brightest AA/14500
37 posts / 0 new
vulcan
Last seen: 3 weeks 1 day ago
brightest AA/14500
Hey guys,could you plz tell me the brightest flashlight in AA/14500? Unlimited bugdet?
is there anything brighter than 1000 lm for 14500 or brighter than 500 (zebra lights) for normal AA ?
Adhara
Last seen: 5 hours 12 min ago
One of the kyfishguy’s, I suppose, at ~2800lm short-term…
Petr J.
Petr J.'s picture
Last seen: 1 month 14 hours ago
1xAA /14 500 UTORCH UT01
2xAA /14 500 Manker T02
4xAA / 14 500 Manker MK41
zak.wilson
Last seen: 1 day 19 hours ago
I don’t think anybody has made a brighter 1xAA than Zebralight. That’s well into the range of technically difficult boost drivers.
Highest output production 14500 is probably the BLF X5. It advertises 1400 lumens, but this post says it’s 1100. This light is bulky for the battery type though. If that’s your motivation, there are a few slim lights in the 700 lumen range like the Klarus Mi7 and Thrunite T10 II (yes, I know it says 550; it’s more).
Ceilingbounce – flashlight testing and runtime graphs for Android
samyy
Last seen: 20 hours 21 min ago
Zebra SC5 II is NOT brighter than 500lm. Ok ,on the paper 550lm, in reality about 430lm.
So the brightest single AA flashlight I know is Armytek Prime A1 PRO – 465 real lumens (warm tint version).
Brightest single14500 light is Wuben E05 – 900lm on the paper (some reviewers measured about 1000lm).
vulcan
Tnx very much,but i looking for mass product flashlights,not customs.
vulcan
!{width:70%}https://cdn3.bigcommerce.com/s-4buand9rva/product_images/uploaded_images...!
So,based on your opnion ut01 is the end game single aa/14500?
WalkIntoTheLight
Last seen: 8 hours 30 min ago
samyy wrote:
Zebra SC5 II is NOT brighter than 500lm. Ok ,on the paper 550lm, in reality about 430lm. So the brightest single AA flashlight I know is Armytek Prime A1 PRO – 465 real lumens (warm tint version).
My first version Zebralight SC5w measures 450 lumens. I think the newer SC5 II, especially in cool white, has to be over 500 lumens.
You’re claiming the Armytek Prime A1 Pro is 465 lumens? I have the A2 warm, and it measures 450 lumens. I don’t see how the 1xAA version could be 465, if the 2xAA version is only 450. Granted, mine is the XML2 version, and I think the newer XPL version is brighter, but I don’t believe Armytek has made as bright a 1xAA light as Zebralight.
Petr J.
Petr J.'s picture
I’ve forgotten Wuben E05 yet. Even better.
Measured parameters in one test.
tm07
tm07's picture
Last seen: 8 hours 17 min ago
Wuben E05 Thumbs Up
mmalive
Wuben E05 900 lumens 14500 battery powered.
HorizontalHunter
HorizontalHunter's picture
Last seen: 14 hours 10 min ago
I’m a fan of the Klarus Mi7. The max output listed is 700lm.
The only issue is that the switch protrudes from the body of the flashlight so it is prone to accidental turn on. If you are going to carry it in a pants pocket you need to lock it out.
The Mi7 turns on in high (quick press) or moonlight mode (long press)
Bob
Vegetarian: vejiˈte(ə)rēən/noun: old Indian word for lousy hunter.
wstrachan
Last seen: 8 hours 18 min ago
Utorch Ut01, Wuben EO5 and Fenix E25 come to mind right away. all are 800-1,000 lumen.
light addict....yeah I've got the bug.
Atrolux MF02_O2S
Imalent DT70
Emissar (All Models)
Lumintop ODL20C
Wuben A21 & T70
thrunite tn32 ut
acebeam k60
many, many others...
MascaratumB
MascaratumB's picture
Last seen: 4 hours 29 min ago
I don’t know if this will be considered a “custom” or a “production” flashlight (maybe the 1st, I guess), but is probably one of the brightest lights on 14500.
It is made by our fellow member vestureofblood, a.k.a. Matt, a.k.a. AdventureSportFlashlights!
“Everyday Carry Brass” – 1536 lumen (on XPL-HI V3-1B and using a high-drain 14500 battery)!
https://asflashlights.com/home/105-everyday-carry-brass-3x-xp-l-hi.html
It can also be seen here, on his channel!
BTW, the main reason why I mention this is due to the “Unlimited bugdet?” part in the OP Big Smile Cash
[REVIEWS] AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 /// SOFIRN: SF14 & SP10A / SP32A / SP10B /// NITEFOX: UT20 / ES10K / K3 /// ODEPRO: KL52 / B108 /// ACEBEAM: H20 /// BLITZWOLF: BW-ET1 /// DQG: AA Slim Ti /// HC-LIGHTS: SS AAA /// XTAR: PB2 Charger /// OLIGHT: M2R Warrior /// WUBEN: TO10R / E05 / T70 / E10 /// ON THE ROAD: M1 / i3 / M3 Pro /// ROVYVON: A2 & A5R / E300S / A8 /// KLARUS: XT1C /// LUMINTOP: Tool AA V2.0 & Tool 25
Tricks: 1 / 2 / 3 / 4 / 5 / 6 / 7 / 8 /// TIR Lenses:1 / 2 /// Others: Biscotti 3 & 1*7135 / Triple TIR & XP-G2 ///// My Collection ///// My Review's Blog (PT)
GIVEAWAY: 1
jerryg
Wuben E05 everyone that handles it says wow, no memory that is what I like about it, ready to blast out a lot of light.
jerryg
duvallite
Really like my Wuben E05. High power, small form factor, and magnetic tailcap. UT-01 is bright, small, and I like the UI, but the known switch problems and on/off problems using 14500s make buying one a risky proposition. Both of mine have the 14500 problem. Get the Wuben E05 Thumbs Up
chadvone
chadvone's picture
Last seen: 1 month 2 days ago
Armytek Prime Pro on a IMR cell is much brigher then a 2xAA.
