LumenMax's Banggood Deal: Lumintop Tool AA ($16) and Lumintop Ant Bass/SS ($28.02/$28.77)
12 posts / 0 new
LumenMax
LumenMax's picture
Last seen: 14 min 26 sec ago
Lumintop Tool AA 2.0 127m EDC 14500 Flashlight Portable Dimming Torch Camping Tent Light Reading Lamp
Price: $22.23 (Must select CN warehouse)
Price with Coupon: $16
Coupon Code: BGXUO
Lumintop Ant Stainless Steel/Brass XP-G2 R5 120LM EDC Mini LED Flashlight - Brass
Price: $37.36 (Brass) | $38.36 (Stainless Steel)
Price with Coupon: $28.02 (Brass) $28.77 (Stainless Steel)
Coupon Code: CFNKL
Edited by: LumenMax on 04/18/2019 - 13:52
LumenMax
LumenMax's picture
Nitecore LA10 XP-G2 S3 4Modes Magnetic Tail Maintenance Light Flexible Camping EDC LED Flashlight Work Light
(Preorder) Exp:2019-03-31
https://www.banggood.com/Nitecore-LA10-XP-G2-S3-4Modes-Magnetic-Tail-Maintenance-Light-Flexible-Camping-EDC-LED-Flashlight-Work-Light-p-1076585.html?p=R4240016492493201711&custlinkid=171439
Coupon Code:LA1010
Normal price: $24.95
Coupon Price: $16.99 (the lowest price)
Exp:2019-03-31
LumenMax
LumenMax's picture
Affiliate LInk: https://www.banggood.com/LUMINTOP-GT-MICRO-1000lm-Flashlight-14500-Battery-EDC-LED-Flashlight-Hunting-Camping-Work-Lamp-Emergency-Lantern-p-1432824.html?p=R4240016492493201711&custlinkid=182304
Price breakdown:
  • Order Subtotal: US$39.99
  • Coupon Code:BGTMO
  • Coupon Discount: US$9.04
  • Grand Total:US$30.95
Processing time: Expected on March 17, 2019
Specification:
Brand LUMINTOP
Type natural white
cool white
Flux 1000 lm
Throw 400 m & ~50Kcd
Battery 14500 battery (can't work with AA battery) (not include)
Driver Texas avenger FET driver
Reflector 29 mm ID, aluminum, smooth finish
Lens Glass with anti-reflective coating
Body Aluminum with Type III hard-coat anodizing
Button Tactile with back-lit rubber boot
Waterproof Equivalent to IP65, do not immerse in liquids
Dimensions 36 x 105mm / 1.42 x 4.13inch
Weight 70g
Features:
[1] By default the GT micro is set to use the very intuitive Narsil smooth RAMPING UI. Instant access to a 2.5A TURBO mode is also provided.
[2] A more conventional discrete level MODE-SET UI is available as an alternative. Any one of 12 pre-defined mode-sets can be selected.
[3] MOMENTARY mode is useful for signaling purposes or rapidly/briefly lighting up targets.
Package include:
1 x Flashlight
Note: not include battery
LumenMax
LumenMax's picture
Affiliate Link (https://www.banggood.com/JETBEAM-RRT01-950LM-CR123A-Flashlight-IPX8-LED-Lamp-Camping-Hunting-Work-Lantern-p-1429674.html?p=R4240016492493201711&custlinkid=170630)
Thank you in advance for clicking on this link!
  • Order Subtotal: US$83.03
  • Coupon Discount: US$24.03
  • Grand Total:US$53.99
  • Use Coupon: FINKJ
This light has a magnetic control ring and uses either a 16340 or 18350 battery. You can dim it down to the point that you have to be in complete darkness in order to see the light 8-) It is quickly becoming my favorite EDC!
The 16340 battery that comes with it has a built-in micro USB charger.  It also comes with a Allan wrench, two extra clip screws and an extra o-ring.
