Xiaomi Mi Powerbank 3 Pro Review - 45W Power Delivery, 20,000mAh
Xiaomi Powerbank 3 Pro Review - 45W PD, 20,000mAh
The Mi Powerbank 3 Pro is the latest offering from Xiaomi, following the success of the Mi Powerbank and Mi Powerbank 2. This time around we get big internal and physical upgrades, now supporting up to 45W Power Delivery output and input allowing to charge laptops and larger power hungry devices.
The original Xiaomi Mi Powerbank 20,000mAh used 6x LG F1L 18650 cells and had a decent efficiency rating. Mine worked great for almost 2 years and when the status leds failed, I took the batteries out to re-use them. The Mi Powerbank 2 uses pouch Li-Ion cells instead and while it yields lots of output capacity (near 100% efficiency), after a year and a half later the cells started swelling to the point that it can spin on its “flats”. Not sure if this is a widespread problem but mine unit had very moderate use and only about 100 complete charge cycles. After this I lost some trust to pouch cells but decided to give the new Xiaomi’s offering a try anyways.
This unit was not a free review sample :smiley: , I bought it from Aliexpress for $43 shipped which is a lot more than the retail in Asia, but even at this price its pretty on par with what similar product costs on amazon. (I rarely receive stuff for review anymore because I like to work under my own schedule)
Main specs for the new Mi Powerbank:
–20,000mAh 3.7V nominal 74Wh
-Supports 45W PD input and output
–2 USB A output and 1 USB C output/input
-Quick charge supported when a single USB A port is used.
  • Unboxing
Just like any other xiaomi powerbanks, very simple packaging with just a short USB 2.0 A to C cable and a chinese instruction manual.
We get a lot of specs from the back of the box, including output capacity rated at 12,600mAh @ 5V which translates to 85% efficiency at 25W output. Compared to the predecesor it carries 74Wh instead of 77Wh of energy (3.7V vs 3.85V nominal.)
  • Build quality and interface
The familiar design is carried on just like before but this time with a matte finish coating all around and shiny polished plastic on both ends. Although it looks great, neither of these finishes usually last a very long time so let’s see how it holds up. Plastic case feels very solid and well built just like past models.
It doesn’t show on the product pictures, but it is a lot larger than the older model.
Shares the same design with many others Xiaomi / ZMI products.
2x USB-A and 1 USB-C on the top with some output specification. Side button used to restart the unit and trigger low power mode. (for charging low drain devices). 4 small LEDs shows the battery status.
Lots of specs printed on the back, I like that. The shiny plastic finish already shows some scratches and I’ve barely given it any real use. It’s not gonna last long.
  • Output Specification and Load Test
Battery Type: Lithium Polymer Battery
Input: 5V3A, 9V3A, 12V3A, 15V3A, 20V2.25A
Output: 45W MAX
USB-A(Single port): 5V2.4A,9V2A,12V1.5A
USB-A(Dual USB): 5V3A
USB-C: 5V3A,9V3A,12V3A,15V3A,20V2A
USB-C Input: 5V3A,9V3A,12V3A,15V3A,20V2.25A
3 Port: 5V5.4A, 9V3A, 12V3A,15V3A,20V2A
Supported protocols are the same for USB-A and C ports. It does have pass through charging, however only 5V 3A output is supported. When the USB-A output is on and you connect or disconnect a charger on the USB C port, it will reset and restart in about 1.5s. So no UPS functionality.
Normal charging vs Pass-through charging supported protocols:
PD 3.0 has support for all available voltages and also supports PPS (Programmable power supply) for custom voltage request: here I set it at exactly 10V and it delivers. Note that PD 20V is rated at 2A instead of 2.25A for the full 45W output, but this doesn’t matter as much because most devices chose to use 15V3A or 20V2A anyways when 20V3A isn’t supported.
Test charging with various PD devices, all charged flawlessly.
Nintendo Switch
Macbook Pro 2018
Surface Pro 6 with PD to 15V DC adapter. PD triggering adapters will soon become a thing, basically any PD output device with PPS support can be used to power any device ranging from 5-20V up to 3A. Imagine the possibilities!
With the new electronic load I can’t set it to ramp automatically so the lines are not straight as it should. But it should show the results just the same.
Compared to the old version it does not have automatic voltage boost above 1.5A draw which acted as cable resistance compensation. But it is also quite stable with acceptable drop at all outputs.
Load test on the USB-A ports shows 5/9/12V with 3A cut out. For the USB-C it goes up to 4A. All ports will be happy to supply more than the protocols indicates.
9V PD Load test
15V PD Load test
20V PD Load test
  • Discharge and Charge Capacity
Based on the testing on the Mi Powerbank 2 I expect the new version to perform on par when it comes to output efficiency, but the factory rating is already very conservative at 85% @ 25W and that is in ideal conditions.
