forget 2.5 minutes on 21000 Lumens not enough thermal mass
and for my liking the shallow LED shelf has been always the big weak point of this light,
even more with TA Overdriven LEDs
you know I had here lights with stripped threads on MCPCB mounting screw holes because the shelf is only 2mm thick
The TA driver has ramping so runtimes for modes is a pretty useless technical detail, sure you can configure the firmware to modes but who wants it?
I would always prefer Anduril with stepped ramping if you want a mode flashlight, sure it can be flashed
I’m pretty much just looking for a decent flood light around $120 CAD. Like if this or other lights that could sustain… Say 9000 lumens? More would be better obviously.
A friend of mine bought the Imalent dx80. It’s very impressive, but way too huge for what I would want in a light and even at it’s lower settings 5000, 9000, and 12000 lumens is very impressive. So I was just looking for something with a high turbo to find a more consistent mid range (5000-9000 lumens).
Astrolux MF01 may be not that floody but its also very nice to light up a lot of area
too bad the original driver is not that good and modding is a challange as its heavily glued
Do the math. 5000 lumens will require about 50 watts almost all of which ends up as heat. Same problem with MT09 with the TA driver. According to TA that thing could deliver 240 watts. While the Q30 is reasonably heavy, if you apply 50 watts, it will indeed get very warm very quickly. These things are actually quite remarkable for the raw amount of power they can pull from a modest sized battery pack.
Thank you very much for the information. I guess I was just looking for a smaller version of the Imalent dx80 but still “high” sustained lumens, but I guess that doesn’t really exist hah.
that’s the key, sustained… The Q8 does a good job…The MT09 does pretty good even after it steps down…
Look at an Emisar D4… Ton of light from a tiny package, until physics takes over…
The MF01 is a good flooder but it can sustain 9000lm for only about 2 min. Got mine for ~ 100$ CAD with a coupon and it is a very good light for the price. I also own a DX80 but I find the MF01 more practical due to its size.
You might also take a look at the BLF Q8. It was on flash sale tonight on Amazon.ca for 62$ CAD, prime eligible. Great deal for a great light.