Specifications:
Brand JETBEAM
Material Aluminum
Mode Highlight - low light - SOS - strobe
Brightness 950 lumens
Waterproof IPX8
Features:
The body of this flashlight is built of high quality aluminum alloy, and it has a very solid construction
-Internal wiring applies the high efficient booster circuit, and can utilize the batteries in the largest extent.
-Excellent waterproof, suitable for outdoor environment, adverse weather conditions except for diving
-Focus function that allow the beam can be focused.
Package included:
1 x Flashlight
1 x Hand strap
1 x Clip
1 x Battery
2 x Waterproof ring
Edited by: LumenMax on 03/12/2019 - 20:54
LumenMax
LumenMax's picture
LumenMax
LumenMax's picture
Convoy M2 XP-L HI LED 7135*8 Driver Tactical Flashlight 3000K/4000K/5000/6500K Smooth Reflector 18650 Battery Portable Torch - 6500K
https://www.banggood.com/Convoy-M2-XP-L-HI-LED-71358-Driver-Tactical-Flashlight-3000K4000K50006500K-Smooth-Reflector-18650-Battery-Portable-Torch-p-1429014.html?p=R4240016492493201711&custlinkid=190402
Order Subtotal: US$32.02
Coupon Code: BGCM2
Coupon Discount: US$5.03
Grand Total:US$26.99
Specification:
Emitter Type: XPL HI with copper DTP plate
Color Temperature:
6500K white tint
5000K neutral white tint
4000K neutral white tint
3000K warm white tint
Driver: 7135*8 with biscotti firmware
Battery Configurations: 1x 18650 lithium battery(Not included)
Lens: Glass
Material: Aluminum alloy
Reverse Protection: Yes
Low Voltage Warning: Yes
Mode Memory: Yes
Tailstand: Yes
Color: Black
Weight: 110g
Size: (Head x Body x Tail x Lengh):31.6mm x 25.8mm x 27.5mm x 135.2mm
Flashlight protection function explanation:
(1)Low voltage protection function: when the voltage of battery is 2.9-3.1V,the flashlight flashes 2times/sec with low brightness,it's a low voltage alarm.
(2)Battery reverse protection:if your battery is reversed,dont worry ,no any problem will happen.
LumenMax
LumenMax's picture
Convoy S2+ Nichia 219C 4000K 5700K 7135*4 1400mAh Driver 12 Groups Mode 18650 LED Flashlight - 4000k
https://www.banggood.com/Convoy-S2-Nichia-219C-4000K-5700K-71354-1400mAh-Driver-12-Groups-Mode-18650-LED-Flashlight-Smooth-Reflector-18650-Battery-Portable-Torch-p-1429013.html?p=R4240016492493201711&custlinkid=190419
Order Subtotal: US$20.64
Coupon code: BGC219C
Coupon Discount: US$3.65
Grand Total:US$16.99
Specification:
Emitter Type: SST20 high CRI 95 with DTP copper plate
Color Temperature:
5700K Cool White
4000K Neutral White
Driver:
7135*4 biscotti firmware: output current 1400mA
Lens: Ar-coated Glass
Mode Memory: Yes
Tailstand: Yes
Color: Black
Weight: 76g
Size: (Height x Width):118mm x 24.1mm
LumenMax
LumenMax's picture
BLF X5 XPL-HI 1400LM EDC LED Flashlight 14500
Coupon: BGX5
Coupon Price: $17.50
Tailcap lights up.
Specification:
Product name: BLF X5 XPL HI LED Flashlight
Brand: BLF
Model: X5
Emitter Type: XPL-HI
Circuit Driver: ATTiny25V-based driver with off-time capacitor
and FET+7135 power channel configuration.
