Component stripped from driver.. Klarus Mi1C
38 posts / 0 new
Jerommel
Jerommel's picture
Last seen: 1 month 6 days ago
Hey, i was gonna do a LED and optic swap on my Klarus Mi1C, and i decided to take out the driver too (to have a look).
So i unscrewed the plastic driver retainer disc, and i stripped off a part…
Can you spot the empty space?
This is what came off.
The capacitor next to it also came off, but i could solder it back on.
The thingy that came off lost its 3 legs in the accident…
The legs were still on the PCB..
It says “SAOH” or “SA0H”.
It’s probably a transistor, maybe a FET.
It’s only 2.7mm wide.
I need a replacement.
2Q19
Edited by: Jerommel on 12/06/2018 - 11:58
Lexel
Lexel's picture
Last seen: 11 hours 46 min ago
would help to see what it is connected to on both sides
most likely FET but could be also a voltage regulator
n-fet you can usually easily pick drain and one of the gate resistors connected to ground
same with p-fet but to battery +
could be also a transistor in the feedback loop
sot23 is 2.9mm wide
DavidEF
DavidEF's picture
Last seen: 6 hours 56 min ago
There are what looks like capacitors connected – one on each side – to the pads of this mystery part. The “top” leg and the “bottom left” leg of the part are connected to opposing ends of the (capacitor?) on the left, and the “bottom right” leg is connected to the (capacitor?) on the right, the opposing side of which is connected to the spring pad. The “bottom left” leg trace also seems to go to the ground ring and some other components.
Reason is not automatic. Those who deny it cannot be conquered by it. Do not count on them. Leave them alone.
-Ayn Rand
Lexel
Lexel's picture
yes for a FET the gate on ground makes not really sense
Agro
Last seen: 11 hours 21 min ago
I killed my Mi1C the same way. Sad
Jerommel
Jerommel's picture
So you need the same part?
2Q19
Jerommel
Jerommel's picture
But this light takes the battery in reverse position.
So the spring is the minus and the body is plus.
2Q19
Jerommel
Jerommel's picture
The through holes on the other side are under the inductor.
So i can’t see where it goes.
I will upload a picture of the other side.
2Q19
Agro
While unscrewing I stripped a capacitor and almost stripped one more part. I think the same as you did, but maybe the 5-legged one. Will check later. The legs got much longer than normal, but I didn’t see any discontinuity.
I soldered the capacitor back, moved the almost-stripped component back to place, the driver was dead.
kikkoman
Last seen: 44 min 43 sec ago
Seiko / Ablic S-1206 is a match for SAOx: a 2.5V LDO.
Bottom left pin = ground would fit too.
https://www.ablic.com/en/doc/datasheet/voltage_regulator/S1206_E.pdf
Jerommel
Jerommel's picture
Okay, i took some pics.
I removed the inductor to show the through holes from the ‘mystery component’.
Apparently the through holes go nowhere.
Very strange.
And another pic from the spring side:
I made blue what tests as continuous, but it’s strange if they’re really the same, because otherwise they could have bridged it right from the minus spring. (Again, the spring is minus, battery goes in bottom first).
2Q19
Jerommel
Jerommel's picture
Okay, now we’re getting somewhere.
Thanks! Thumbs Up
what does LDO mean and what does it do?
EDIT: I see it’s a Voltage Regulator.
2Q19
Flashy Mike
Flashy Mike's picture
Last seen: 5 hours 23 min ago
Low-dropout_regulator
This board might have more than 2 layers so the through holes could have a purpose.
Jerommel
Jerommel's picture
Yeah, that crossed my mind too, but i can’t see a hint of another layer..
But it would make sense.
2Q19
Jerommel
Jerommel's picture
2Q19
kikkoman
Jerommel wrote:
Is this the same?
https://www.ebay.com/itm/10pcs-Original-XC6206P252MR-SOT-23-2-5V-Low-Dro...
or
https://www.ebay.com/itm/10-PCS-XC6206P252MR-SOT-23-XC6206P252-XC6206-Po...
If not, can someone help me find one?
Those should work but you should make sure it’s indeed an LDO: Vin (pin 1, top) should be connected to the battery plus; the output (pin 3) probably connects to pin 1 of the µC (a PIC12F1840).
If that’s the case, it’s pretty much confirmed it’s an LDO.
I’d try and get a replacement somewhere that doesn’t take a month to ship though.
e.g. https://www.conrad.nl/p/microchip-technology-mcp1700t-2502ett-pmic-volta...
or maybe you have a local shop.
