flashlight modding and list of LEDs by order of LUMEN output
15 posts / 0 new
xP.1337
Last seen: 2 years 7 months ago
http://www.dealextreme.com/forums/Forums.dx/Forum.-209~threadid.530221
Luxeon Rebel 040-bin (84+ lm @ 1A)
Luxeon Rebel 050-bin (105+ lm @ 1A)
Luxeon Rebel 060-bin (126+ lm @ 1A)
SSC P4 S1-bin (127-141 lm @ 1A)
SSC P4 S2-bin (141-165 lm @ 1A)
Luxeon Rebel 070-bin (147+ lm @ 1A)
SSC P4 T1-bin (165-188 lm @ 1A)
Luxeon Rebel 080-bin (168+ lm @ 1A)
Cree XRE/XPE P4-bin (177-192 lm @ 1A)
Luxeon Rebel 090-bin (189+ lm @ 1A)
Cree XRE/XPE Q2-bin (192-207 lm @ 1A)
SSC P4 T2-bin (188-214 lm @ 1A)
Cree XRE/XPE Q3-bin (207-220 lm @ 1A)
Luxeon Rebel 100-bin (210+ lm @ 1A)
Cree XRE/XPE Q4-bin (220-233 lm @ 1A)
SSC P4 U1-bin (214-235 lm @ 1A)
Luxeon Rebel ES (225+ lm @ 1A)
Luxeon Rebel 110-bin (231+ lm @ 1A)*
Cree XRE/XPE Q5-bin (233-251 lm @ 1A)
SSC P4 U2-bin (235-256 lm @ 1A)
Cree XRE/XPE R2-bin (251-268 lm @ 1A)
SSC P4 U3-bin (256-280 lm @ 1A)*
Cree XRE/XPE R3-bin (268-286 lm @ 1A)
Cree XRE/XPE R4-bin (286-306 lm @ 1A)*
Cree XPG R2-bin (380-406 lm @ 1.5A)
Cree XPG R3-bin (406-433 lm @ 1.5A)
Cree XPG R4-bin (433-463 lm @ 1.5A)
Cree XPG R5-bin (463-493 lm @ 1.5A)
Cree XPG S2-bin (493-520 lm @ 1.5A)*
Cree MCE H-bin (490-560 lm @ 2.8A)
SSC P7 A-bin (440-570 lm @ 2.8A)
Cree MCE J-bin (560-648 lm @ 2.8A)
SSC P7 B-bin (570-700 lm @ 2.8A)
Cree MCE K-bin (648-753 lm @ 2.8A)
SSC P7 C-bin (700-800 lm @ 2.8A)
Luminus SST-50 F-bin (635-823 lm @ 5A)
Cree MCE M-bin (753-858 lm @ 2.8A)
SSC P7 D-bin (800-900 lm @ 2.8A)
Cree MCE N-bin (858-980 lm @ 2.8A)*
Luminus SST-50 G-bin (823-999 lm @ 5A)
SSC P7 E-bin (900-1100 lm @ 2.8A)*
Luminus SST-50 H-bin (999-1175 lm @ 5A)
Luminus SST-50 J-bin (1175-1410 lm @ 5A)
Luminus SST-50 K-bin (1410-1645 lm @ 5A)*
Luminus SST-90 K-bin (1410-1645 lm @ 9A)
Luminus SST-90 L-bin (1645-1998 lm @ 9A)
Luminus SST-90 M-bin (1998-2350 lm @ 9A)
Luminus SST-90 N-bin (2350-2820 lm @ 9A)
Luminus SST-90 P-bin (2820-3408 lm @ 9A)*
thats something i find VERY useful as a quick reference guide
now my qustion for modding is
I am doing more Aurora V6's (have 3 bodies in the mail, since i screwed up the first 2)
I plan on recreating my Q5 (loved it)
doing an R5
and then an MC-E as a pocket rocket.
my main question is, I can get the emitter alone or a star. I am looking for a 14mm star with an MC-E on it.  I am not to picky, will take a Jbin as that will be plenty of output (WOOT!)
i know it exsists, cause my MC-E p60 drop in is a 14mm circle/star.
where can i find these for the MC-E????
or preferably one premounted
agenthex
agenthex's picture
Last seen: 5 years 11 months ago
They don't fit very well on a 14mm star since their long side is already 9mm.
physical specs contained on datasheet:
http://www.cree.com/products/pdf/XLampMC-E.pdf
Reading this makes you smarter: http://lesswrong.com/
xP.1337
ah but they DO fit lol
sorry for the massive picture. but as u can see they do exsist
xP.1337
also a good find while i was looking
http://www.xmeteorlight.com/SSC/CREE/Lumileds/c68/p296/Cree-XLamp-MC-E-M...
but still not the 14mm style im looking for.   M bin is awesome tho Big Smile
agenthex
agenthex's picture
This is an interesting star design:
http://www.cree.com/XLampModels/XLamp%20MC-E%20Star%20PCB%20Series.pdf
For when you have higher voltage ~14v already, you only need 700ma drive for full power. The p7 is parallel only.
I wonder if it works if you use a standard 1 die regulator and hook only it across the first die and then wire the rest in series. You'll still need  a source higher than the summed vf's, but you won't need a special driver.
Oldienea
Oldienea's picture
Last seen: 4 years 5 months ago
Here you can get some bare emitters, but not the 14mm star, sorry. No free shipping, sorry again.
http://www.led-tech.de/en/High-Power-LEDs-Cree/CREE-MC-E-Series-c_120_13...
xP.1337
yea i need that 14mm star. cause its gotta be made for the LED.
i know they make them. just gotta find them!
agenthex
agenthex's picture
Well, you could in theory just use a xr-e star. Physically they're the same dimensions and electrically just soldering everything down should work.
The problem is that KD only sells a 16mm, which you'll need to sand down AND reflow for mc-e
http://www.kaidomain.com/ProductDetails.aspx?ProductId=1772
dx has already mounted xr-e
http://www.dealextreme.com/details.dx/sku.3475
you'll need to take off existing emitter and add the raw mc-e.
SPAMBOT
SPAMBOT's picture
MC-E on MCPCB, is it 14 or 16mm? Should fit in a p60 either way.
Now with 100% all natural asbestos!
Nautic
Nautic's picture
Last seen: 4 months 1 week ago
At the KD website it says 16 mm. Will fit a P60
Cheap quality is good - Expensive crap isn´t
xP.1337
ah but theres no bin labeling. i want to get the best bin i can. good catch tho. almost seems worth it to sand it down a bit to make it fit!!!
edit: also this is not for a p60 mod, its for a Aurora V6 mod.   the empty aurora V6 on DX uses 14mm.  but the mc-e has the same diameter diode as the q5 which the reflector is designed for
i plan on having 3 Aurora V6s
1 Q5
1 R5
1 MC-E (just for fun. to hot to use)
Don
Don's picture
Last seen: 2 years 5 months ago
Since Brted hasn't said it yet, take a look here.
The numbers from my light tests are always to be found here.
https://spreadsheets.google.com/ccc?key=0ApkFM37n_QnRdDU5MDNzOURjYllmZHI...
SPAMBOT
SPAMBOT's picture
Current top flux bin for MC-E is N, there are some bare N WG-tint available over at led-tech.de They are €21 a piece excl. shipping though...
xP.1337
oh i didnt say i needed the brightest one! lol
id be happy with M Big Smile
Harborseal
Last seen: 1 week 6 days ago
This is a great list!  Any chance someone could add either CRI or color (neutral white, warm white, etc) or CCT?  Thanks!
Bob C.