Recharge:
5V 2.4A adapter
QC2.0 adapter
45W PD Adapter
45W PD Adapter: when using the powerbank at high current draw such as 20V 2A, the LVP will kick in before the battery is entirely drained. In those cases when recharging back up it will require less energy because there is still charge left. Notice that most of the charging time it’s on CV phase.
Discharge
The output is very stable and consistent, even with the axis range zoomed in it remains pretty flat.
Discharging at 5V 2A from USB-A
Discharging at 18W PD from USB-C port
Discharging at maximum PD 45W
For low power devices such as smartphones the efficiency is good and I’d recommend using the USB-A as much as possible. But for power hungry devices maxing out the PD output means wasting a lot of capacity, at 47Wh output it barely provides a full charge for my Surface Pro 6 which has a tiny battery compared to full size laptops (up to 99Wh).
  • Final words
The Good:
-Versatile output and lots of protocols support means being able to charge virtually everything
-Output stays relatively stable beyond specs and has over current protection for all ports.
-Recharging time is impressively quick using a 45W PD adapter, it’s the fastest I’ve tested so far for a 20,000mAh powerbank. 3.5hrs charge for a couple days of smartphone juice!
Neutral
-Efficiency is decent but not as good as previous version. but I do believe that one was under-rated.
-Pouch cells instead of 18650 means it could suffer the same fate as my Mi Powerbank 2 (swelling).
-The matte and polished plastic finish is not the most durable, but this doesn’t affect the performance.
-Only one USB-C port for both charging and recharging means double the wear. I would’ve preferred 2 C and 1 A ports.
The Bad
-The choice for the battery is odd as it seems to be low drain. I noticed that even at relatively low discharge rate (18W) after LVP triggers for the first time I could restart the powerbank and the output and will resume for about another 30 seconds, and it can be repeated many many times which is indication of voltage sag under just ~0.3C load. This is also noticed when recharging at 45W, again at less than 1C and it goes to CV phase much quicker than I’d like, almost half of the charge time it’s on CV phase.
-Voltage boost to compensate for cable losses is missing in this version, it was specially useful when very long or old/bad quality cables are used. Now the USB-A puts out exactly 5.0V which means some devices won’t be charging at optimal speed, they should’ve gone with 5.3V output instead.
Overall I’m happy with my purchase however I wouldn’t be using this one as extensively and I’ll keep it for when I really need that PD output, I have many other cheaper powerbanks that I wouldn’t mind dropping or wearing out. I do believe powerbanks are not yet ready to charge laptops as it is simply not efficient to carry such weight for just half a laptop charge. Maybe in a near future when better components and higher density/discharge batteries are developed.
Thanks for reading! I’ll be happy to answer any of your questions. There are many things that were left out due to my limited time and because my YZXStudio ZL1100 broke, I used a much more powerful discharger for these tests but it’s fully manual.
Thanks for the extensive test!
Does it function as a UPS? (does not cut output power when input is connected or disconnected)
Yes it does have pass through charging, however only 5V 3A output is supported.
@will34,
Which of the current crop of powerbanks, if any, support voltage boost?
Thanks
Voltage boost is very useful for when very long, or low quality, or with worn out connectors cables are used. If you’re certain of the health and quality of your cable it doesn’t improve the charging speed by a lot. I do believe a fixed and stable voltage output is way better than voltage boosting. Ideally a charger with around 5.3V fixed output would provide highest possible charging speed.
I’m using a 6ft long cable to compare between several powerbank and chargers, the output voltage were ranging between 4.89-5.16V under load. Because the cable has 24awg conductors and is pretty new, I’m seeing between 1.68-1.92A. Maximum charging speed using a 1ft long cable is 2.1A.
These I tested to have voltage boost:
-Xiaomi Powerbank 2, 5,000, 10,000 and 20,000 versions
-Anker powerbanks with VoltIQ feature
-Newer ravpower powerbanks with iSmart feature, I have an older one with iSmart and it doesn’t do anything.
-Some of Aukey new powerbanks with PD and USB A port, hidden feature since they’re not advertising it.
I’m really surprised to find this feature missing on the Xiaomi powerbank 3, definitely a downgrade from the older model.
@will34,
I still have some cylindrical wall chargers from the HP Touchpad era that put out a fixed 5.3V. The enthusiast community bought up all the spares when HP gave up on the tablet business!
Xiaomi does not give their technology a cute name but claims they can deliver up to 5.1V but not the circumstances under which they do it. (I have a Power Bank 2 and will try to find time to measure its output)
Anker PowerIQ 2.0 has VoltageBoost but does not provide any detail beyond “smoothing out the voltage” whatever that means
Ravpower iSmart 2.0 has Smart Voltage, the graphic for which seems to show a voltage sense wire going back to the charger which I doubt they really have
Aukey AiPower says nothing about this so their capabilities are indeed hidden.
