://www.gearbest.com/chargers/pp_424662.html?lkid=10940189
Not sure if it covers all the specs you want, but check it out.
I have the Liitokala Lii-500 and it has been great.
Lightbringer
Lightbringer's picture
Last seen: 7 hours 45 min ago
The almighty Miboxer C4 has 4 slots, but I think it only handles non-Li cells in slot 4.
jigsaw
Last seen: 1 day 10 hours ago
I’ve been considering this one. Just haven’t pulled the trigger yet.
https://www.amazon.com/Opus-BT-Intelligent-Compatible-Batteries/dp/B0185...
dealgrabber2002
Liitokala Lii-202 refresh and charges lifep04?
DavidEF
DavidEF's picture
Does it work with LiFePO4 cells? It doesn’t say in the listing. Only Li-Ion, Ni-Cad, and NiMH are listed.
DavidEF
DavidEF's picture
Same question as above. LiFePO4?
dealgrabber2002
Clicked on Fin pictures, no discount.
ven
ven's picture
Last seen: 2 weeks 2 days ago
jigsaw wrote:
I’ve been considering this one. Just haven’t pulled the trigger yet. https://www.amazon.com/Opus-BT-Intelligent-Compatible-Batteries/dp/B0185...
Mine has been excellent, over 2.5yrs(cant even remember how many years total) at least. Plugged in 24/7, been used daily for years until recently. Only down to having a c4-12 sat next to it. I still use the opus for nimhs, also when i am charging more than 4 cells(over spill from the c4-12).
I have already opened up the miboxer c4-12 as a bay spring snapped, so had to repair that the other day.
Back to the opus bt c3100 v2.2, lots of charge current options from 0.2a to 2a on bays 1 and 4. All 4 bays in use limits to 1a each. I have found it to be reliable, flexible and good value. Smile
ven
ven's picture
Inside is a switch(i have mine opened up on the back of the charger) and a 3.7/ 4.35/ 4.2v switch can be used. I only use the 4.35(sanyo 16650 cells) and of course the 4.2v for my li ions.
It aint pretty haha
Funner
Not sure. $6
dealgrabber2002
I found out it charges lifep04. Look at the picture, next to the battery LED icon, second one down, it states it.
Not sure about refresh mode tho.
Funner
Yea, I looked at Gearbest after your last post and I had 2 of those chargers in my cart, says OUT OF STOCK.
That forum of Fin17’s for Gearbest deals is the one to watch.
ActiveAl
ActiveAl's picture
Last seen: 4 days 19 hours ago
jigsaw wrote:
I've been considering this one. Just haven't pulled the trigger yet.
AliExpress has several stores offering the Opus BT 3100 V2.2 for about $29.50. But you'll have to wait 2- 3 weeks for delivery.
Monsieur Lightbringer, don't you own this charger?
Lightbringer
Yeah. Nice, but gets heat-stroke easily and the fan buzzes like an angry bumblebee if you use too much current.
I usually have to stand it on-end to let hot air waft upwards, helping it along, vs having to suck it out sideways.
ven
ven's picture
My fan was noisy out of the box, very noisy in fact. I bought a couple of spares from gearbest(not much over a $1 iirc………….cheap!). Swapped it out and its been quiet ever since(24+ months)
atbglenn
atbglenn's picture
Last seen: 1 week 6 days ago
I wonder why Opus uses crappy fans in the first place?
Boycott Nike
ven
ven's picture
Guess all down to cost, cheap components= more profit.
Ironically, the cheap fan inside was replaced with another cheap fan of which is quiet . Maybe luck of the draw as they are very cheap. Other than that(not really a major issue as i put up with it for a year), its been faultless.
I usually or have recommended the opus several times of past, for around $30 its hard to beat imo.
Liking the c4-12, like just being able to place cells in the bays without pressing any buttons. Also the auto charge setting it chooses , seems to be spot on. Other than one of the springs snapping(again cheap components), its been very good so far. I have the c4-12 and 3100 v2.2 sat next to each other for most of my down stairs charging.
dealgrabber2002
NVM, it does not charge lifep04. It will detect that type of batteries but won’t charge.
Also no refresh mode.
matik42
Last seen: 4 hours 10 min ago
Maybe MIBOXER C2-4000 Dual Slot Battery Charger
https://www.fasttech.com/products/1421/10036918/9310500
(some rumor that code BLF may work, but cant confirm)
