Modding Sunwayman D20A
7 posts / 0 new
Wrathbringer27
Wrathbringer27's picture
Last seen: 8 hours 33 min ago
Hello!
I have a really important question. Is this light mod friendly? It’s my nightlight I sleep with under my pillow. The red light is terrific but the cool white isn’t. I want to swap out the xpg2 to maybe a nichia or sst20. Not sure if this can power a sst20.
So yeah, warm white, not sure to go with a dedomed xpg2 for WW or for less throw with a nichia.
Thanks guys!
Words can be broken,
so can bones.
Edited by: Wrathbringer27 on 05/12/2019 - 11:31
BlueSwordM
BlueSwordM's picture
Last seen: 1 hour 39 min ago
Since it has an XP-G2, you should go with an SST-20.
Same footprint, a bit more throw, easily available, much better color reproduction in 4000k and below CCTs, etc.
Nichia can be used too, but I wouldn’t recommend it.
Wrathbringer27
I see. But, how do I open it up. I’m not an experienced modder. I usually send it to someone else to open it up and replace the board
so can bones.
djozz
djozz's picture
Last seen: 1 hour 21 min ago
I would first try screwing off the bezel, by pushing the light down on a strip of rubber or inner tyre then rotate.
If that does not work, I’d carefully blowtorch the top a bit (not in the lens opening), to soften eventual glue in the threads, then repeat the rotation on the strip of rubber.
I have good luck sofar with opening bezels of all kinds of lights, but have also ruined one or two lights.
Vinh did modding on the D20A back in 2014 so there must be ways.
bansuri
Last seen: 8 min 51 sec ago
Push the larger bezel against a rubber band or large rubber surface and unscrew it.
There will be a lens, o-ring, reflector, and centering ring to remove.
You will see 2 small phillips on the sides of the inner cavity to remove.
I don’t recall if there are any screws under the buttons. If the driver doesn’t come out then check there. (It’s been a while, sorry).
The whole assembly will come out of the tail end.
The actual modding can be done, I’ve done 2 and it was medium complexity level.
Wrathbringer27
I tried opening the large bezel. I used tape and presses the bezel against it. The glass lens dropped out. I couldn’t figure how to remove the o-ring. It’s so tiny. I didn’t want to risk breaking it
so can bones.
bansuri
I use a needle to get it started, work it between the ring and the threads.
Not the best light to start modding hobby with but doable.
