Test/review of Altizure AA 1200mWh LiIon (Brown) SQ00F3
7 posts / 0 new
HKJ
HKJ's picture
Last seen: 48 min 26 sec ago
DSC_8148
Official specifications:
  • Typical capacity: 650mAh
  • Minimum capacity: 630mAh
  • Nominal voltage: 1.5V
  • Standard charge: 325mA
  • Rapid charge: 2.6A
  • Standard discharge: 325mA
  • Rapid discharge: 6.5A
  • Lifetime at standard charge/discharge: 20000 cycles
  • Lifetime at rapid charge/discharge: 10000 cycles
  • Temperature: Charge: -20°C ~ 60°C, Discharge: -40°C ~ 60°C, Storage: -20°C ~ 50°C
  • Self discharge: 1.9% first month then 0.5 – 1% monthly
Altizure%20AA%201200mWh%20LiIon%20(Brown)-info
This is a new type of battery: Low voltage LiIon, they can handle very high charge current and many cycles.
DSC_8149 DSC_8150
DSC_8151
DSC_8152
DSC_8153
Altizure%20AA%201200mWh%20LiIon%20(Brown)-Capacity
The two tested batteries matches nicely, the capacity is fairly low and the voltage fairly high for AA cells.
Discharge%20capacity%20Altizure%20AA%201200mWh%20LiIon%20%28Brown%29
I also did a discharge at low current to see if voltage and capacity changed. The voltage is about 1.85V (Lithium primary is 1.7V).
Altizure%20AA%201200mWh%20LiIon%20(Brown)-CapacityTime
Altizure%20AA%201200mWh%20LiIon%20(Brown)-CapacityTimeHours
Altizure%20AA%201200mWh%20LiIon%20(Brown)-Energy
Altizure%20AA%201200mWh%20LiIon%20(Brown)-PowerLoadTime
Altizure%20AA%201200mWh%20LiIon%20(Brown)-Charge
Their charge algorithm is similar to other LiIon batteries, but at other voltage levels, this means a special charger.
Battery-20190712115906-Pulse-0.5A-10-10-1V-IR
Charger BC-L01A
DSC_8156
This is a charger designed for these batteries, it cannot charge other types of batteries.
DSC_8139 DSC_8140 DSC_8141 DSC_8142
The box is a black cardboard box with some specifications on it.
DSC_8147
The box contained the charger, four batteries, USB cable and a instruction sheet.
DSC_8163
The charger is USB powered.
DSC_8164
There is a led for each slot, it is red while charging and green when done, with no battery in the slot it is off.
DSC_8158 DSC_8159
DSC_8160
The charger uses the common two level slots for AA/AAA sized batteries, but do not put NiMH batteries in it!
DSC_8161 DSC_8162
DSC_8165 DSC_8166
DSC_8157
Measurements
  • Power consumption when idle is 35mA from USB.
  • Charger will discharge batteries with about 4mA when unpowered.
Altizure%20%28Altizure%29%20%231
The charger uses about 2.5A current and charges to 2.4V, this takes slightly above 15 minutes for one cell.
Altizure%20%28Altizure%29%20%232
Altizure%20%28Altizure%29%20%233
Altizure%20%28Altizure%29%20%234
THe 3 other slots looks similar.
Altizure%20%284xAltizure%29
With four cells the charge time is increased to about 1 hour, the charger uses less than 1.5A from USB.
Poweron
The charging is pulsing the current, probably to measure the voltage.
Charge%202%20cells
Charge%203%20cells
Charge%204%20cells
With more cells the same charge circuit is doing time sharing between the cells.
USBCurrent
I noticed a current spike in the USB current.
USBCurrentzoo
It is rather high, but also a short pulse. This will probably prevent the charger from working with some USB supplies.
Conclusion
This battery do not have any electronic circuit in it, but is a special LiIon type battery with a voltage near primary Lithium-Iron batteries.
The capacity is rather low, but it is fast to recharge the battery and according to the specifications it will last for many many cycles. It can also be used in cold weather and even charged in cold weather.
I am not sure how useful loose AA sized batteries are (More capacity and a bit lower voltage would make them more useful), but battery with fast charge time and many charge cycles can be very useful in some products, even if they have fairly low capacity.
The supplied charger is not ideal, the fast charge is impressive with one cell and mostly disappears with four cells. I am missing a warning not to charger NiMH in it, that ought to be a very visible warning on the charger.
Notes and links
The batteries was supplied by Altizure for review.
Compare to other AA/AAA batteries: Alkaline/NiMH/Lithium
LumenHound
LumenHound's picture
Last seen: 1 month 15 hours ago
Thanks for testing these interesting cells HKJ.
They are certainly a niche market product.
1332332331
Last seen: 2 days 16 hours ago
It seems like these could be useful for devices designed for alkaline batteries that don’t like the lower voltage of NiMH batteries. I have a remote control that never indicates more than 1/2 full batteries when using NiMH. I guess it’s really just a cosmetic thing, but I’d like them to show full.
Superstocker
Superstocker's picture
Last seen: 2 hours 2 min ago
Thanks HKJ! These are interesting cells.
Barkuti
Barkuti's picture
Last seen: 1 hour 20 min ago
Interesting. Maybe for toys or related stuff with relatively high power demands.
≈2.4V cut-off voltage? Yikes! That's a pretty high figure for a “1.5V nominal” battery. I'd say the cell would be fully charged with a bit less voltage, maybe 2V tops. Pretty sure.
Smile
Shadowww
Last seen: 9 hours 34 min ago
Wouldn’t these be great in 1xAA flashlights that cannot run off 14500’s? The higher voltage at high currents (vs NiMH) would give significantly higher brightness.
For much shorter time, though. But maybe some applications value brightness over battery life
Barkuti
Barkuti's picture
Shadowww wrote:
Wouldn't these be great in 1xAA flashlights that cannot run off 14500's? …
What flashlight? There are many 14500 flashlights, and most single cell units can run on standard 14500 li-ion too I believe.
Shadowww wrote:
… The higher voltage at high currents (vs NiMH) would give significantly higher brightness.
A single AA flashlight driver will need to boost the voltage of this cell anyway. It would get an efficiency benefit due to the much higher voltage, but the cell capacity and energy is quite low.
Now, a dual in series AA flashlight may be something to look at. I mean, the flashlight driver would either blow up or could become a lot brighter. Just could.
Cheers Smile
