Test/review of Sony US21700VTC6A 4000mAh (Green)
6 posts / 0 new
HKJ
HKJ's picture
Last seen: 7 min 51 sec ago
DSC_3747
Official specifications:
  • Size: 21700
  • Nominal Capacity: 4000mAh
  • Continuous Discharge Rating: 30A (40A with 80° Deg. C temperature cut)
  • Nominal Voltage: 3.6v
Sony%20US21700VTC6A%204000mAh%20(Green)-info
This is a 21700 high current cell and it is not really from Sony anymore, Murata has bought the LiIon battery business from Sony.
DSC_3746
DSC_3748 DSC_3749
DSC_3750
DSC_3751
DSC_3752
Sony%20US21700VTC6A%204000mAh%20(Green)-Capacity
The two batteries are very well matched, but at 30A they have problems with heat.
Sony%20US21700VTC6A%204000mAh%20(Green)-Temp-20.0
Sony%20US21700VTC6A%204000mAh%20(Green)-Temp-30.0
My thermosensor ran out of batteries and did not stop discharging of the A battery, instead the internal fuse in the battery blow.
Sony%20US21700VTC6A%204000mAh%20(Green)-CapacityTimeHours
Sony%20US21700VTC6A%204000mAh%20(Green)-Energy
Sony%20US21700VTC6A%204000mAh%20(Green)-PowerLoadTime
Sony%20US21700VTC6A%204000mAh%20(Green)-TripCurrent
Sony%20US21700VTC6A%204000mAh%20(Green)-Charge
Conclusion
This is a good battery and can easily deliver 20A, but at higher current it best to have a temperature cut-out.
Notes and links
The batteries was supplied by Vapcell for review.
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
wolfdog1226
wolfdog1226's picture
Last seen: 1 week 6 days ago
Thanks HKJ. Cool
Looks pretty good but not quite as good as the Samsung 40T and the Molicel P42A. This is in regards to voltage sag. P42A has a little advantage w/ 200mAh additional capacity….40T and Sony21700VTC6A both w/ the RATED 4000mAh.
Solitude breeds contemplation which creates clarity.
Environment molds a person. Perseverance changes them.
        WOLFDOG
Agro
Agro's picture
Last seen: 8 hours 32 min ago
I expected more from it. Thanks HKJ!
RelakS
Last seen: 2 hours 3 min ago
“Do not use outside of battery pack”
Hmmm…. Because what will happen otherwise?
Superstocker
Superstocker's picture
Last seen: 4 hours 11 min ago
Thanks again HKJ! I was hoping these would outperform the 40T’s. Not quite though. They look good though.
shadockan
shadockan's picture
Last seen: 1 day 16 hours ago
HKJ … Thank’s my friend …
Your help is unlimited …..
Molicel P42A = 4200mAh
Sony VTC6A = 4160mAh
Samt 40T = 4000mAh
Up to 3.0 – 3.3 Volts batteries have minimal differences.
The differences will be seen in a graph.
There are no differences in use.
They deliver a current of 25A without exceeding 80 ° C.
With 30A Samy had a 82 ° C rise in temperature.
The temperature of Molicel P42A was the same
There are samples of the VTC6A, which are exactly the same as the Samy 40T.
I believe that in the future we will see better batteries from this model in the market.
It’s not the first time Sony’s original batteries in the market … were lower than the next batches …..
