Test/review of A123 ANR26650M1B 2500mAh (Green)
7 posts / 0 new
HKJ
HKJ's picture
Last seen: 4 min 57 sec ago
DSC_7329
Official specifications:
  • Nominal capacity: 2500mAh
  • Minimum capacity: 2400mAh
  • Call weight: 76g
  • Internal impedance: 6mOhm @ 1kHz
  • Recommended standard charge method: 1C (2.5A) to 3.6V CCCV, 45 min
  • Recommended fast charge method: 4C (10A) to 3.6V CCCV, 12min
  • Maximum continuous discharge: 70A
  • Maximum pulse discharge: 120A for 10s
  • Cycle life: >1000 cycles
  • Operating temperature: -30° ~ 55°C
  • Storage temperature: -40°C ~ 60°C
A123%20ANR26650M1B%202500mAh%20(Green)-info
This cell is fairly old, data sheet is from 2011, but even today its current capabilities are impressive. The capacity is not very impressive, but some of it is related to the chemistry (LiFePO4), it has lower capacity.
DSC_7327 DSC_7328
DSC_7330 DSC_7331
Watch out for polarity on this cell, the can is plus!
DSC_7332
DSC_7333
DSC_7334
A123%20ANR26650M1B%202500mAh%20(Green)-Capacity
This chemistry has a very flat discharge curve and the two cells are well matches and do not have any problems with 30A
A123%20ANR26650M1B%202500mAh%20(Green)-Temp-20.0
A123%20ANR26650M1B%202500mAh%20(Green)-Temp-30.0
The do not even get hot.
A123%20ANR26650M1B%202500mAh%20(Green)-CapacityTimeHours
A123%20ANR26650M1B%202500mAh%20(Green)-Energy
A123%20ANR26650M1B%202500mAh%20(Green)-PowerLoadTime
A123%20ANR26650M1B%202500mAh%20(Green)-TripCurrent
A123%20ANR26650M1B%202500mAh%20(Green)-Charge
Conclusion
These are impressive high current battery. The disadvantage of these batteries is lower voltage and capacity. Today it is possible to get better batteries in this chemistry.
Notes and links
Vapcell told me that I was missing some cells in my comparator and they would be happy to supply them.
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
Barkuti
Barkuti's picture
Last seen: 2 min 8 sec ago
Sorry but there's something wrong with this test: the reviewed cells were bad, for sure.
You already reviewed this cell in the past with the old station, dear Henrik: A123 26650 2500mAh (Green)
Let's take a comparative look at the discharge graphs:
From this review:
From the old review in the old, non 4 terminal (?) holder station:
The difference is appalling!
Mooch also reviewed this cell 2¾ years ago: A123 ANR26650M1-B 2400mAh 3.3V 26650 Bench Test Results...an extraordinary battery, with issues
His main discharge graph:
Regards and cheers Smile
HKJ
HKJ's picture
Barkuti wrote:
Sorry but there’s something wrong with this test: the reviewed cells were bad, for sure.
The cell may be a bit old, I do not see any other reason for this.
Shadowww
Last seen: 1 day 21 hours ago
It’s a shame A123Systems went out of business. Their LiFePO4 cells were quite ahead of their time.
hank
hank's picture
Last seen: 1 hour 9 min ago
A few years ago when I asked someone at A123, I was told all the cells then on the market were old stock but that the company planned to resume production.
patmurris
patmurris's picture
Last seen: 7 hours 58 min ago
Impressive current indeed, although at a low voltage.
If those cells are as old as their datasheet…
vapcell Dennis
vapcell Dennis's picture
Last seen: 1 day 12 hours ago
Let’s take a comparative look at the discharge graphs:
From this review:
Mooch also reviewed this cell 2¾ years ago: A123 ANR26650M1-B 2400mAh 3.3V 26650 Bench Test Results…an extraordinary battery, with issues
Yeah ,It is old a123 cell, HKJ,could you mark old cell,or The title says old M1B
Battery curves are compared with M1B,
https://lygte-info.dk/review/batteries2012/A123%2026650%202500mAh%20(Green)%20UK.html
This battery is very good Thumbs Up
