If you had to choose a LED for a Zoomie Flooder, XHP70-50, L2, MT-G2, Triple L Hi
15 posts / 0 new
Funner
Last seen: 1 week 1 day ago
If you had to choose one for dropping in a Zoomie host, mainly for great flooding up to 50 yds out. Xhp70, 50, L2, Triple L Hi, or MT-G2. Or other. I will be powering it with a Keeppower 6000mAh.
Thanks
Edited by: Funner on 11/03/2018 - 18:21
Barkuti
Barkuti's picture
Last seen: 1 hour 29 min ago
You could also choose 4x 3535s for as long as your zoomie uses ∅20mm MCPCB. Related information: Frankenquads using 20mm 2x2 3535 MCPCBs
Available in all variants: 4S1P, 2S2P & 1S4P.
Smile
Cereal_killer
Cereal_killer's picture
Any time an MT-G2 is an option it’s always the option!
adam7027
Last seen: 5 hours 12 min ago
I would also consider Nichia 319A (hexagonal light emitting surface, small 3.5mm×3.5mm footprint) or Samsung LH351D (again 3.5mm×3.5mm). LH351D has very large surface under the dome, so it should look somewhat roundish, when focused.
Geuzzz
Geuzzz's picture
Last seen: 42 min 1 sec ago
Good old MT-G2 Thumbs Up
thisnameisvalid
thisnameisvalid's picture
Last seen: 8 hours 52 min ago
You can’t go wrong with an MT-G2 Silly
-X3-
-X3-'s picture
Last seen: 11 min 59 sec ago
Here is what an LH351D looks like behind the Cometa aspheric optic (left is LH351D, right is sliced SST20) :
"-X3-, is there any place in your house without a flashlight ?"
My Flashlight public album (mods, emitter swaps, eye candy)
My reviews channel (French language, Olight, Thorfire, Sofirn, Lumintop : 60+ lights tested)
My personal channel (including Olight SR mini, S1, S2, S1A and S-mini disassembly)
M4DM4X blog, saves you $$$
Funner
Looks like I may be leaning toward the MT-G2, since I have a number of XHP50’s.
So I just ordered the MT-G2 and Xhp50’s, and more.
As a little blaster the MT-G2 will go into my Convoy M2 with a 17mm driver and two Keeppower 18350’s.
Another MT-G2 will go into a Zoomie. Link: https://www.aliexpress.com/item/Powerful-Tactical-LED-Flashlight-T6-Led-...
leaftye
Last seen: 2 weeks 6 days ago
It’s like the love for the MT-G2 has only grown fonder.
The low mode should be lower.
Reviews: Efan IMR18350 700mAh 10.5A, <a href="http://
Funner
Thoughts on a MT-G2 in the Zoomie I pictured? Or would another LED be better?
Thanks for all the input too!!
Barkuti
Barkuti's picture
Funner wrote:
Another MT-G2 will go into a Zoomie. Link: https://www.aliexpress.com/item/Powerful-Tactical-LED-Flashlight-T6-Led-lamp-10000-Lumens-Zoomable-Waterproof-Torch-for-26650-Rechargeable-or/32844920042.html
Does that look like some sort of Warsun? 28mm head travel path…  I wonder how good is the emitter shelf/cooling inside of that aluminium can.
I may try Kaidomain's “fishing flashlight host” some day, huge space for driver (∅23mm) and led board (∅26mm). Thumbs Up
Cheers Smile
Funner
I may try Kaidomain’s “fishing flashlight host” some day, huge space for driver (∅23mm) and led board (∅26mm). Thumbs Up
Cheers Smile
All easy fixes. It will make an ideal zoomie.
Funner
So in a large diameter Zoomie would a Xhp70.2 flood better than a MT-G2?
Mike C
Mike C's picture
Last seen: 3 days 21 hours ago
I built a zoomie with a MT-G2 for a friend a few years ago. It turned out rather nice: http://budgetlightforum.com/node/38320
Funner
Cheers Smile
I picked up that “DIY Fishing Flashlighht Host 26650” from Kaidomain. I got it in yesterday, put a MT-G2 and H1-A 20mm driver with a 20mm to 22mm brass ring adapter. A little solder added to the outer portion of the ring to make the 22mm ring fit tight in the 23mm driver hole. I will pick up a rubber washer gasket/ring to make the lens stay tight and not rattle.
But other than that it’s a great feeling light and bright. It does not zoom quick like most zoomies. The zoom is you turning it on threads. It’s a tad quirky to figure out at first, I will leave it at a midway zoom/flood. But it’s a solid feeling light. It’s much brighter than a similar Xhp-50 Zoomie I modded up.
It warms up a tad in seconds and stays that temp. I haven’t yet felt it get overly hot. Solid pill, plastic lens.
