Here's the newest lights and best Black Friday deals I've found on GearBest this week. All links are affiliate links.
The Convoy S2+ is down to $6.99 with the code taoWUI14. This model does not have the newest driver, but it's the lowest price I've seen. This price is also significantly lower than a new host direct from Convoy, if you want to build your own light.
The Convoy S2+ UV is also at a new low of $11.99 with the code OL6NKEEs
Add the item in your cart, open cart, click on the "proceed to checkout" button then enter the coupon code on the "use coupon " window (lower leftof the screen) and click "apply". You have to be loged in for that (unlike banggood where most coupons can be tested without being loged in)
You can enter only one code per order so if you have several item with different codes you have make one order for each code
