[in Design process] Astrolux FT 03 CC FET white flat driver
68 posts / 0 new
Lexel
Lexel's picture
Last seen: 13 hours 20 min ago
Edited by: Lexel on 08/22/2019 - 20:57
Lexel
Lexel's picture
reserved
Lexel
Lexel's picture
Interest List:
Th558
Th558's picture
Last seen: 9 hours 43 sec ago
Interested. Is this for the white flat 2 or 1? 2mm would make more sense.
ZozzV6
ZozzV6's picture
Last seen: 1 day 2 hours ago
5A is for 1mm. The 2mm version need 9-10A
Lexel I am in for one but in parts kit version as my earlier driver orders. I maybe add some other drivers or aux led boards to my order.
808Hi
Last seen: 3 hours 21 min ago
Interested
Lexel
Lexel's picture
1mm2 is 4A, the 2mm 7A near the max output peak, also considering temperature of flashlight after some time running
I hope driver does not get too hot on 7A will need to test that,
I hope the solder filled viases doing a good job on heat thransfer from FET to the Ground plane
mattadores
mattadores's picture
Last seen: 2 weeks 3 days ago
interested!
HONDARIDER
HONDARIDER's picture
Last seen: 5 days 11 hours ago
Definitely interested. I have 3 of these light and would love to mod one for a little more throw just to show off to my friends.
oweban
oweban's picture
Last seen: 4 hours 7 min ago
Interested!
HONDARIDER
Lexel, Where does one go to purchase drivers for other items that you have built?
4492011
Last seen: 8 hours 13 min ago
Will this include the usb charging ?
Lexel
Lexel's picture
HONDARIDER wrote:
Lexel,
Actual ready to sell items are in the different sales topics
http://budgetlightforum.com/node/59724
http://budgetlightforum.com/node/57900
http://budgetlightforum.com/node/57772
http://budgetlightforum.com/node/61921
http://budgetlightforum.com/node/57724
http://budgetlightforum.com/node/66094
if you found a fitting board just PM me
its designed to fit the original charging board
still transplanting it is not so easy those brass rods are a beast if you try just with an iron
I found out iron plus Hot air workst best
Lexel
Lexel's picture
the first prototype will get on my next board order within the next days
it will be usual 1 Oz copper to do first function tests and see if it fits the light flawless as I made manual measurements of the original driver
this will take about 3-4 weeks from China
also if thats done the final production board in 2 Oz will take also some time
mattadores
Hey Lexel,
I thought that you could already swap the white flats into the FT03 without any other mods.
I’m planning this mod for my DOA FT03 host I have kicking around. Can you help me understand what the need/benefit is of this?
I’ve never built a driver and I’m wondering if I would be able to simply salvage all the parts off the FT03 SST-40 driver and re-install them on this one?
oweban
oweban's picture
IIRC white flats start going “pop” at 5A and above; the stock FT03 driver hits ~9A on turbo (FET and all that).
mattadores
that would do it alright if that’s the case.
lol ok I want one. but how do I build an all new driver Facepalm
oweban
oweban's picture
No idea, I’m just going to wait until it’s complete Wink I still need to chip in to his gofundme.
mrheosuper
Last seen: 4 days 10 hours ago
why there is LDO?, isn’t this is 1 cell flashlight?, you could use 2*26350, but it makes no sense to me
and btw, how can you controll current with MCU.
Forgot my pen
Lexel
Lexel's picture
why are people always thinking too much?
a LDO is just a thing that puts out a constant voltage it is not a magical 2S or 4S conversion part
on 2S/4S builds the cell voltage would be above 6V absolute maximum voltage rating of an Attiny MCU, so you need to bring the voltage down (z-diode or LDO)
totally different story here it remains 1S—>3V driver(could be as well used for 2S—>6V LED)
the LDO is there because it is needed on a CC build
reason:
Attiny MCU puts out a PWM signal, the operation amp needs a DC level
so this PWM signal gets filtered to a DC signal using a low pass
if the MCU voltage is not stabilized then the CC set voltage would vary depending on battery charge(like 2.5A with emtpy battery and 4A with full)
Lexel
Lexel's picture
who says you have to build it?
I am developing and building it
when its ready it will be sold
so far I am close to order the prototype of it as design looks good
function got tested on 22mm prototype so it should work
Ryzbor
Ryzbor's picture
Last seen: 51 sec ago
You mean the 2mm WF?
Does it hit ~9A on a low drain (10A rated) 21700?
A local modder here offers FT03’s with the 2mm white flat so I assumed it’s safe for the 2mm.
virence.com rosy 3500K R9080 Wizard Pro, MF01 Mini 4000K to be modded with FA3 SST20, super rosy 3000K E21A Tiara and super warm 2000K Wizard Pro on it's way
ZozzV6
ZozzV6's picture
It is not that simple. A fet driver max output current depends on led forward voltage a lot. An XP-L HI draws like 5A but a 3V XHP50.2 can draw 14A from the same driver. in my L6 a White flat 2mm hit 10A with Liitokala 26650.
oweban
oweban's picture
Ah, I meant the 1mm on the 5A. Pretty sure people have had 2mm at 10A no probs (as per ZozzV6’s comment).
ZozzV6
ZozzV6's picture
I needed to lower the turbo because 2mm white flat turned blue at full power.
Lexel
Lexel's picture
On those currents you already are beyond max lumens and output is dropping, not healthy for the LED
It is better to stay a bit below max test bench output current and have regulation on a high drain battery not only when it is full
DD is no real option for those ultra low forward voltage emitters
oweban
oweban's picture
Definitely agree – finding the best regulated output (4.5A?) as a maximum is a good idea. I figure you know what you’re doing, so I’ll just wait patiently Smile
ZozzV6
ZozzV6's picture
My tries of white flat 1mm version showed that 4,5A is good for this emitter. Worth the bump from 4A but over that nothing significant output increase happening. Just more heat and turning angry blue over 5A
mattadores
Big Smile I thought you were selling blank driver boards.. not fully built just wire it up boards!
Definitely buying one!
Lexel
Lexel's picture
Why should I sell bare boards?
Without parts you wont be able to equip those easily
Without stencil you cant apply the paste as well to viases
4492011
I think that the need for the driver should not be based upon the 1mm flat white plenty of linear drivers for that, but for the 2mm flat white hopfully to get the full potential from the emitter