In your experience, is there some kind of feedback loop that tells the charger to raise the voltage or is it a user driven control of some sort using say QC3.0 PPS or PD3.0 PPS? I see in your review above that the older Xiaomi’s did a fixed voltage step up based on current.
Thanks.
It’s not complicated, but not as easy as with QC 3.0 or USB PD.
In the QC 3.0 and USB PD specs, there is a resistance function used to determine how much current to pass through at a given voltage, or if the machine supports it, upping the voltage and reducing the current if needed.
In most of the other proprietary techs, what they do is that they sense the phone initially requesting a lot of current, but then backs off because of the cable’s high resistance. Some phones are designed to be extremely sensitive to this, and may reduce the current significantly.
Therefore, what these USB supplies do is up the voltage until the set current stays stable.
That means charging is faster, but at the expense of lower overall charging efficiency since the cable has to dissapate more heat.
Not a problem using a wall connected supply, but a problem with battery packs.
BlueSwordM,
Very interesting and likely most effective when the same manufacturer makes the supply and the charging device.
Any idea of the time periods over which these voltage/current changes occur?
Someone should propose running a voltage sense line back from the load to the supply over the charging cable so there is a closed loop!
Thanks.
No idea behind the time periods.
Probably in the seconds range.
Already exists in QC 3.0 and USB-PD.
Wow! Which of the cable wires is the sense line?
I found this thread whilst researching more info on this powerbank because of its PPS feature.
Anyway, this thread made me want to ask this question…
What’s a good baseline for cable resistance in a cable? Ive some emarker usb-IF cables that can handshake to allow PPS type charging. Ive a gadget that can test the resistance of the cable and I’d like to know if there are some resistance values that a cable would be a better cable to use over another with poorer resistance values…
Hopefully my post is making sense… :slight_smile:
Hi, I’m currently looking for a powerbank for my Nintendo Switch and came across this. I was wondering is it safe for the Switch’s battery if I use this xiaomi powerbank pro 3? will the battery get burned if I use it too often?
Dear will34,
first of all thanks for the great review. It did convince me to buy one and it has just arrived. However I cannot get it to charge my Huawei P20 Pro or my Surface Pro 6. In both cases I have been using the cables that I normally use for charging them with a standard charger (in case of the Surface cables explicitly USB PD compliant). The powerbank is charged up but as I said I cannot get it to charge devices connect via USB-C. Charging the mobile via USB-A does work. And strangely enough having connected the mobile and the powerbank, it does look as it the powerbank is being charged-up.
I suppose I forgot some important step. Has anyone here got any idea? Your help is highly appreciated. Many thanks already.
fflachs
I’ll just give my comment but I cannot be 100% sure if this is the reason:
  • I’m unable to find definitive information whether the Huawei P20 Pro supports USB-PD (Power Delivery) or not.
Based on some info I got from Internet search, and also from what you’ve described, it would appear that the Huawei P20 Pro does NOT support USB-PD.
One would need a USB-PD certified USB type-C to type-C cable (based on my limited understanding, one has to use a C-to-C cable to activate USB-PD, although I could be wrong) to activate USB-PD protocol.
So what this means is that, the powerbank and your P20 Pro is not able to communicate a charging standard, and therefore is not charging (or maybe just charging at normal speed?) when using a C-to-C cable.
(with a C-to-C cable, the current flow can be from a USB-PD-certified smartphone to or from a USB-PD-certified powerbank, and if I understand correctly, with USB-PD, you can actually set the smartphone to charge the powerbank, or the powerbank to charge the smartphone, assuming both are USB-PD supporting devices —- based on my understanding — I also don’t have a USB-PD certified smartphone so I have no hands-on experience with that setup ; I do have a charger and a powerbank that are supposed to be USB-PD certified though, just no USB-PD certified smart device to trigger the “PD” other than my USB meters that have PD trigger).
When you use the USB-A to type-C cable, the current flow will from the charger/powerbank to the phone automatically.
Also, I believe the Huawei higher-end devices use a different fast-charging Huawei protocol (because when I use my USB meters to test some powerbanks/chargers, I notice some of them list a Huawei FCP/SCP protocol. And I think only the original Huawei charger will support the “Huawei 4.5v/5Amp” protocol.
Dear d_t_a,
thanks for the reply! I was actually hoping for it to simply charge and wouldn’t have minded if it took a bit longer. In the meantime I have tried charging my bluetooth headphone USB-C-to-USB-C and it failed, too. Both, headphone and P20 Pro, can be charged USB-A-to-USB-C. On the one side I am lucky, that AliExpress refunded the charger, but I still would have like to use it for my mobile devices…
I got one Xiaomi Powerbank pro 3 too. It cannot charge anyone of my home’s two MacBook pro. Good thing, I got refund too. Just wondering what’s wrong, ’cos I see quite a lot of failures on the internet with many Xiaomi Powerbank pro 3 unable to charge laptops. I wonder if there is anyway to repair it…
