I was very stubborn about not using 14500 cells.
69 posts / 0 new
264
264's picture
Last seen: 2 weeks 1 day ago
Currently I own four 18650 powered flashlight. Which are used but not much. I do have many AA/14500 powered flashlights that upto a month ago i just used Eneloop batteries in. My favorite type of flashlights now are 14500 powered ones. I was slow to accept 14500 batteries. So just for around the house work and short walks which type of lithium Ion powered flashlights are most favored? I vote for 14500 size cells.
Edited by: 264 on 11/30/2018 - 20:57
toddcshoe
toddcshoe's picture
Last seen: 4 hours 45 min ago
I like 14500 for short periods. I carry a Zebralight SC52w or a Ultratac A1 most of the time when I don’t need extended run times. I have several more but those two are my favorites.
"Everywhere I go, there I am"
Pete7874
Pete7874's picture
Last seen: 35 min 58 sec ago
For walks, I really like Nitecore TIP attached to my hat, just because how light it is.
For around the house and night light, usually some AA light is plenty… either utorch ut01 or ultratac A1. No need for 14500 cells as I typically run them on lowest mode anyway, sometimes medium.
DavidEF
DavidEF's picture
Last seen: 1 week 1 day ago
For me, cell size is incidental. I like flashlights of various sizes, and I’m not concerned about what size the cell is, as long as it is sufficient for the purpose. I’ve seen some 18650 lights that are smaller than some 14500 lights. so, cell size isn’t going to necessarily determine the maximum size of the light, even though it might help determine the minimum size. I like smaller lights for EDC, because I want to carry in my pocket or on a belt clip. I have a 10180 keychain light, a single AAA twisty, and a 18350 light with me right now. When I’m home, if I need to quickly grab a light and go outside, it could be a bit bigger, but not huge. A large pocket size, up to C8 size, is fine. Again, cell size isn’t even considered. If I’m going somewhere that has large open spaces, and especially if I want to show off, then a larger light with a nice big reflector and plenty of lumens will probably go with me.
- The YKK Philosophy
moderator007
moderator007's picture
Last seen: 8 hours 52 min ago
I prefer 14500 or 16340 lights, lighter and smaller to carry around daily. Usually EDC a V11R but if its snowing or going somewhere that I feel my life could depend on the light (hoping it never does) I grab the Zebra SC600w for the longer run times and dependability.
I like a light that will run on a AA but when you can have 3 times the lumens using a 14500 in the same light, that’s what I load it with. Smile
I been using the 14500 since the days of the Akoray K-106, modded of coarse.
SIGShooter
SIGShooter's picture
Last seen: 9 hours 49 min ago
I’m still stubbornly only use NiMh in lights that take both. The reason is that I’ve had lights where using a 14500 in it damaged the driver so that the output on NiMh was very poor (essentially moonlight level). Is this still something to be concerned about or is it a thing of the past?
Thanks
9mm/40cal/45cal bullets and large/small pistol primers available for sale in San Francisco Bay area
264
264's picture
[quote=SIGShooter]I’m still stubbornly only use NiMh in lights that take both. The reason is that I’ve had lights where using a 14500 in it damaged the driver so that the output on NiMh was very poor (essentially moonlight level). Is this still something to be concerned about or is it a thing of the past?
Thanks[/quote
Having the 14500 battery destroy the driver was and still is one of my concerns.
teacher
teacher's picture
Last seen: 6 months 3 weeks ago
I like 14500 lights too. In fact I got a Wuben E05 the other day & I am amazed with it. It has quickly become one of my favorite lights.
264
264's picture
Has anyone have a name brand expensive AA/14500 flashlight only start to work correctly with 14500 batteries ? Only moonlight mode with regular AA or eneloop batteries?
Thanks All.
toddcshoe
toddcshoe's picture
264 wrote:
Has anyone have a name brand expensive AA/14500 flashlight only start to work correctly with 14500 batteries ? Only moonlight mode with regular AA or eneloop batteries? Thanks All.
