(Cancelled)D1S+, CSLNM1.TG LED, 850lm, 320kcd
351 posts / 0 new
ZozzV6
ZozzV6's picture
Last seen: 29 min 2 sec ago
with this osram led you can make a tube light with one led that out throws D1 with XP-L HI.
FBsLights
Last seen: 1 month 1 day ago
I“m interested in a LED, driver, and centering ring “upgrade” kit.
I really like my Emisars, but think the throw difference from the D1 to the D1S should be greater.
This would fix that!
FB
Agro
Last seen: 3 hours 3 min ago
Hey Hank, I really like how you jump on the latest greatest thrower LED. It can really make your products so much better than what you’ve shown is a good example.
But please let me join others with the question:
Is the driver going to be regulated?
Many of BLFers are savvy enough to use only weak cells with FET+white flate combo. But we’re an exception….you could artificially increase resistance in your host, but that would be a hack rather than a solution.
ZozzV6 wrote:
Tried this led with D1. It simply doesn’t have good enough reflector. It top half and bottom half has a little different focal point whith doesn’t matter with larger led like XP-L HI. I played with focusing for hours.
It can’t get any better than this.
!{width:70%}http://img2.indafoto.hu/3/9/134029_e227dae7eadb61c0adb17748b381f0a8/2611...!
Thanks a lot for the info.
I wanted to do the same to mine.
GT Mini, D1…some good lights that turn out to have too poor reflectors for that LED.
And actually both have been my white flat candidates. :/
DB Custom wrote:
Ok, you got me. I want, cause I like, a lot.
I have a D1S with the Titanium 18650 tube from the Ti D4, the D1S is black with the Ti tube, love it. Can you perhaps offer us a clear anodized D1S with the White Flat? Basically don’t bead blast it after machining and don’t put it in a dye bath, just straight from the machines and into the ano, then seal it. Could you do that? I’d (and many other’s I’m sure) absolutely love a clear machined finish D1S! Most especially if it could have the square blocky knurling of the Titanium D4 18650 tube… Oh Yeah! Big Smile
It may not be so simple….
That’s how thickly anodized undyed alu looks like:
https://www.oveready.com/flashlight/torchlab-triple-v5-e-scout-head-7075...
That’s a different alloy and different thickness, but how thin would ano have to be to produce practically no colour change?
Eraursls1984
Last seen: 2 hours 45 min ago
Hanks has said a few times that it would be limited to 5 amps. Hank, if you haven’t already put this info in the OP, that may help out.
adam7027
Last seen: 11 hours 11 min ago
Definitely interested!
I guess (or I hope), it could be even used as a star pointing beam for astronomers (backup for the banned green lasers).
mustig
mustig's picture
Last seen: 2 months 1 day ago
Absolutely getting it if made a reality!
4Null
Last seen: 3 days 22 hours ago
Already have a D1S but two is one and one is none. Definitely interested.
ToyKeeper
ToyKeeper's picture
Last seen: 4 hours 20 min ago
We’ll find out when he’s ready to tell everyone. He doesn’t like to reveal things very far in advance.
specialk
Last seen: 2 weeks 4 days ago
Interested
R10500
Last seen: 1 week 1 day ago
any specs regarding lumens?
rvr
Last seen: 1 month 1 week ago
Its in the titel of this thread: 850lm
iosala
Last seen: 2 hours 50 min ago
Verry interested!
DB Custom
DB Custom's picture
Last seen: 40 min 28 sec ago
Agro, I have lights that this is successfully done on… wouldn’t have asked if it weren’t possible. Heck, I’ve done it to parts myself. Wink
Muto
Last seen: 1 hour 20 min ago
interested
After the Apocalypse there will be only 2 things left alive Cockroaches and Keith Richards
Agro
Good to know.
I believe we asked several manufacturers to do that already and nobody agreed. Sad
Any idea why is it so?
Lfatman
Lfatman's picture
Last seen: 23 min 50 sec ago
Interested.
lawallac
lawallac's picture
Last seen: 2 hours 11 min ago
I’ll get one for sure.
scr79423
Last seen: 23 hours 11 min ago
Hank Wang wrote:
ZozzV6 wrote:
Jerommel wrote:
I would have expected a better reflector in your Emisar though.
I doesn’t blame them. It designed for XP-L HI and it is perfectly good tor that. Maybe the big corona what show something isn’t perfect But 48 kcd still very good for this size.
Yes, the D1 reflector is designed for the XP-L HI, which does not produce good beam with the CSLNM1.TG upon testing, the D1S reflector produces good beam with the CSLNM1.TG LED.
Vinh from skylumen tested the CSLNM1.TG LED in the D4S and got 3,000 lumen with 126,000cd @turn on, please use this LED in your D4S!
DB Custom
DB Custom's picture
Agro, a lot of the industry doesn’t like change, they’re used to hiding imperfections behind sandblasting. To take the parts straight from the CNC to the ano bath will show the machine marks from the tooling and while some of us like that the industry is afraid it will be seen as ugly or unfinished by the consumer market at large. So on the few occasions we have had success it has been in limited runs. I’m ok with that, a serial numbered limited run of 100, or 300, would be great. If they saw a quick sell out then they might be interested in taking it further, maybe a second run of 500 or 1000, who knows…
Tom E
Tom E's picture
Last seen: 45 min 29 sec ago
Very much interested as well, but also interested in exactly how the 5 amps restriction is implemented. Regulated would give you 5 amps pretty exactly, but using a FET, you can restrict it to 5A max based on the best fully charged cell with adding the right amount of resistance - very different solutions.
bmg50
Interest intensifies!
Kafuzke
Kafuzke's picture
Last seen: 3 months 6 days ago
I am interessted for a whole flashlight.
Greetings from Germany
xCentrino
xCentrino's picture
Most definitely purchasing one. Can’t have enough mini throwers to lend out, Maybe I’ll keep this one for self and lend the D1s more.
will34
will34's picture
Last seen: 18 hours 2 min ago
I would get both D1S and D4S with this new emitter but only if you make a 21700 version.
Brainsick67
Brainsick67's picture
Last seen: 6 days 18 hours ago
INTERESTED
Kaf23211
Last seen: 3 months 15 hours ago
Interested
Niko
How this gasket work?
Is not close to led.
And same for xp-l and white flat?????
full-beam
Interested!
Thanks Hank
Kalpn
Last seen: 6 hours 39 min ago
Interested
BobbyMK
BobbyMK's picture
Last seen: 9 hours 33 min ago
Ill take one.
 Olight i3s, Olight S1, Olight S Mini, JetBeam Jet-1, BLF 348, Astrolux S41S, UF SK-98, Convoy S2+ 3*XP-G2, Convoy S2+ 3*XPL, Convoy S2+ 219CT, Convoy M1, Convoy C8, Brinyte B158, Courui D01, Convoy L6, Noctigon M43