Light Tint: 1A (6500K),3B(5300K)
Material: Constructed from aero grade aluminum alloy
Mode:
1 -- 1400 lm
2 -- 5, 1400
3 -- 5, 293, 1400
4 -- 5, 135, 543, 1400
5 -- 5, 79, 293, 688, 1400
6 -- 5, 54, 178, 419, 813, 1400
7 -- 5, 47, 135, 293, 543, 858, 1400
8 -- 5, 35, 99, 213, 365, 613, 953, 1400
Battery Configurations: 1 x 14500 battery (not included)
Working voltage: 2.8-4.35v
Switch Type: clicky
Switch Location: tail of the flashlight(Lighted tailcap by pilotdog68)
Impact Resistant 1 meter
Lens: Toughened ultra-clear mineral glass
Reflector: Smooth reflector
Carrying Strap: included
Waterproof: IPX-8 waterproof 2 meters
Color: silver
Weight: 236g without battery
Size: 105mm x 28mm(length x body diameter)
Package included:
1 x BLF X5 XPL-HI 1400LM LED Flashlight
1 x Deep Carry Pocket Clip
1 x Gift Box
1 x Extra o-rings
1 x Extra button cap
1 x flashlight landyard
More information about the flashlight from BLF forum : http://budgetlightforum.com/node/40642
About the modes click: flashlight-firmware
LumenMax
LumenMax's picture
NITECORE TM10K 6x XHP35 HD Tiny Monster 10000 Lumen LCD Display Burst Rechargeable Flashlight
Affiliate link: https://www.banggood.com/NITECORE-TM10K-6x-XHP35-HD-Tiny-Monster-10000-Lumen-LCD-Display-Burst-Rechargeable-Flashlight-p-1352258.html?p=R4240016492493201711&custlinkid=195287
Order Subtotal: US$301.02
Coupon Code: 6ab60b
Coupon Discount: US$101.02
Grand Total:US$200
Specification:
Product name: NITECORE TM10K Tiny Monster 10000 Lumen LCD Display Burst Rechargeable Flashlight
Brand: NITECORE
Model: TM10K
Emitter Type: 6x XHP35 HD
Max Output: 10000 lumens
Range: 315 yards
Mode: Turbo, High, Mid, Low, Ultralow
Lumens: Turbo: 10,000 lumens
High: 400-2000 lumens
Mid: 300 lumens
Low: 100 lumens
Ultralow: 3 lumens
Runtime: High: 2 hr
Mid: 7 hr
Low: 14 hr
Ultralow: 200 hr
Battery Configurations: 4800mAh li-ion battery (Built-in)
Switch Type: Clicky
Switch Location: Body side of the flashlight
Impact Resistant 1 meters
Waterproof: IP68 - 2m submersible
Color: Black
Weight: 8.7oz
Size: 4.33" x 1.61" x 1.22" (L x W x H)
Features:
Intensely bright 10,000 lumen burst mode.
Max beam intensity of 20,000cd and a max throw of 315 yards.
Maximum runtime up to 200 hours.
Compact, palm-size body for easy carrying.
OLED display reports output, temperature, battery status, and more.
Quick Charge 2.0 USB Type-C charging and 4800mAh built-in li-ion battery.
Package included:
1 x NITECORE TM10K flashlight
1 x USB Type-C charging cable
1 x Holster
1 x Lanyard
1 x Instruction Manual
1 x Warranty Card
LumenMax
LumenMax's picture
Xiaomi Yeelight YLFW01YL 6.5W Rechargeable Dimmable LED Night Light Bluetooth Control Table Lamp
https://www.banggood.com/Original-Xiaomi-Yeelight-5W-Rechargeable-Dimmable-LED-Candle-Night-Light-Bluetooth-Control-p-1175326.html?p=R4240016492493201711&custlinkid=160577
4.98 out of 5 See all 55 reviews
Order Subtotal: US$35.89
Coupon Code: candleled
Coupon Discount: US$0.90
Grand Total:US$34.99
Description:
What is Candela?
Candela is the world's only smart candlelight using the latest Bluetooth (BLE) Mesh technology, combining the warm comfort of candlelight with the convenience and control of smart technology. The BLE Mesh technology allows up to 30,000 units candelas to communicate with each other.
Specifications:
Brand: Yeelight (Xiaomi ecological chain)
Voltage:5V
Power: 6.5W
Power Supply: USB
Lumens:0.3-13lm
Light Color: Warm White(1800k)
Control Range: 20m
Battery Type: 2100mAh
Size; 72*195mm
Features:
Brown copper candlelight simulation
Minimalist design, rotation control, IoT smart device
Simply rotate a Candela to control all connected candelas
Control your Candela and other Yeelight smart lights with Android or iOS apps.
