Review Nitecore NTP30 "Titanium Bolt Action Tactical Pen"
8 posts / 0 new
roma58
roma58's picture
Last seen: 1 day 8 hours ago
NITECORE NTP30
The Nitecore NTP30 was sent to me directly by Nitecore for the review.
For the technical characteristics of the product: https://flashlight.nitecore.com/product/ntp30
For purchase:
https://www.nitecorestore.com/NITECORE-NTP30-Bolt-Action-Tactical-Pen-p/...
Immagine
The Nitecore NTP30 Titanium Alloy Tactical Pen is a tactical pen made of Titanium TC4 alloy, CNC machined (computer numerical control), characterized by an excellent lightness, excellent resistance to impacts and corrosion.
The Nitecore NTP30 is designed for self-defense, emergency escape and daily writing. It is equipped with the new "bolt-to-retractor" system, a tungsten steel tapered tip and a high-quality water-resistant German gel refill.
Specifications:
Name: NTP30 Titanium Bolt Action Tactical Pen
Usage: Self Defense, Tactical Use, Glass Breakage, Daily Writing
Pen material: TC4 titanium alloy
Tip material: Tungsten steel
Length: 13.3cm (5.2 ")
Diameter: 0.95cm (0.4 ")
Weight including the cartridge: 27g (0.95 oz)
Refill ballpoint pen: Schneider Gelion 39
The packaging:
Elegant the Nitecore NTP30 packaging that arrives in a semi-rigid black cardboard box. We see in the front the writing of the brand NITECORE, the name of the model NTP30 and the type of tactical pen TITANIUM ALLOY TACTICAL PEN. Then there is the design of the new NTP30.
Immagine
Inside we find the Nitecore NTP30 inserted inside a protective foam and above it a yellow card with the inscriptions that identify the main parts that distinguish the Nitecore NTP30.
Immagine
Immagine
The NTP30 is the latest tactical pen from Nitecore. It is made of TC4 titanium alloy and machined by CNC machine, thus obtaining a light product with an excellent resistance to impact and corrosion. It holds well in your hand and is not heavy.
Immagine
Immagine
The Nitecore NTP30 can be completely disassembled by unscrewing it. Even if I have not done so, you can also remove the bolt by unscrewing it.
Immagine
Immagine
The threads of the unscrewable parts are sliding and machined and finished in an impeccable manner.
Immagine
On the tactical pen we find two writings engraved on the Nitecore logo and the NTP30 model.
Immagine
Immagine
The internal ink cartridge for writing is of quality and is of German origin being the Schneider Gelion 39. The cartridge is resistant to water and fading as well as extreme temperatures. This cartridge allows a fluid and spotless writing even when traveling by car or plane. Although the NTP30 is compatible with other cartridges, the Gelion 39 can be found easily and at affordable prices.
Immagine
Immagine
The clip inserted in the Nitecore NTP30 is also made of titanium alloy. Being rigid, it allows an easy and safe hooking in your pocket or shirt, backpack etc.
Immagine
Like everything else, the clip can also be removed by unscrewing the two fixing torx screws.
N.B. Being the tip of the clip in contact with the body of the pen (above the writing Nitecore) you have to raise it slightly or remove it before unscrewing the body to access the selection system (pen / tip) to avoid scratching the body.
Immagine
Immagine
Immagine
The Nitecore NTP30 stands out from other products to be equipped with the exclusive bidirectional "Bolt-Action Retractor" bolt design system that allows you to quickly switch from the writing system to the self-defense system using the conical tip of which it is equipped.
Immagine
Immagine
Immagine
Immagine
Immagine
Immagine
Equipped with a stable locking system, it can be operated quickly in its L-shaped groove to choose whether to use the pen or use the tungsten steel tapered tip.
This tip has a high hardness measured from the Rockwell scale (89-92.5 HRA), which is positioned, as hardness, behind only that of the diamond. The tungsten steel, of which the tip is made, is notable for its strength as it can be used to cut the metal.
Immagine
Immagine
Immagine
Immagine
Immagine
Immagine
Nitecore NTP30 grips well and does not slip, thanks to the anti-slip design on the body that facilitates grip even in difficult situations.
Immagine
Immagine
Immagine
Nitecore NTP30 together with other pens:
Immagine
Photo and Video of Nitecore NTP30 Titanium Bolt Action Tactical Pen:
Immagine
Immagine
Immagine
Immagine
Immagine
Video:
CONCLUSIONS:
The Nitecore NTP30 "Titanium Bolt Action Tactical Pen" is a tactical pen built with quality materials like titanium and with a precise and imperfection-free processing. Beautiful to be seen writes well in all situations even in the most difficult. Holds well and can easily be stored in trousers, jacket, cases or backpacks.
This new model of Nitecore is equipped with a new bidirectional design selection system that allows, in a simple and fast way, to switch from writing to self-defense in case of danger (for example just in case we need to break a window).
Finally, the Schneider cartridge "Gelion 39 Ballpoint Pen Refill" of which the NTP30 is equipped allows you to write accurately and without smearing even in situations different from those to which we are accustomed.
In conclusion I recommend the purchase of Nitecore NTP30 to those who need an instrument to always carry with them to write and, in case of need, for self-defense.
Thank you for reading the review.
klrman
klrman's picture
Last seen: 55 min 51 sec ago
Expensive for basically a pen with a metal point!
CRX
CRX's picture
Last seen: 14 min 28 sec ago
Was looking at these the other day, I have the NTP10. Interesting designs in titanium Thumbs Up
Wont be appreciated by many here though Wink
DB Custom
DB Custom's picture
Last seen: 2 hours 33 min ago
Appreciated by Moi! Wink
Jerommel
Jerommel's picture
Last seen: 1 week 7 hours ago
I prefer a forward clicky. Wink
2Q19
CRX
CRX's picture
I could only do a twisty switch on the NTP10 but a forward clicky could work on the NTP30 Smile
Nichia 219B
Jerommel
Jerommel's picture
^ Well, of course you did…
LOL
2Q19
MichielSanders
MichielSanders's picture
Last seen: 5 hours 54 min ago
For the price of the nitecore you could buy 6 of these
https://www.fasttech.com/p/9534803
I have it for over a month and i’m really happy with it.
It yust doesn’t have a retractable tungsten point.
Incandescent Lights: Maglite: 2D, 3D, 4D, 5D, 6D, Magcharger.
Led Lights: Maglite: Led AA - Klarus: RS11, RS20 - BLF: Q8, A6, GT, GT mini - Nitecore: TM26GT, SRT9, EC11, T5s, P05Pink, LA10, HC33, HC70 - Fenix: TK76, CL05, CL09 - Olight: M3XS-UT, S Mini CU Rose Gold, Marauder X6 - Petzl: PIXA 3 - Ledlenser: P4BM - Lumintop: Tool Ti - Astrolux: A01 Copper, Ti3a, MF01 - FourSevens: Maelstrom MMU-X3 - Convoy: S2+ Uv 365nm Nicha - Imalent: DX80, DN35, DN70 - Niwalker: Vostro BK-FA30S - Emisar: D1s
Signed up For: BLF: Ultimate lantern, TLF FW3A
