[Unboxing] LuminTop ZOOM1
33 posts / 0 new
steel_1024
steel_1024's picture
Last seen: 16 hours 10 min ago
[Google Translate]
This should be the first Zoom flashlight from LuminTop.
Through the push-pull of the convex lens of the barrel, the poly-and floodlight zoom effect is produced.
The zoom flashlight is very convenient for everyday use.
Can adjust the spotlight and floodlight according to your own needs.
Especially in the mechanical maintenance, there is considerable convenience.
LuminTop’s consistent environmental carton packaging
ZOOM1 (There may be ZOOM2 in the future?)
Double carton packaging
Open the inner box
Intimate thank you card
Boxed all items
Use the head to push and pull, no segment zoom
The head of the tube remains in the last state of flooding
The head of the tube is pushed to the front of the spotlight
The inside of the barrel is exposed ZOOM1 when it is opened.
Look good
After the head is pressed, the height should be almost the same.
One battery attached
It should look like a protected 2600mAh lithium battery
The (bunny) standby indicator light after the battery is installed can also be easily seen in the dark.
Off after power on
Provide Micro USB charging device (Well, not using USB3.0 specification?)
Large spring with tail cap, no magnet
Hand rope hole position, support flashlight stand
The instructions are in Chinese, English and Japanese.
The main feature, LED visual should be cool white
Instructions
instructions 2
Operation flow chart
Structure diagram
Specification Table
Green rabbit during standby
Tube pattern
Mark
ZOOM1
Charging current
Bright red rabbit when charging
Charging complete bright blue rabbit
The wall is about one meter away, and the spotlight
Floodlight
Outdoor spotlight
About the middle
Floodlight
Animation
Beautiful and practical zoom flashlight ZOOM1
thanks for watching
Sorry for my poor english.
Edited by: steel_1024 on 01/24/2019 - 09:50
djozz
djozz's picture
Last seen: 7 hours 25 min ago
Thanks for the review and pics.
Interesting, I had not seen this zoomie before. The short travel of the head indicates a nice short focal length lens. Is the lens AR-coated like the Jaxman Z1 ?
F.i.l.a.s
F.i.l.a.s's picture
Last seen: 1 day 7 hours ago
A promising host for White flat.
Agro
Agro's picture
Last seen: 26 min 32 sec ago
It’s a TIR lens, right?
Could you post a white wall pic of intermediate beam?
saypat
saypat's picture
Last seen: 3 days 6 hours ago
very nice. $41 @ Amazon
blueb8llz
Last seen: 22 hours 19 min ago
Thanks for the review. Very nice looking light. I don’t think it’s zoom 1. I think the 1 is a logo design to replicate a zoom type.
I wish they went with one click on and off. And hold to cycle modes instead.
And turbo to be in the mode sequence.
I’ll have to pass on this light because of the UI.
steel_1024
Confirmed, the name is Zoom1
Smile
hank
hank's picture
Last seen: 1 hour 58 min ago
Quote:
cool white
Too bad.
How easy does it look to modify by replacing the emitter?
steel_1024
Not easy
I will continue to try
steel_1024
Wait…
It is easy to disassemble
I will post photos……soon
Firelight2
Firelight2's picture
Last seen: 5 hours 22 min ago
From the pictures it looks like an LED Lenser style zooming TIR. However, the outer ring of the TIR appears to be frosted. So the spot beam has a lot of spill in it. Result should be a spot beam that looks like that from a Coast flashlight and not nearly as much throw as if both TIR elements were calibrated for throw.
noboneshotdog
Last seen: 3 hours 29 min ago
Dang! Your photography is exquisite!
Thier ain’t no bones in a hot dog. F. York
nkresho
nkresho's picture
Last seen: 2 days 15 hours ago
Got mine today via Amazon. Meh. Doesn’t zoom in and show the die as I expected. Kinda blurry soft hotspot. UI is not terrible imho.
I’m going to have to swap the emitter I think. Stuck with the driver since it has the charging and eswitch.
This was an impulse buy and I’m not all that thrilled with it.
If you’ve got the itch to grab a light, make sure you know what you’re getting into with this one.
Also verified the zoom 1 name. It’s printed on the label that way.
Brainsick67
Brainsick67's picture
Last seen: 2 months 4 days ago
I get min Tomm…im ok with the zoom in..but hows the zoom out? I hope its ok.
I'm ThatCrazyFlashaholic 67
nkresho
nkresho's picture
Out isn’t bad, but retains some of the squarish shape. It could stand to go a little further out and get more round.
Funny to say, but the cometa spoiled me. Although I do have a white flat and l4p driver in mine.
Took my Zoom1 apart tonight because it wasn’t all that happy the way it sits anyway.
Lumintop zoom1 teardown
Measured draw at the emitter too. Once I got the pill unscrewed from the head.
04a L
0.50a M
1.19a H
2.29a (double click turbo)
Used a UT210E directly on the emitter wire with a VTC5a installed fresh off the charger.