No, can’t say as I have. I don’t have everyone ever made but, I have about 20 from most of the more popular and budget friendly makers. If it says they take both I have tried both in them and haven’t had any problems. I use mainly 14500’s and only use NiMh in lights that don’t lose much output on NiMh. I like the new Wuben E05 as well, the only thing you lose with NiMh is it’s turbo mode. I like the Ultratac A1’s mode spacing on NiMh too.
Speadge
Speadge's picture
Last seen: 2 days 16 hours ago
I am also 14500 fan and I prefer them above 18650. Why? Because of mobility.
I can put small 14500 flashlight into jacket pocket and simply forget about it untill I need it. It’s not exactly as small as 10440, but still … smaller and lighter than standard 18650 flashlight while there’s still more than decent output – modern 14500 flashlights reach between 500 – 800lm on max. It’s not like I need anything more than that realisticly.
Another advantage as some above already stated is also that those flaslights can use also standard alkaline AA batteries available in every store.
I try to limit my flaslights to only (10180)/10440/14500/18650/26650 format because I prefer to have all flashlights available and functional long term, while there’s simply too many battery formats to take care of, replace and keep in good condition over years to come.
I am aware that I am missing some great flashlights because of that, but on the other side … how many od them we, as flashaholics with hundreds flashlights, have in regular use at all?
264
264's picture
I like the Wuben E05 also but I think they should have used an OP reflector instead of a smooth one.
264
264's picture
I agree that 18650 size flashlights are just too big to carry around (EDC). That is why I like AA/14500 single cell lights. Triple A size is even better but such short run times make them unfeasible in most situations needing light for more than a couple of minutes.
264
264's picture
moderator007 wrote:
I prefer 14500 or 16340 lights, lighter and smaller to carry around daily. Usually EDC a V11R but if its snowing or going somewhere that I feel my life could depend on the light (hoping it never does) I grab the Zebra SC600w for the longer run times and dependability. I like a light that will run on a AA but when you can have 3 times the lumens using a 14500 in the same light, that’s what I load it with. Smile I been using the 14500 since the days of the Akoray K-106, modded of coarse.
Zebra brand lights are nice. Just too expensive for me.
toddcshoe
toddcshoe's picture
Amen. A OP for sure we need. Smile
264
264's picture
Those Nitecore lights look so sophisticated and high tech. Tup/Tip/Tini/Thumb/Tube.
264
264's picture
Wish I noticed the UltraTac A1 when it was $12.00 each.
raccoon city
raccoon city's picture
Last seen: 2 min 59 sec ago
I have a Tube and a Tip.
The Tube isn't very durable, but I love the Tip and it seems much more durable.
264
264's picture
I tried some DC-Fix film on the lens of the E05. Just made the beam look worse. That film usually works wonders.
mmalive
Last seen: 11 months 5 days ago
Sooo True teacher. Love mine. Will never leave collection.
Any related note 14500 much better for run times than any AA. Not knocking AA but prefer 14500 as primary and AA NiCad as backup.
NO ALKALEAKS!!! unless out of options.
MascaratumB
MascaratumB's picture
Last seen: 23 min 1 sec ago
Agree!! Even after putting a Luxeon on it, there are some “rings” on the beam that would be only eliminated by a diffuser or a reflector mod!
Despite this, it is a very good flashlight and is still very useful on AA batteries (even without turbo)!! Thumbs Up
[REVIEWS] ACEBEAM: H20 / TK16 /// AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 /// BLITZWOLF: BW-ET1 /// BRINYTE: T28 /// DQG: AA Slim Ti /// FIREFLIES: ROT66 GEN II /// HC-LIGHTS: SS AAA /// KLARUS: XT1C /// LIVARNOLUX: 314791 /// LUMINTOP: Tool AA V2.0 + Tool 25 /// NITEFOX: UT20 / ES10K / K3 /// ODEPRO: KL52 / B108 /// OLIGHT: M2R Warrior /// ON THE ROAD: M1 / i3 / M3 Pro /// ROVYVON: A2 + A5R / E300S / A8 /// SKILHUNT: M150 /// SOFIRN: SF14 + SP10A / SP32A / SP10B /// WUBEN: TO10R / E05 / T70 / E10 / TO50R / E19 /// XTAR: PB2 Charger ///
Tricks: 1 / 2 / 3 / 4 / 5 / 6 / 7 / 8 /// TIR Lenses: 1 / 2/// Others: Biscotti 3 + 1*7135 / Triple TIR w/ XP-G2 ///// My Collection ///// My Review's Blog (PT)
OL Contest 2019
GIVEAWAY: 1 / 2
MascaratumB
Hum, have you tried a different type of diffuser? I tried a piece of a “frosted” diffuser once sent by Boaz and the beam improved greatly! No greens or other shifts! Loses throw, but gains quality!
