Test/review of Keeppower 18650 3400mAh P1834J (Black) 2019
7 posts / 0 new
HKJ
HKJ's picture
Last seen: 5 hours 3 min ago
DSC_6847
Official specifications:
  • Nominal capacity: 3400mAh
  • Minimum capacity: 3250mAh
  • Nominal voltage: 3.70V
  • Charge voltage: 4.20 +/-0.05V
  • Discharge cut-off voltage: 2.50V
  • Standard charge current: 1500mA
Keeppower%2018650%203400mAh%20P1834J%20(Black)%202019-info
This is protected high capacity 18650 cells from Keeppower.
DSC_6846
DSC_6848 DSC_6849
DSC_6850
DSC_6851
Keeppower%2018650%203400mAh%20P1834J%20(Black)%202019-Capacity
The two cells tracks nicely and the protection trips when they are overloaded.
Keeppower%2018650%203400mAh%20P1834J%20(Black)%202019-Temp-5.0
Keeppower%2018650%203400mAh%20P1834J%20(Black)%202019-Temp-7.0
Keeppower%2018650%203400mAh%20P1834J%20(Black)%202019-CapacityTimeHours
Keeppower%2018650%203400mAh%20P1834J%20(Black)%202019-Energy
Keeppower%2018650%203400mAh%20P1834J%20(Black)%202019-PowerLoadTime
Keeppower%2018650%203400mAh%20P1834J%20(Black)%202019-TripCurrent
Keeppower%2018650%203400mAh%20P1834J%20(Black)%202019-Charge
Keeppower%2018650%203400mAh%20P1834J%20%28Black%29%202019-Pulse-1A-10-10-2.8V-IR
Conclusion
This is good protected cells. They can deliver above 8A for a short time and a bit below 7A during a full discharge.
Notes and links
The batteries was supplied by Keeppower for review.
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
Superstocker
Superstocker's picture
Last seen: 1 day 1 hour ago
Thanks HKJ!
hasddie293
hasddie293's picture
Last seen: 13 hours 5 min ago
Thanks HkJ, great review and test.
Is this probably good high capacity cell definitely for longer runtime usage and for electronics device that consume less power.
Cell has protection board which good for some electronics device aren’t equip with safety discharge limit.
In search of the most ideal flashlight in town:
1. BRIGHTNESS
2. Durabillity
3. Design
4. Quality
5. Price$$$
Barkuti
Barkuti's picture
Last seen: 1 hour 19 min ago
Overstated capacity and energy claims as usual. Even if a little bit.
As (this) technology is the battery does not “go up”, it exclusively “goes down”. This means you never ever see rated figures. Lousy imho.
Smile
Innocent
Shadowww
Last seen: 8 hours 3 min ago
To be fair, this battery’s capacity is rated at a discharge to 2.5V. HKJ only discharges it to 2.8V, which might not consume full capacity of the cell.
flydiver
Last seen: 4 hours 26 min ago
Once you get down below 3.0v the drop is precipitous. Not really much down there that’s useful, and it’s not good for the battery. Who is actually going to use a cell like this from 4.2v > 2.5v at 0.1A on a routine basis? It would be like testing MPG on a car by driving it at 30mph a glass track with a tailwind and crowing about the results.
You can nitpick methodology, but it’s mostly just marketing hype, and they seem to over ride the engineering dept anymore. Seems very few are immune to it.
Barkuti
Barkuti's picture
If you need to know how much capacity until 2.5V you need to look somewhere else, at ECF for example (Mooch's reviews). Barely anything changes, though.
This cell claims 3250mAh minimum capacity, a figure which is not met at less than rated discharge (0.2C = 680mA) down to 2.8V (3236mAh at 0.5A). Suffice to say KeepPower does not seem to do any in-house testing to their rewrapped cells, their cell testing machinery is incorrectly calibrated, they overlook the results or any combination of the  aforementioned.
3400mAh? Not by a long shot…
Smile
Innocent
