Can anyone help me ID a blown diode?
5 posts / 0 new
Zelda
Zelda's picture
Last seen: 5 days 20 hours ago
I connected a high power (16.5A@12V) blade server fan with wrong polarity to a power supply.
The motor driver replied quickly with smoke...innocent
Diode
The diode cracked. I searched with the keywords "ON Semi 949GEE" but I could not find any Information.
Size is about: 8 x 6 x 2.4mm.
Maybe someone can tell me a common diode as replacement.
Thank You!
XXX-Man
XXX-Man's picture
Last seen: 10 min 56 sec ago
By marking on PCB it is Zener diode.
Only diode with 949 marking I could find from ON Semiconductor was 1SMB5949BT3G
https://www.digikey.co.uk/en/datasheets/on-semiconductor/on-semiconducto...
Not sure if this helps…
"With the first link, the chain is forged. The first speech censured...the first thought forbidden...the first freedom denied – chains us all, irrevocably."
My reviews:
Sofirn SF36 /// Thorfire VG10S /// Sofirn C8F /// Zanflare F1
Zelda
Zelda's picture
I can't imagine that is a 100v Zener Diode. I have a second working PCB, is there a (non-destructive) way to measure the working Zener Diode?
Kame Sennin
Kame Sennin's picture
Last seen: 1 day 1 hour ago
This is a 1SMC12AT3  = 12V 1500W unidirectional transient voltage supressor
The 949 code is the date code (YWW) while the GEE is the actual component code.
Datasheet
Zelda
Zelda's picture
Thumbs Up Thank you everyone!
