Which solder paste for LED reflow?
25 posts / 0 new
Muto
Last seen: 3 hours 45 min ago
Got a hot air gun today and would like to reflow some emitters
Is this a decent choice for something available on Amazon?
https://www.amazon.com/dp/B017RSZFQQ/ref=sspa_dk_detail_1?psc=1
It has lead (probably not much content), is that the better choice over the lead free?
All advice is appreciated.
Thanks!
Keith
After the Apocalypse there will be only 2 things left alive Cockroaches and Keith Richards
Friends don’t let friends use ATT/DirectTV
I used her, she used me
But neither one cared
We were gettin’ our share
“Bob Seger”
Lexel
Lexel's picture
Last seen: 44 min 52 sec ago
I would not buy lead free paste unless its low temperature BiSn
this paste has not even marked which compond it is so I would not buy it
sn62pb36ag2 is still the best leaded solder compond
lead free SN98 or 96 paste has a too high melting temperature
if you use hot air then on a bigger piece of Aluminum or copper asbuffer so it heats up and cools down steady and slow
and heat aypplied from below, not from above!
RobertB
RobertB's picture
Last seen: 1 day 11 hours ago
I use this stuff. Seems to work great
Enderman
Enderman's picture
Last seen: 6 days 22 min ago
MGchemicals
KawiBoy1428
KawiBoy1428's picture
Last seen: 1 min 26 sec ago
Tried them all, I liked MG Chemicals, but went back to Kester EP256 63/37. I buy from CML Supply it seems to be fresher because they sell a crap load on Amazon/FleaBay and in my experience it flows a bit better/faster/cleaner with a hot air/reflow station and last longer, IMHO, it was $17.99 free shipping 3 days to the door, usually.
https://www.cmlsupply.com/kester-ep256-lead-solder-paste-63-37-syringe-d...
KB1428 “Live Life WOT
Lexel
Lexel's picture
also the grain of the paste matters if you want solder very small stuff
Type 5 is smallest paste
amars7
Last seen: 4 days 9 hours ago
Like the others I usually use the MGChem stuff. I have also used a lower temp Sn/Bi paste called Maker Paste, it seems to work fine as well.
clemence
clemence's picture
Last seen: 1 min 7 sec ago
SnBi based solder paste has very BAAAAD thermal properties and very brittle. EDIT: I only use it for [wire pads] on hard to solder MCPCB, mixed with approximately 30% Sn60Pb40 to make it slightly flexible. Never use it for LED or anything requires good thermal conductivity.
AFAIK, Sn52Bi48 only has 19W/MK TC. For comparison: copper ~400W/MK, Aluminum ~200W/MK, Brass ~100W/MK, Stainless steel ~16W/MK, Sn63Pb37 51W/MK, SAC307 62W/MK.
[Clemence]
amars7
I figured that might be the case, I originally got it because it was the only thing available.
clemence
clemence's picture
Useful information:
http://budgetlightforum.com/node/51628
[Clemence]
BlueSwordM
BlueSwordM's picture
Last seen: 3 min 14 sec ago
@Muto, do not use SnBi thermal paste for anything other than soldering springs.
It does not work well for LEDs and connections at all.
amars7
Awesome info, thanks!
clemence
clemence's picture
Except mixed. I mixed it with ~30% Sn60/Pb40. But don’t forget to heat it first to temp slightly above 60/40 melting point. Otherwise the 60/40 granules will stays unmixed. You still get around 150C combined melting point
[Clemence]
moderator007
moderator007's picture
Last seen: 7 min 27 sec ago
I use this stuff https://www.digikey.com/product-detail/en/chip-quik-inc/SMD291AX50T3/SMD...
Works really well for me.
All the resistor’s plus cap’s (size 0402) and other components are reflowed with the Chipquik and a hot air.
I use this same stuff for all my led reflows too, I haven’t found a need to try anything else, if it’s not broken why fix it.
I agree 100%. I haven’t found anything better. The added silver also helps improve conductance.
WillyD
Last seen: 4 days 7 hours ago
I know Micro Center has locations in PA, so if you have one near I’d suggest checking out their soldering supplies. I used to order everything after Radio Shack went away until I finally realized Micro Center has just about everything you’ll ever need.
JasonWW
JasonWW's picture
Last seen: 3 hours 28 min ago
I don’t even use solder paste. I use the same solder that I use with my iron, Kester 44.
I clean the old solder off the pad then add flux and solder with my iron. Then more flux and put the led on top and heat the mcpcb up again.
The thing about pastes is they go bad over time and then don’t work well. I’d rather have the reliable spool and do the extra step. Just my opinion.
staticx57
Last seen: 1 hour 55 min ago
How do you reflow? If you are using hot air for a PCB or hot plate for MCPCB paste is really helpful. I have been using the same cheap syringes of paste for a few years now without issues.
JasonWW
JasonWW's picture
Hot air.
A lot of pastes technically expire like 6-9 months after date of manufacture. I rarely reflow stuff, so that paste just goes to waste with me. I’m also not real comfortable using it after the expire date. It’s probably okay, but eh.
mattjk
mattjk's picture
You can revive expired paste by mixing some IPA in. Its just the carrier fluid for the flux that evaporates
Muto
You guys rock.
Ordered the MG
Figured there would be plenty of choices and just like when I first visited here, I have no clue what a lot of the terms used in the above posts mean and don’t need to know just need what works all around best for an amateur hobbyist and it looks like this stuff will do well.
Thanks again
Keith
“Bob Seger”
DB Custom
DB Custom's picture
Last seen: 26 min 33 sec ago
Kester EP256, nothing else. To me the MG Chemicals sucks.Kester EP256
nsl18
Last seen: 1 week 2 hours ago
[Clemence]
The thickness of alloy is very small to have a significant effect on final heat dissipation. An more narrowed space- the p-n junction to thermal pad. You was compare the junction themperature with different alloy, with infrared thermometr?
clemence
clemence's picture
[Clemence]
It is significant. 50W/MK vs 86W/MK TC made huge difference in output. Haven’t tested 19W/MK vs 50W/MK but I suspect the difference would be much greater.
[Clemence]
Chatika vas Paus
Last seen: 36 min 6 sec ago
Someone used this? Good for leds?
clemence
clemence's picture
It’s works good but not my favourite. Keep it in cool in an air tight container, gets dry fast when left open overnight. I prefer higher oily flux content. Get the syringe container for longer shelf life.
[Clemence]