The built-in 2100mAh battery allows for up to 8 hours of continuous use on a single charge.
Candela fits perfectly in any bar or restaurant or any scenes.
Package Included:
1 x Yeelight YLFW01YL Night Lamp
LumenMax
LumenMax's picture
https://www.banggood.com/BLF-Q8-4x-XP-L-5000LM-Professional-Multiple-Operation-Procedure-Super-Bright-LED-Flashlight-p-1194351.html?p=R4240016492493201711&custlinkid=129648
  • Order Subtotal: US$79.95
  • Coupon Discount: US$34.96
  • Grand Total:US$44.99
  • Code: BGQ8
    Expired On: 2019/05/31
BLF Q8 4x XP-L 5000LM Professional Multiple Operation Procedure Super Bright LED Flashlight
4.99 out of 5
407 Reviews
Specification:
Product name: BLF Q8 4X XP-L 5000LM Professional Super Bright LED Flashlight
Brand: BLF
Model: Q8
Emitter Type: XP-L HD  V6 3D
Light temperature: 4750K-5000K
Light color: Neutral White
Mode: Smooth ramping or mode set operation
Material: Aerospace grade aluminum alloy construction
Total Emitters: 4x
Battery Configurations: 4 x 18650 or unprotected button top (not included)
Working Voltage: 3-4.2v
Switch Type: Electronic switch
Peak Beam Intensity: 50,000+ cd
Impact Resistant 1.2meters
Max Output: 5000+ lumens
Range: 450+ meters (max)
Lens: High transmittance glass
Reflector: Aluminum alloy mirror reflective cup
Color: Black
Weight: 400g without battery
Size: 132mm x 59mm x 50mm(length x head x body diameter)
Features:
• Compact and lightweight 5000 Lumens flashlight
• Utilizes four XP-L LEDs
• Uses four 18650 batteries for maximum runtime up to 1500hours
• Features advanced temperature regulation (ATR) technology
• Integrated power indicator in side switch indicates remaining battery power
• Flashlight can blink out voltage with 0.1V accuracy
• Intelligent memory function for brightness levels
• Direct access to ultralow and turbo outputs
• High transmittance glass
• Stainless steel bezel ring protects core components from damage
• Constructed from aerospace grade aluminum alloy
• HAIII military grade hard-anodized
• Waterproof in accordance with IPX-8
• Tail stand capability
Mode,Lumens and runtime:
Mode Groups: Runtime and Lumens (manufacturer tested,it will be a little bit different from the real data )
Group1: Moon 2LM/1500h Turbo
5000LM/40min
Group2: Moon 2LM/1500h Low 160LM/33h Turbo
5000LM/40min
Group3: Moon 2LM/1500h Low 70LM/66h Mid 1250LM/8h Turbo
5000LM/40min
Group4: Moon 2LM/1500h Ultralow 10LM/150h Low 160LM/33h Mid 1500LM/6h Turbo
5000LM40min
Group5: Moon 2LM/1500h Ultralow 10LM/150h Low1 70LM/66h Low2 160LM/33h Mid 1500LM/6h Turbo
5000LM/40min
Group6: Moon 2LM/1500h Ultralow 5LM/150h Low 70LM/33h Mid1 240LM/17h Mid2 1100LM/10h High 2500LM/3h Turbo
5000LM/40min
Group7: Moon 2LM/1500h Ultralow1 10LM/400h Ultralow2 35LM/140h Ultralow3 95LM/54h Low1 160LM/33h Mid 1350LM/8h High 2500LM/3h Turbo 5000LM40min
Group8: Moon 2LM/1500h Low 160LM/33h Mid 750LM/17h High
2100LM/5h
Group9: Moon 2LM/1500h Ultralow 10LM/150h Mid 520LM/20h Turbo
5000LM/40min
Group10: Moon 2LM/1500h Ultralow 10LM/150h Mid 1500LM/6h Turbo
5000LM/40min
Group11: Moon 2LM/1500h Low 160LM/33h Mid 1350LM/8h Turbo
5000LM/40min
Group12: Moon 2LM/1500h Ultralow 5LM/600h Low 150LM/33h Mid 1700LM/5.5h Turbo
5000LM/40min
Package included:
1 x BLF Q8 4X XP-L 5000LM Professional Super Bright LED Flashlight
2 x Flashlight Body Tube O-ring
1 x Flashlight Head Lens O-ring
1 x Switch cover
1 x English Manual
Note:
Before ordering please make sure that you know how to operate the flashlight.