OL Contest 2019
GIVEAWAY: 1 / 2
Pete7874
Pete7874's picture
It was closer to $10 at one point. I got two of them. It’s a very simple, 3-mode, great little light with no blinkies. No nasty greenish tint either. Mode spacing is a little weird on Li-Ion, from what I’ve read, but on NiMH it’s fantastic.
Boaz
Boaz's picture
Last seen: 6 min 13 sec ago
Couple of lights I’d like to try A1 and the wuben 05 ... just keep missing the deals .
  I think 14500’s have their place but sort of default to the nimh . 14500’s usually kill the moon modes and don’t have very much runtime.
Otoh .... some lights are just begging for more horsepower so I recently added another 6 cells to my colle tion of 14500’s but I find I don’t normally reach for them .
 Been wearing a lumintop tool on my collar for years now and recently find I’m grabbing the Boruit 11$  EHL0628 Super best budget headlamp with the headband 100% loose over my head / around my neck .
Couchmaster
Last seen: 21 hours 43 min ago
For me, when I just want to run out to the back yard and spotlight a skunk or head to the park to walk the dog, the little Nitecore MH20GT (18650) is my fav. It’s light, small, easy to turn on or bump the brightness, and the distance I get is both needed and sweet.
DB Custom
DB Custom's picture
Last seen: 2 hours 50 min ago
The Thorfire TK05 is really nice as a 14500, but I carry an 18500 quad daily, never without it. When I discovered the Samsung LH351D in 80 CRI at 5000K I updated this quad from XP-L HI under a Khatod optic to the Sammy under a Carclo optic, with a very pleasant result of a Beam profile that is essentially one large hot spot. This light comes in handy on a regular basis, with Bistro allowing 7 levels and reversing function so its easy to stay in ultra low levels when required. With a Turbo over 3200 lumens and a moon around 1/3 of a lumen I’m always ready for whatever presents. The 18500 cell with 1000mAh capacity allows that extra bit of run time as well as power.
Of course, the 10440 Texas Poker is always around my neck waiting to be needed. Wink In spite of it’s rather dimunitive size it can still put out over 700 lumens and makes a good showing of itself. Big Smile I have a spare 10440 in a custom Ti carrier on my key-chain should it be required.
Also have the super tiny DQG Spy on my keychain, just in case…
The newly announced GT micro has my eye… will def be getting this new 14500 asap to add to my arsenal.
A quick pic of part of my EDC, these 3 are with me always… regardless of what else I may carry…
DB Custom
DB Custom's picture
FWIW, the Texas Poker is only off the chain when I bathe, it’s with me all other times, even sleeping. Has been for over 5 1/2 years.
(ok, the Dr’s made me take it off when they cut my throat, but it went back around my neck asap afterwards)
Speadge
Speadge's picture
Hey, is this beautiful knife here just to looks nice on picture or you actually carry around $500 knife as an EDC beater? Smile
(I am sorry for being offtopic, but urge to ask is too strong)
Gebe
Last seen: 7 hours 42 min ago
Totally agree! Just got mine and it’s a winner. Tiny and powerful and so well built.
DavidEF
DavidEF's picture
Everything in that pic is part of his EDC.
nick779
nick779's picture
Last seen: 2 days 17 hours ago
Yep I’m now favoring 14500 lights now too for every day tasks. 18650 is overkill in terms of runtime and host size. The wuben E05 is growing on me immensely