On 4+year old Olight protected 14500 I am getting 485 lemons
Switch bodies and I can get 850+ on a Vapecell 18350
They go into direct drive or something close to it.
agent80
Last seen: 25 min 45 sec ago
Like my Klarus Mi7. Great mode spacing. Very bright on a 14500 and AA eneloop.
d_t_a
Last seen: 3 hours 6 min ago
Wuben E05 is very bright on Turbo (4 brightness levels when used with 14500). But when using AA, it has only 3 brightness levels, and its brightest level on AA is not so bright.
Lumintop Tool AA v2.0 lists 650 lumens on Turbo mode, but would seems to be a bit brighter than 650 lumens. The brightness spacing is more logically spaced than the Wuben E05 (on 14500, big gap from “High” mode to “Turbo” mode).
Lumintop EDC05 is another candidate, 800 lumens on Turbo (must program it first, since it’s set to 75% level from the factory).
Quote:
Lumintop EDC05
Factory Default: Level ② Output 75% Brightness
By default, the flashlight doesn’t come at its highest output from the factory. You can manually set it to the maximum lumen output by going into programming mode.
14500 Battery:
Stage ③ Output 100% Brightness:
High: 800 lumens Med: 320 lumens Low: 100 lumens Moonlight: 10 lumens
Stage ② Output 75% Brightness:
High: 600 lumens Med: 240 lumens Low: 75 lumens Moonlight: 5 lumens
Stage ① Output 50% Brightness:
High: 400 lumens Med: 160 lumens Low: 45 lumens Moonlight: 1.5 lumens
comparing Klarus Mi7 vs Lumintop Tool AA v2.0
Mi7 is the left beam while Tool AA v2.0 is the right beam
EDCba
Last seen: 5 hours 51 min ago
Nitecore had a 900-1000 lumen single 14500 – the EA11, but it’s discontinued. They also had another very similar one with slightly different UI – MT10A, also discontinued.
To me, there’s a distinct difference between the 500-700 lumen lights, and the 900+ lumen ones. Below 700 lumens the lights are using conventional ICR 14500, so most cells, including protected ones, work. The 900 lumen ones need high discharge IMR chemistry.
EDCba
Generally the 1xAA can use 14500, but 2xAA only take Ni-MH. So they end up very similar in output. See Olight S1A and S2A.
vulcan
This means 2*AA can not use 14500? Could you tell me the reason plz?
EDCba
I think not many drivers can handle up to 9 V. Fenix has one but lumens isn’t impressive. Another problem is safely discharging 14500 in series.
teacher
teacher's picture
Last seen: 2 hours 40 min ago
Another vote for the Wuben E05… I am really liking mine. Thumbs Up
wolfdog1226
wolfdog1226's picture
Last seen: 1 month 1 week ago
Impressive output ,,BUT who is willing to pay $219 for a AA light whose battery can NOT maintain that output for long! Not me!! I would take the Wuben E05 and then buy another modded EDC and still have enough money to buy a $65 bag of Merrick Buffalo and sweet Potato for CAPO!!! Thumbs Up
Solitude breeds contemplation which creates clarity.
Environment molds a person. Perseverance changes them.
        WOLFDOG
MascaratumB
Impressive output ,,BUT who is willing to pay $219 for a AA light whose battery can NOT maintain that output for long! Not me!! I would take the Wuben E05 and then buy another modded EDC!
Sure, I’m with you too Wink Still, in what concerns being “the brightest”, this surely reaches a place into the top ranking!! (I wish I could have it, though Big Smile Cash )
The more I know this flashlight world, the more I’m inclined to choose better runtime over more output! The Wuben E05 seems to be a very good one or the best in the budget range to be bright and have decent runtime on a 14500 cell!
I subscribe that one as well as a good choice!!! Wink
GIVEAWAY: 1
wolfdog1226
You are right,,,it qualifies for the brightest! Thumbs Up I was just looking at it from a practical point of view.
OT- I see you are from Portugal. I hope you bring me good luck!!!
I have a date at noon[6pm Roma time] w/ a woman whose blood is from Portugal but she was born in France. Her mom and dad moved there after her 2 siblings were born. She speaks French, Portuguese and of course English! She is Pretty and seems like a sweetheart,,,,,,I must be on my best behavior!
        WOLFDOG
teacher
teacher's picture
You want a bright 14500, get you one of these bad boys!!
They have practical use at lower power & a SUPER DUPER ‘W.O.W Factor’ when you open it up!!! Wink
http://budgetlightforum.com/node/65070
Kyfishguy Micro Mags
…“around 2800 lumens at start up and 2400 lumens at 30 seconds based on emitter testing by Texas Ace”…..
WalkIntoTheLight
Okay, I thought we were comparing apples to apples, not oranges.
AKAIK, the Zebralight SC5 is the brightest single AA light on the market, that uses a NiMH cell. Yes, there are plenty of 14500 lights that are brighter, possibly including the Armytek on a 14500.
chadvone
chadvone's picture
The Armyek Prime Pro 1AA is brighter then the Zebralight SC5.
zak.wilson
Advertised, or independently tested? Issues with the Prime’s optics are well documented by now, and I do not believe the advertised OTF output for any model.
