Enerpower 18650 3.2V 1800mAh (Blue)
Official specifications:
Chemistry: LiFePO4
Manufacturer: Heter
UL: MH48108
Nominal voltage: 3.2V
Discharge cut-off: 2.5V
End of charge voltage: 3.6V
Maximum charge current: 1.8A
Capacity: 1800mAh
Continuous load (in amperes): 3C (approx. 5.4A)
Internal resistance:<40m?
Pulse Load: 10A / 10 seconds
Weight: 42 grams
Dimensions: 18.20 mm diameter / 65.20 mm length
Protective circuit: NONE
Lifetime: 1500 full cycles (100% DoD), 3000 full cycles (80% DoD), 6000 full cycles (60% DoD)
This is a LiFePO4 cell in 18650 format, this means lower capacity, lower voltage, flat discharge curve and long lifetime.
The two cells are well matched, the maximum specified load is easily handled.
Conclusion
This is a good cell with high capacity for a LiFePO4 cell. The flat discharge curve can be very useful for some applications.
Notes and links
Compare to 18650 and other batteries
