Gearbest new item evaluation !
12 posts / 0 new
gearbest
gearbest's picture
Last seen: 23 hours 50 min ago
Dear All,
Thank you for all your support to Gearbest.
We will public a new flashlight recently, below are the main descriptions and appearance.
You can leave your opinion or suggestions about this item.
Main Features:
Brand Name: Beamday
• One – hand operation, one – key focus
• SUPER-BRIGHT: 1000-lumen (max)
• LONG-LASTING: Up to 4 hours (Medium-beam mode) of powerful, non-diminishing brightness from the included premium rechargeable 2600mAh battery. Recharge in just 4 hours with a 1A adapter (not included) and the included Micro USB cable.
• TOUGH & RELIABLE: IP65-rated water resistant and designed for use in heavy rain. Its durable aluminum body and shock-resistance endure rough handling.
• 5 modes: Spotlight high – spotlight low – floodlight high – floodlight low – flash
Edited by: gearbest on 04/16/2019 - 02:18
itsonlyme
Last seen: 4 min 3 sec ago
Agro
Last seen: 12 hours 28 min ago
What kind of optics is that?
MascaratumB
MascaratumB's picture
Last seen: 9 sec ago
Ok, GB, let’s see where the rabbit hole leads us!!
Quote:
Brand Name: Beamday
Not the best, but it is not the worst! I believe some of us would suggest “FireBeam” just because! Big Smile
If this is supposed to be a new brand from your company, chose the name well so that it can stand as a known brand of lights among others!
Ok, what do you mean by “key focus”? Is is a zoomable flashlight? Or do you have to push a button to adjust the focus?
Also, and after Agro suggestion, what is that lens? Is it a dual LED flashlight?
If so, does it have optics, or reflectors?
A lot of info is missing here…
Ok, 1000 lumens seems of for generic uses!
But, continuing the questions, what LEDs will it have? Will it have a good heatsink internally?
More, what type of driver will it have?
Also, will it have e-switch or mechanical clicky switch (reverse/forward)
Honestly, you have 3500mAh batteries that can be put inside the flashlight to increase its runtime. So, why put 2600mAh batteries? Is it to spare time while charging? If so, wouldn’t it be better to have longer runtimes instead of having to charge the battery more often?
Also, if charging “fastly” is a plus, to be able to use the flashlight quickly again, why not use USB-C and fast charging with a 3500mAh cell? (don’t know if this makes sense, but correct me if I’m wrong about this suggestion!)
About water-proofness, will that ring on the tail be well isolated due to the screw/unscrew movement?
Again, it is not clear what type of beam the flashlight will produce, so that information would be important to have to better analyse this User Interface!
I am also of the opinion that “flash” (strobe, I suppose) should be hidden, this is, it should not be in the main interface!
Another question: to get “floodlight low” do we have to go through all the modes [Spotlight high – spotlight low – floodlight high] to get that mode?
That is terribly annoying!
Also, does the flashlight have memory? Or does it always start on HIGH (1000 lumens)?
There are many things to be answered here Gearbest, so that we can give proper suggestions!
Still, hope the questions help you to get answers and to make a good flashlight! Arrow Right
REVIEWS: AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 /// SOFIRN: SF14 & SP10A / SP32A / SP10B /// NITEFOX: UT20 / ES10K / K3 /// ODEPRO: KL52 / B018 /// ACEBEAM: H20 /// BLITZWOLF: BlitzWolf BW-ET1 /// DQG: AA Slim Ti /// HC-LIGHTS: SS AAA /// XTAR: PB2 Charger /// OLIGHT: M2R Warrior /// WUBEN: TO10R / E05 / T70 /// ON THE ROAD: M1 / i3 / M3 Pro /// ROVYVON: A2 & A5R / E300S / A8 /// KLARUS: XT1C
Tricks: 1 / 2 / 3 / 4 / 5 / 6 / 7 / 8  TIR Lenses: 1 / 2   Others: Biscotti 3 & 1*7135     Triple TIR & XP-G2
 MY GIVEAWAY (FW3A)
Agro
As to “key focus” – I think they actually mean “one-key focus”.
See modes:
So you use “one key” (tail switch) to both adjust “focus” and switch output level.
I think that it has 2 separate optics, one is floody (spotlight) and the other is floodier (floodlight). As you switch modes the light switches between them.
Which seems like a terrible UI really. If I want to switch mode I don’t want to have to cycle through entirely different beam shape and through strobe. Facepalm
Paradise
Last seen: 24 sec ago
I would like a rear eswitch light.
The dual optics or reflector in the front look interesting.
LarryLumens
Last seen: 6 hours 45 min ago
Just send me one and I will inspect and report.
LL
Give me thrower or give me pizza.
RobertB
RobertB's picture
Last seen: 5 hours 53 min ago
itsonlyme wrote:
Here is some feedback http://budgetlightforum.com/node/66772
Yoobin Hacked… lol
pc_light
pc_light's picture
Last seen: 3 hours 41 min ago
Sounds interesting.
+1 does it have Last-Mode-Memory? Some like it, some don’t but including it as an (simple to access) option would be good.
You’ve provided Throw vs Flood options, which is great, now provide selectable UI Groups and everyone should be satisfied, Options to Start Low first, Start High first, Flood only, Throw only, Alternate Flood to Throw (Flood Low > Throw Low > Flood High > Throw High), etc.
Of course the most important test will be quality of the output.
Move towards the light.
Lexel
Lexel's picture
Last seen: 1 hour 21 min ago
programmable user interface
Trail Trek
Trail Trek's picture
Last seen: 3 days 14 hours ago
Interesting light, sort of like an S2 with a silly name.
Please stop releasing new lights with micro usb charging. USB Type-C came out 2014-2015.
I hate having to carry the old micro usb lead with me when camping for old connections like this.
Other than that it looks an interesting computer render of a new light.
Thanks for posting.
gearbest
gearbest's picture
Quote:
Brand Name: Beamday
1.push a button to adjust the focus,it is a dual LED flashlight.
2.mechanical clicky switch,Inside the aluminum substrate, the outside is aluminum alloy shell, are good heatsink internally.
3.The flashlight have memory, it will begin from last time you have chosen.
4.the ring on the tail be well isolated due to the screw/unscrew movement.
5.For the battery we also can increase it to 3500mAh, but the price will be different.