How to use the UI: bit.ly/narsilinfo
For the safety to the battery: bit.ly/lionsafety
For more information to see: bit.ly/blfq8
Product review from BLF Forum:http://budgetlightforum.com/node/45915
LumenMax
LumenMax's picture
Sofirn SP70 is a powerful outdoor flashlight designed for outdoor activities like camping, hiking, fishing or hunting. It can be operated with two 26650 or 18650 (with sleeves) Lithium-ion rechargeable batteries. Tail switch powers on / off, side switch controls two mode groups: Group 1 with 6 brightness levels and Group 2 with ramping capability.
  • Order Subtotal: US$61.59
  • Coupon Code: BGSP70 (expires 2019/4/26)
  • Coupon Discount: US$11.59
  • Grand Total:US$50.00
https://www.banggood.com/Sofirn-SP70-XHP70_2-With-ATR-2-Groups-7Modes-55...
Specification:
XHP70.2 LED with a lifespan of 50,000 hours
Working Voltage: 5.6 V - 8.4 V
Battery Options: Two 26650 or 18650 Li-ion batteries
Dimension: 250mm (length)× 90mm (head diameter)
Weight: 625 grams (without batteries)
 Flashlight body: 6061 aluminum alloy, CNC manufactured to Military Grade Specification type III hard-anodized anti-abrasive finish to get solid built body, anti-crash geometry.
Toughened mineral glass lens
The waterproof level: in accordance with IP68
Reverse polarity protection from improper battery installation
Mode Memory:Last mode remembered - it memorizes the last brightness level used in the general modes (except Beacon)
Advanced Temperature Regulation (ATR) technology: ATR will adjust the brightness level automatically when the driver temperature reaches 60°C (140 °F) to prevent overheating
Automatic Stepdown: Turbo mode steps down to High mode after 3 minutes of operation to prevent overheating. High mode steps down after 30 minutes of illuminating.
Power Indicator: Turn on the light, the side indicator shows the battery power for 5 seconds. Green is good enough power, orange is half power, red is short of power, flashing red is power running out, please replace or recharge batteries ASAP. In Standby Status, the indicator is Green as locator in the dark.
Operation Instruction:
Half press the tail switch for momentary-on. Fully press tail switch to power on or cut off. When the light is on, the side switch controls all flashlight functions as follows:
Group 1: 6 modes (default group)
Click and hold the side switch to cycle through brightness levels: Eco-Low-Mid-High, release when you find the level you need.
Double-click to activate Turbo mode, one click to return last brightness.
Click to Standby, the main LED turns off but side indicator is green as locator in the dark. Click to turn on the main LED again
In Standby Status
Click and hold to Moon, click goes back to Standby
Four fast clicks to active the lock-out, the main LED blinks twice, the indicator LED turns off. When in lock-out status, only four fast clicks will reactive the light, all other operations only get two blinks
Six fast clicks change from Group 1 to Group 2 or the other way around
Eight fast clicks to active Beacon which light up 0.1s in every 2 seconds
Group 2: Ramping
Click and hold side switch to ramp up or down. Ramping changes direction when the button is being clicked and held again within 1.5 seconds; same direction when ramping again after 1.5 seconds.
The light blinks once time when it reaches Moon or Turbo mode.
Click to go to Standby, another click turns on the light.
Package included:
1 x
flashlight
1 x strap
1 x replace rubber cap for side switch
2 x replace Orings
2 x key rings
2 xbattery adapter
QQ20190327170803
