How to make a "lightbox" ?
16 posts / 0 new
juhi81
Last seen: 8 years 4 months ago
Hi guys!
I ordered a Digital Lux Meter from DX for my future measurements. It has arrived today to my post office and now would be a good
time to build a "lightbox" as mentioned here (BLF) in many occasions.  It seems that a simple cardboard box would be a good start ?
I would like to see your solutions for it (pictures)
Don, i know that you have one. Could you make "a mini review" for it  ? Smile
Current flashlights: Mrlite KC-05  -  Ultrafire C3  -  Ultrafire C3 Stainless Steel  -  Romisen MXDL RC-G2  -  AKOray K-106  -  Fenix LD10 R4  -  X2000  -  Trustfire WF-502B MC-E&nbs
old4570
Last seen: 3 weeks 20 hours ago
I use a ATX Power supply box [ Computer power supply ] ..
I cut a slot at the bottom [ middle ] and cut a hole , on the opposite side , top .
The light meter is a very tight fit [ keep out light ] as you want 0 reading ...
I take a minimum reading as its more accurate than say a maximum reading ... [ flashlight ]
You just need to do what ever you do the same time every time .. [ set your own procedures ]
 Always remember , the easiest thing in the world to do , is to expel hot air from your lungs and through some vocal chords ..
The resulting sound may , or may not be worth listening too ….
agenthex
agenthex's picture
Last seen: 6 years 4 months ago
edit: I posted my lazy solution. It probably isn't that great. You should probably find something unique and not just something I thought up in a minute.
Reading this makes you smarter: http://lesswrong.com/
juhi81
Finished my lightbox:
Its not pretty but it will do the job. Now i'm ready to make my first review.
juhi81
Its made from cardboard box. Inner and outside are covered with aluminium foil and paper. Its pretty "light tight".
Don
Don's picture
Last seen: 2 years 11 months ago
My box look rather like yours. I used a bit of translucent plastic cut from a milk container to act as a diffuser and to prevent dirt from getting in the top hole.
I put in a barrier in the middle so that no light can go directly from the torch to the meter, it has to bounce around a bit first. Think of it like the letter "T". this hangs from the top of the box.My meter's sensor is held in place with the extremely high tech approach of duct tape. I have put cardboard flaps over the input and meter ports to keep light and dirt out.
The numbers from my light tests are always to be found here.
https://spreadsheets.google.com/ccc?key=0ApkFM37n_QnRdDU5MDNzOURjYllmZHI...
agenthex
agenthex's picture
aluminium foil
Usually an integrating sphere is covered on the inside w/ diffuse material, or the exact opposite of reflective.
juhi81
Yes, that's why i use paper to cover the foil. The box isn't reflective inside.
The foil is for make to box "light tight" so that outside light sources won't interfere.
old4570
All you need to do is work out the light output on several of your lights :  [ Driver efficiency ] vF cF , type of emitter , and your good to go after some math ...
agenthex
agenthex's picture
That's a pretty good idea, but be sure to crinkle it up first to reduce directionality.
If you have a laser, you can use it to test the effectiveness of your contraption as well as troubleshoot consistency. Readings shouldn't change with it pointed to different angles at the input.
Oldienea
Oldienea's picture
Last seen: 4 years 10 months ago
I like the way you explain it. ROFL
juhi81
I made a quick run trough for my lights.
Here are the results:
Brand and ModelBattery typeSwitch on LUX
Mrlite KC-051xAAA208
Ultrafire C31x1450803
Ultrafire C3 SS1x1450535
AKOray K-1061x1450610
Fenix LD10 R41xNiMH534
X20001x18650750
Trustfire SSC P7 C-BIN1x186501240
Ultrafire WF-502B MC-E1x186501614
UltraFire WF-1300L3x186505005
There are few suprises in the results:
- Ultrafire C3 with black anodising is brighter than its stainless steel version
- Trustfire P7 seems to be somehow broken becouse my new WF-502B MC-E beats it easily.
  The reading is from first second at the start and it starts to drop significantly. After 10 sec its only about 900 lux.
- I always thought that WF-1300L is bright and it truly is, up to 3x brighter than WF-502B MC-E
The Romisen MXDL-RC-G2 is missing because its in my car and i'm lazy today...
I'll do a better version of the table with more information about brightness in different runtimes.
Budgeteer
Budgeteer's picture
Last seen: 6 years 5 months ago
With my lux meter on the way... im going to make one of these.
Since i would love to have cosistent readings what's the best way to design the "integrating sphere"?
The sensor of the light meter should not allow other light to go inside. (poorly made hole).
The internals should be made of non reflective material. What would be best? Lined with a old cotton shirt?
The aperture for the flashlight should probably have the antique photo camera rug installed so no other light can pollute the internals?
Shape? Sphere seems logical, but is really that disruptive going for a square box? A dodecahedron would be batter than a box?
A cheap plastic ball might be just the thing. Cut in half, and then heavily brushed to kill any reflectivity. Glued together and glued/ in a wood cage to preserve shape...
If i understood correctly i win if i get my measurements cosistent, but i will never be able to know if my calculeted lumen output of 320 in reality can be 304 or 330?
Any suggestions?
kragmutt wrote:
They're gonna send you a green redcat with a black LED.
Don
Don's picture
It is important that no light can go directly from the torch to the meter's sensor, it has to bounce around first.
http://www.rp-photonics.com/integrating_spheres.html
http://www.sphereoptics.com/assets/sphere-optic-pdf/sphere-technical-gui...
Budgeteer
Budgeteer's picture
Thanks for the good reading. Smile
arenat
Last seen: 8 months 3 weeks ago
Being lazy and hating the maths led me to set mine lightbox to direct reading in Lumen.
Calibrate it with the ITP A3 the only 'trusted' stock not touched I own as 85 lumen in high 23 in med...given the readings I get probably the actual output in mine is 80...
RC-G2 with XR-E R2 at 1,4 A 340 Lumen
RC-G2  with XP-G R4 at 1,4 A 408 lumen
RC-G2  stock XR-E  with rechargable cell 130 Lumen
MTE F15 P7D at 2,4A  620 Lumen
P10 with XP-G R5 at  1,4 A 470 lumen
I think all the number are too high maybe 10%  or a bit less
I need to work in the reflection issue because the throwers perform way better than the flooders or candle mode...
