I took a closer look at the datasheets of similar models, in white.
PQ2A and PQ2N (yes, the latter is just the same family as UV mentioned in the first post).
The are very few CCTs to choose from (usually 2-3 per variant) but CRI goes from unrated to 9590. That’s not the minimum CRI that Nichia uses but the typical one. They are available with and without domes.
Output beats E17A for the same CRI and it should be possible to use Virence boards
Availability could be better, I see only one distributor (TME) having them and only 2 variants.
