DIY RLT, takes 2 & 3
7 posts / 0 new
LouieAtienza
Last seen: 2 days 11 hours ago
So I thought I’d try these semi-hemispherical baking forms. I bought these a few months ago and shelved them. Then I came across an older thread here where someone tried to use them, but remarked how they couldn’t get the surface shiny, and the aluminum was pitted. Upon looking at these, and that thread, it seemed the OP didn’t realize he had to remove the anodized surface off before it can be polished effectively. I removed the later with 320 silicon carbide paper. It’s important not to start too coarse or you’ll leave scratches that will be hard to remove, and only visible when your doing the later polishing. I progressed to 500, 1000, and 2000 Mirka Abralon pad, and finish sanded with 3000 and 5000 3M Trizact pads. I build guitars so I try to get as good a surface as I can after shooting my clear coat, which I use automotive paints.
It’s also important to pre-soak these abrasives, and wet-sand. Breathing the dust from the anodized surface is not good, and it can wreck havoc on the ways or screws of a mill or lathe – so you probably don’t want to sand these near machinery. But once you get through the anodized layer, the aluminum underneath is pretty soft, and sands and polishes beautifully and easily. I used automotive polishing compounds, then metal polishing cloths to enhance the surface.
https://photos.app.goo.gl/jBeVZrhHhs3hUQZ76
https://photos.app.goo.gl/BTPiu5P1MsWkZHLcA
https://photos.app.goo.gl/db3wSot5MJTzSX1BA
https://photos.app.goo.gl/ezxwyrpL7J4hqdYC8
LouieAtienza
There is a slight haze on the surfaces that is a residue from the polishing cloth. This gets removed with dishwashing soap and hot water. Not 100% perfect, but 95% cheaper than the real deal…
Pöbel
Pöbel's picture
Last seen: 8 hours 47 min ago
very nice. But will these be precise enough to focus the emitter properly? I guess you will show us soon Smile
LouieAtienza
Thanks… and with the LED on low mode, yes. The question is whether or not when I step up the juice, how much stray light doesn’t make it onto the LED and illuminates other things inside the assembly – which may or may not look good. I did a spotlight build with one I made from a steel door knob, but the door knob had a small dent. I didn’t think much of it but that dent acts like a tiny lens and illuminates the whole chip – enough that at 40ft I can read the writing on the MCPCB and almost read the s/n on the White Flat!
Barkuti
Barkuti's picture
Last seen: 4 min 52 sec ago
LouieAtienza wrote:
… I did a spotlight build with one I made from a steel door knob, but the door knob had a small dent. I didn't think much of it but that dent acts like a tiny lens and illuminates the whole chip - enough that at 40ft I can read the writing on the MCPCB and almost read the s/n on the White Flat!
Cool! Just ask the implied parties some subliminal advertising royalties. Big Smile
Party
DavidEF
DavidEF's picture
Last seen: 4 days 4 hours ago
Looking forward to seeing your results (beam shots).
- The YKK Philosophy
LouieAtienza
Thanks…. Me too!