PS: I think Arrow has free shipping right now, might be the fastest & cheapest option of all
Jerommel
Jerommel's picture
Hmmm… The other 3 legged component “D19HJ” is connected pin 1 to plus and pin 2 (left) to minus.
Pin 1 of the “SAOH” is not connected to plus.
(see next posts)
wait, i’ll do some testing, be right back.
2Q19
kikkoman
Oh, there’s some confusion here.
The S-1206 datasheet has pin 1 on top, but common SOT-23 nomenclature has it at bottom left:
Jerommel
Jerommel's picture
Uhm… so.. pin 1 (bottom left) of “SAOH” is connected to minus.
So it’s not a positive LDO, correct?
2Q19
kikkoman
Jerommel wrote:
Uhm… so.. pin 1 (bottom left) of “SAOH” is connected to minus. So it’s not a positive LDO, correct?
No, that’s the same as ground, so B+ and LDO output are above that. (=positive LDO)
But make sure pin 3 (top, as in the diagram above) is connected to the battery +.
Jerommel
Jerommel's picture
Pin 3 (top) is not (directly) connected to plus. No ‘beep’ on de DMM.
It’s very hard to follow the traces with my DMM, the probe pins are too big and blunt and i suspect it is indeed more than 2 layers PCB, because visually many traces stop at a through hole.
Is it possible that the plus gets switched by the µC, so that it only works when the light is on?
Could the “SAOH” have something to do with the ramping between modes perhaps?
Or maybe with switching from linear to boost (because it’s also quite bright with a CR123A)?
I really don’t know… Tired
2Q19
Jerommel
Jerommel's picture
By the way, Conrad is expensive and also charges shipping, making 1 of those LDO’s twice as expensive as 10 pcs from ebay…
I could fill my cart with € 30.— of stuff and get free shipping, but everything is expensive…
I saw a Cree XM-L2 for € 18.— for example…
Carclo triple optics are quite cheap though at 1.76 (or something).
So, kikkoman, should i just order from ebay and hope it’s what i need, pray and solder it on?
Or do you think i could ask Klarus for info?
Dang… This was not a cheap light..
2Q19
Jerommel
Jerommel's picture
Where did you get this information?
2Q19
Agro
I checked: in my case the damage is done to 31VGp….I tried searching for that code but nothing comes out. Any idea what would that be?
kikkoman
I think I searched at LCSC (they have a nice little picture of the actual part) for SOT-23 LDOs and one with a matching marking came up (SAxx), then had a look at the datasheet.
http://chip.tomsk.ru/chip/chipdoc.nsf/vc1!readform&view=smd&cat=A&start=1&count=500 is also very useful, it’s the most comprehensive list on the net as far as I can tell.
You should also check against the bottom right pin of D19HJ (which I suspect is for polarity protection, maybe a p-FET).
Quote:
Is it possible that the plus gets switched by the µC, so that it only works when the light is on? Could the “SAOH” have something to do with the ramping between modes perhaps? Or maybe with switching from linear to boost (because it’s also quite bright with a CR123A)?
Since it’s an e-switch driver the µC needs to be constantly powered and that’s usually done with an LDO. Which would also explain the 2 decoupling caps to GND.
But yes it _might _be something else like a voltage supervisor that’s why we need to figure out where its input & output go.
The TPS63020 is a buck/boost converter that switches between modes automatically.
kikkoman
Is this a true CC (no PWM) light? If yes, then I suspect it’s an op amp. The number of discrete passives around it also point to “opamp”.
Unfortunately there’s 2 different pinout variants that most opamps in these packages follow:
One way to tell: desolder the sense resistor and check which pin has a resistance of a a few 10kR (or zero) to LED- ; that’s IN+
(no guarantees, but most CC drivers use the opamp in the same way it seems)
Agro
Thanks kikkoman, will check the next time I pick up the iron. Smile
kikkoman
By the way, Jerommel, have you tried reattaching the part with some flux and big fat solder blobs? Looks like there’s still some of the pins left that it just might work. Maybe dig a little into the package with an x-acto knife to expose the lead some more
Jerommel
Jerommel's picture
Unfortunately one leg (pin 2) was torn out of the component, leaving a hole there…
2Q19
Jerommel
Jerommel's picture
I sent an email to Klarus with a picture of the driver and the broken component.
I hope they can help me..
2Q19
Jerommel
Jerommel's picture
Hey, i found another pic of the part here on BLF:
(in this topic: http://budgetlightforum.com/node/58832 )
“SAOF” in stead of “SAOH”
2Q19