Might be able to drop a white flat right in.
Tom E
Tom E's picture
Last seen: 1 hour 30 min ago
Any updates on modding this light? Martin has a deal goin on this light now: https://m4dm4x.com/m4d-m4x-deals/
From the teardown above, looks like a driver replacement would be easy. Guess all depends on the optics and focusing.
teacher
teacher's picture
Thank you for the review Steel. Once again, your pictures are amazing!! Thumbs Up
Tom E
Tom E's picture
Ohh, yes - thanks Steel! Excellent pics!!
Agro
Agro's picture
I have to say that I really like what I see here:
  • 21700 cell, 40 mm head, not very long – nice format, must feel good in hand
  • e-switch
  • USB charging
  • push-pull action
  • probably – Lumintop’s good overall quality
Lumintop chose to use a partially frosted lens to smooth out the beam. Fair choice. I suppose it avoids the problems with a hole in the beam in intermediate zoom positions.
With the versatility that zoom1 offers it could easily become one of my most used lights.
There are several things that could make it better and most seem to be achievable with modding skills somewhat above mine. Wink
  • Lumintop, if you go for beam quality – how about adding high CRI options?
  • Narsil / Andruil would be awesome
  • XHP35 HI seems like a natural choice for this light with its better efficiency, better throw and easily double Turbo output ( GXB172 Smile ).
  • Type C….Lumintop offers it in several lights already and I wonder – why not this one?
  • How about adding a powerbank function?
With these changes….that would be nearly a dream light. Smile
nkresho
nkresho's picture
I dropped in a white flat. Had to sand the mcpcb a tiny bit. It was a 16mm, needed to be 15 or so to fit the cap that covers it. Super east mod other than the sanding. I used a Dremel with sanding wheel.
Kept the driver the same. Long press to off kinda sucks.
Meh, still. Hotspot, zoomed out, is still too big. Not nearly zoomed in enough to get a clear die shot. Needs another few mm of outward movement.
I got 16,314cd with the oslon. Didn’t bother with the stock emitter.
21700 will not fit out of the box, gotta buy their tube. Quality is good, just not happy with the short zoom distance.
Agro
Agro's picture
16 kcd with white flat and 40 mm head? That’s bad. Sad
I guess the host deserves further improvements on the Lumintop side….
nkresho
nkresho's picture
Here’s the zoom 1 with white flat ~20” diameter at 10’ 16kcd(max)
Zoomed all the way to the smallest beam
Here’s the cometa with white flat ~4” diameter at 10’ 334kcd(max)
and for reference, l2 with white flat ~5-6” diameter at 10’ 464kcd(max)
Tom E
Tom E's picture
Oh boy, definitely not a thrower, unless figuring out a way to extend the lens out more.
nkresho
nkresho's picture
Removing the optic and holding it further from the emitter yielded 59kcd with the zoom1. Beam pattern was nearly identical to the cometa in this configuration.
Lower current than the l4p drivers i’m using in the other lights.
This was very close to the optic being flush with the end of the head (bezel removed), and zoom fully extended outward. I don’t see a realistic way to mod it without a new head.
Tom E
Tom E's picture
Ok, it's a flooder with the ability to narrow and lengthen the flood zone smile
mrheosuper
Last seen: 1 week 3 hours ago
i wonder how many lumens lost at maximum zoom
Forgot my pen
Cereal_killer
Cereal_killer's picture
Last seen: 4 weeks 1 day ago
Atleast 50%, probably closer to 75%.
You don’t get a zoomie cause you care about lumens…
nkresho
nkresho's picture
From flood to zoom mine reads 440lm then 338lm. My sphere (spherical one) is baffled at both sides of the sensor.
About 77% of the value when zoomed in tight, so a 23% loss
edit: May be a bit low on both readings. Just put the battery back on the charger. Was at 3.84v for the readings I got above.
Firelight2
Depends on the type of zoom and how well done.
With an aspheric lens type zoomie, you can easily lose 50-75% of the total lumens when cycled to spot mode. This is because the light is emitted from the LED in a wide cone, and most of this cone hit the sides of the sliding bezel rather than the lens when the bezel is extended for spot mode.
With a zooming TIR mechanism like on an LED Lenser, the light loss when cycling from flood to spot can be as little as 0%. This is because in theory all parts of the LED’s emission cone are collected by the optic and directed out the front in both flood and spot positions.
However, not all LED Lenser type optics are created equal. I’ve seen some where there is no visible lumen loss in a ceiling bounce test. But I’ve seen others where significant lumens are still lost.
nkresho
nkresho's picture
I take it all back… 464 lumens at zoom out, followed by 388 focused tight. 83.6% or a reduction of 16.4% Battery hot off the charger in both instances.
Tom E
Tom E's picture
nkresho wrote:
I take it all back... 464 lumens at zoom out, followed by 388 focused tight. 83.6% or a reduction of 16.4% Battery hot off the charger in both instances.
Not much loss because it doesn't zoom fully - it's a zoom'n flooder.
