I messed up this thread. Don’t know how to delete it sorry. Charger recommendations for orbtronic protected 14500 batteries? SV2 Rocket goes back to 1amp after short power outages.
If you want something small and inexpensive, the Xtar XP1 Hummingbird is a single bay USB multi-chem charger that does 250mA and 500mA rates. It only accepts AA/14500 sizes, or smaller, however, but is inexpensive and small in size.
Thanks Chris I will keep that in mind along with those chargers Teacher suggested.
I appreciate all the help from everyone. I just cant figure out whats going on with my Miboxer C4-12 charger which im sure there is already a thread about somewhere.
There are also two from Litokalla—their 100 and 202 single and dual bay USB true multi-chem/multi-voltage chargers that do fit the 18650 cells (I have two of each.)
They are both under $8, like the Xtar and work well in my experience.
I have the Rocket SV2 by Xtar and it works great, also HKJ said it was a great or very good charger for a simple charger IIRC. Just a little more bulky than the 100 and 202 it looks like but idk for sure.
Thanks again Chris. Just might order me 1 of those just to have an extra laying around for my walks and bike rides
Hurricane Irma in ’17 right after Harvey in Houston.
Yes, about 3-4 years ago, smaller folding USB panels started to hit the market. Some are so-so, some are pretty good, like the Anker PowerPort 21w. These things never deliver near the amperage that they advertise and then if they get close, it’s under laboratory conditions.
Still, they have their place and aren’t too spendy. I have a 12vdc 60w rigid setup to charge up 12vdc mother batteries, which I then use to power 12vdc fans and battery chargers, so that system works well. I also have the SKD 14w jobbie, which is easier to move out of my condo for charging up power banks and what not.
I’m not a prepper, but I try and have stuff on hand when the power goes out and it was out for 84 hours during Irma!
A lot of this stuff is not expensive and works well in a pinch, even if it doesn’t all last 30 years.
The Xtar XP1 no longer shows up on Xtar’s official site, but the XP4 Panzer does.
You can find them out and about.
The Opus is a pulse charger on NiMH, but does a decent job. The only issue on my 3400, is that I can only discharge four NiMH at a max rate of 700mA per slot, but 1A for li-ions.
