[Review] Olight PL-Pro (1500 Lumen Weapon Light & Comparisons with the PL-2)
Today I have a review of the Olight PL-Pro Weapon light. This is a version of the PL-2 that came out last year but the Pro offers Olights built in magnetic recharging system, an optional remote pressure switch and a neutral white LED. Thanks to SkyBen (Affiliate Link) for sending this to me to take a look at.
Full Image Gallery: Olight - PL Pro Review - Album on Imgur
Join my channels Facebook Page: Liquidretro Gear & Reviews
YouTube Version of this Review:
Packaging
Packaging follows Olights recent trends for 2019. A white high quality box with a photo of the light on the front and information on all sides. Inside the light pulls out from a tray. Below is all the accessories including the picatinny insert (Glock insert comes preinstalled), extra screws, Torx driver, MCC1A USB charger, and the manual. Skyben also included a battery holder (Even though this light doesn’t have replaceable batteries).
I also got with my light the RPL-7 magnetic pressure switch which came in a small zip top bag. It includes the remote pressure switch itself, and then an adapter so that the switch can be mounted or zip tied to a picatinny rail section.
Construction
The body itself is made from hard type anodized aluminum. The battery compartment is contoured to match the PL-2 that had removable batteries where as the PL-Pro has an internal non removable cell. The PL-Pro carries over the mounting system from the PL-2RL by having a metal rail piece. Out of the box this came with the Glock sized rail preinstalled, but you get a 1913 rail piece in the box as well as an allen wrench to change it. The quick detach mount is very sturdy, and requires no tools to attach to the light. It has tension on the mounting system even in unlocked so it won’t drop free without pushing in from the side, I like this two step open option, as it makes sure the light won’t fall off if accidentally bumped or the unlock lever gets reversed.
The rear switches and battery cover look the same from the PL-2, the only exception is that on the PL-Pro they don’t open. On the bottom there is the magnetic charging pad. There is a slightly raised up section
The RPL-7 remote pressure switch fits onto the bottom of the PL-Pro perfectly. It’s a stronger magnet then the charger which is good because it’s not something you would want to fall off. The cable is a similar flat siliconized cover. The button itself is plenty long. My only semi complaint would be the way it attaches to your rifle, I would prefer a mount that screws into piciitiy rail or that Olight would offer a MLok adapter.
Size & Weight
Size wise the PL-Pro is basically identical to the PL-2. The only difference at the bottom there are little extra nibs on the Pro for the recharging base making it a little thicker. I don’t have a way to test this myself but I suspect some holsters that fit the PL-2 will also fit the PL-Pro or could with a very slight modification. Weight of the PL-Pro is actually about 13 grams lighter. The PL-Pro is IPX6 rated.
PL-Pro PL-2
Length 81mm 80mm
Height 32.4mm 30.5mm
Width 36.6mm 36.6mm
Weight 103.4g 116.1g
Mounted Photos
LED/Runtime/Beamshot
The Olight PL-Pro is using a Cree XHP 35 HI NW. This is the same LED as the the PL-2 but in a different tint. My PL-2 is in a cool white, and the PL-Pro right now is only coming in neutral white. While I applaud Olight for offering a neutral white (Usually my preference) the bin they chose here has a good amount of green in it, and it’s most noticeable in lower output modes. In my comparison shots here it’s noticeable which is cool white and which is neutral white.
The beam is identical to the PL-2 due to the same reflector and LED being used with the difference being the tint of the LED. The light has a medium sized hotspot that throws pretty well out to 100 yards or so.
PL-2 On Left —- PL-Pro on the Right
In my runtimes were pretty accurate with what Olight saw. The internal battery is rated for 900mAh. On the full 1500 lumens the light lasted for 1.5 minutes, past that it saw a 60% relative output decrease where it ran for 35 minutes. Now this sounds like a big drop and it is but this was still quite a bit of output at 300 lumens. Next the light saw a step down to right at 20% relative output where it ran for another 10 minutes before shutting off. Step downs at the beginning are timed and then voltage controlled from there on out. Step downs are sudden and sharp. It would be nice to add a couple of flashes at the end of the runtime giving one last warning before the light shuts off.
Recharging of the built in 900mAh battery is accomplished with Olights MCCA1 charging system. It’s compatible with other older charges from Olight, except for the one for the PL-Mini. I saw a complete recharge in 1 hour and 18 minutes at a max charge rate of 0.9A.
UI
UI is a little different but similar on the PL-Pro. The light has 2 modes, a low power 300 lumen mode and a high power 1500 lumen mode. It’s pretty easy to switch between them, Just double click on one of the paddles to jump up into high or medium mode, similar to how you get to turbo on other Olights. Low Power mode is more of a lockout mode so it won’t burn a hole through you bag accidentally. To activate it with the light on press one of the paddles for 3 second then press and hold the other till the light shuts off. At this point it’s in a low power 100 lumen mode Olight is calling Lockout. To reverse this just do this process again.
In either mode the light a quick press of a paddle locks the light on, a longer press gives you momentary, and pressing both together gives you strobe.
Pro’s
  • Rechargeable is really convenient and cheaper to run if you are going to use a lot of hours on it.
  • Nice integration with a remote pressure pad as an option, gives this light the ability to mount on a rifle as well.
  • Neutral white, but that green tint kind of kills the deal here for me
  • Some holsters that fit the PL-2 may fit the PL pro as they are similar in dimensions. Your luck may vary
Con’s
  • LED choice resulted in a beam that has a green tinge.
  • Battery isn’t user replaceable thus it’s a consumable light.
  • Timed step downs for turbo.
Conclusion
The Olight PL-Pro Valkyrie continues to show what Olight has learned when making weapon lights. The little refinements like making a low power (still 300 lumens) lockout mode to prevent the light from literally burning a hold in your bag is a simple, smart idea. I like the integration of the remote pressure switch as well being magnetic, meaning it can break free with sufficient force if needed without damaging things. It’s easy to reattach too. Olights tint choices for LED’s continue to confuse me. My only thought about the choice of going with neutral white here was to aid hunters who are more likely to use the rechargeable version of this light to save runtime costs over the CR123 version, over the PL-2 being more designed for a tactical role, better shelf stable batteries etc. The downside of neutral white at least here is more green tint then I would like to see. Overall if you liked the PL-2 you will like the PL-Pro. It’s a very similar light but includes Olight’s magnetic recharging system and a neutral white LED this time.
