Convoy C8+ Programming help..
19 posts / 0 new
rikr
rikr's picture
Last seen: 7 hours 1 min ago
I got this light today and it will not go into programming mode. I have half clicked the crap out of it and still nothing. Please help.
Thanks,
Rick
 New Collection / Old Collection
Marc E
Last seen: 5 days 9 hours ago
Sometimes if i use a low or protected battery i can’t get into programming. Yesterday i couldn’t get into programming mode on my Cometa until i slowed down the rate i was clicking by a fraction, and even then it took more clicks than i remember.
rikr
rikr's picture
Ok I will try that, thanks
No, that didn’t work.
Marc E
Sorry, i don’t have anything else to offer. Hopefully someone else will be along with an idea. Try not to get too frustrated in the meantime Smile
rikr
rikr's picture
That’s ok. I appreciate the help.
bmengineer
bmengineer's picture
Last seen: 4 weeks 10 hours ago
Where did you buy it and which driver did you order?
Find all my reviews of flashlights and more gear at www.bmengineer.com
rikr
rikr's picture
I got this from Banggood
Convoy C8+ Sand-color XPL HI 1100LM Memory Function Professional 12-Group 55Mode Tactical Flashlight – V2-1A
bmengineer
And you’re trying to half click while it’s on?
rikr
rikr's picture
yes
Phlogiston
Phlogiston's picture
Last seen: 5 days 21 hours ago
What modes do you have at the moment? Maybe BangGood got their stock mixed up and sent you an old version.
Default Biscotti modes, assuming nobody’s played with it before you got it: 0.1%, 1%, 10%, 35%, 100%, strobe, biking, battery-check.
There’s a way to recognise the most common old-model driver: put it in the lowest mode, wait about 5 seconds and see if it goes dim for a moment.
rikr
rikr's picture
It’s the 8 mode, when I turn it on in low it stays the same, I have a convoy S2+ and on low it blinks one time.
jfg
jfg's picture
Last seen: 5 hours 35 min ago
10+ half press taps from on and the light should shut off momentarily until it goes into a strobe kind of burst. Tap during the first burst, the light will then start slowly blinking the number for each mode group starting with number one (i.e. wait till it blinks six times, and then click the switch off for mode group 6). Hope this helps, I had to fuss with mine for a while to get it right too.
rikr
rikr's picture
It just keeps cycling, won’t shut off just keeps on and on
Phlogiston
OK. Unfortunately, that sounds like you have the new driver, but it’s defective.
One last thought – there was a buggy version out there that ran at double speed, so you had to half-press really fast to get it into programming mode. Those drivers were supposed to have been taken off the market, but somebody somewhere got their stock mixed up, so they still crop up from time to time.
If that doesn’t help, then I can’t think of anything else; you probably have a defective unit. Ask BangGood for a refund. After that, Convoy sell replacement drivers if you want to try your hand at a fix (you have to unsolder & resolder a couple of wires).
rikr
rikr's picture
Thank you for all the help, I was thinking it was a bad unit also. Oh well, now the fun part..lol
RelakS
Last seen: 1 day 22 hours ago
Do you click quickly through the modes? After about 10 clicks it should go dark, blink one, and strobing fast.
You should not keep more than 0.2-0.3 seconds between clicking, or you will only cycle through the modes. This means if you happen to turn off the light, it might need so much time to turn back on that you have to start over.
rikr
rikr's picture
Yes, I do. I have other Convoys that I have had no problem switching modes. This one just won’t.
Swabs
Swabs's picture
Last seen: 6 hours 34 min ago
I just tried looking for turbo mode for the first time on my Convoy C8+. All it does is cycle through four levels of brightness. I tried the ten or more half clicks while the torch was on, but I am stuck with only the four levels of brightness.
Is my C8+ defective? Is there a known defect for the C8+ that Convoy is offering repairs or replacement for? I wish I had tested this out when I had first received the C8+, but I was fixated on its throwing performance.
My Future's So Bright...well, my flashlights are anyways.
strobe me, strobe me. STROBE! STROBE! strobe me, strobe me. STROBE! STROBE!
JiggyJinjo
Last seen: 1 week 2 days ago
Seems like you have the version without biscotti firmware
