SOLVED! Something went wrong flashing FW3A (hope not bricked...)
11 posts / 0 new
dropman
Last seen: 1 week 1 day ago
Was trying to flash newest firmware, but something went wrong and now I get this:
Quote:
C:\avr\MHV AVR Tools>avrdude -p t85 -c usbasp -Uflash:w:fw3a.hex:a
avrdude: warning: cannot set sck period. please check for usbasp firmware update
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.05s
avrdude: Device signature = 0×1e930b
avrdude: NOTE: “flash” memory has been specified, an erase cycle will be perform
ed To disable this feature, specify the -D option.
avrdude: erasing chip
avrdude: reading input file “fw3a.hex”
avrdude: input file fw3a.hex auto detected as Intel Hex
avrdude: writing flash (7682 bytes):
Writing | ################################################## | 100% 8.66s
avrdude: 7682 bytes of flash written
avrdude: verifying flash memory against fw3a.hex:
avrdude: load data flash data from input file fw3a.hex:
avrdude: input file fw3a.hex contains 7682 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 5.57s
avrdude: verifying …
avrdude: verification error, first mismatch at byte 0×0000 0×00 != 0xef
avrdude: verification error; content mismatch
avrdude: safemode: lfuse changed! Was e2, and is now 80
Would you like this fuse to be changed back? [y/n] n
avrdude: safemode: hfuse changed! Was de, and is now 0
avrdude: safemode: efuse changed! Was ff, and is now fe
avrdude: safemode: Fuses OK (H:FF, E:DE, L:E2)
avrdude done. Thank you.
Not tried to solder driver back and test. What shoud I do? Sad
Edited by: dropman on 08/04/2019 - 02:08
SammysHP
SammysHP's picture
Last seen: 3 hours 16 min ago
First of all, check the wiring. If possible, send photos of your setup.
dropman
link to google drive photos
Hope that wiring is wrong, because instructions was not stright forward for me…
SammysHP
SammysHP's picture
The wiring looks to be OK. So next step is to remove the clip and attach it again. There might be bad contact. Then try to read the fuses:
avrdude -p t85 -c usbasp -U lfuse:r:-:h -U hfuse:r:-:h -U efuse:r:-:h
Repeat several times and check that you get consistent results.
dropman
I got 4 times:
Quote:
C:\avr\MHV AVR Tools>avrdude p t85 -c usbasp -U lfuse:r::h U hfuse:r::h -U e
fuse:r:-:h
Reading | ################################################## | 100% 0.04s
avrdude: reading lfuse memory:
Reading | ################################################## | 100% 0.01s
avrdude: writing output file “
0xe2
avrdude: reading hfuse memory:
0xde
avrdude: reading efuse memory:
0xff
SammysHP
SammysHP's picture
That’s strange. Reading the fuses explicitly says L:E2 H:DE E:FF, but the summary is L:E2 H:FF E:DE (high and extended exchanged)
Sounds like a bug in avrdude. I assume that the explicitly read values are correct and they match the default Anduril configuration. So just try to flash it again.
edit: lol, the avrdude bug tracker already has a big warning at the top:
Quote:
Please stop reporting bug #40085 over and over again.
Which is this bug: Typo fix in fuses report
And it was fixed already 2013…
dropman
I installed avr tools from MHV_AVR_Tools_20131101.exe
Do I need newer version?
Thanks
SammysHP
SammysHP's picture
It’s an old version, but it should work.
The latest version would be http://download.savannah.gnu.org/releases/avrdude/avrdude-6.3-mingw32.zip (I’m a Linux user and haven’t tested the Windows version.)
dropman
Still no luck.
I have avrdude 6.3 now and still get:
Quote:
c:\avr\MHV AVR Tools>avrdude -p t85 -c usbasp -Uflash:w:fw3a.hex:a
Reading | ################################################## | 100% 0.03s
avrdude: Device signature = 0×1e930b (probably t85)
Writing | ################################################## | 100% 8.75s
Reading | ################################################## | 100% 5.69s
avrdude: safemode: Fuses OK (E:FF, H:DE, L:E2)
SammysHP
SammysHP's picture
First try to flash with 3.3 V instead of 5 V by moving the jumper on the programmer one pin to the right (from pin 1+2 to pin 2+3). I had problems flashing with 5 V because the power consumption of the LEDs was too high. Not sure how other people handle this.
If it didn’t work: Don’t know if avrdude detects if the lock bit is set. Please show the output of this command:
avrdude -p t85 -c usbasp -U lock:r:-:b
dropman
Tried with 3.3V
Writing | ################################################## | 100% 8.94s
Reading | ################################################## | 100% 5.60s
avrdude: 7682 bytes of flash verified
Will try to solder driver back and test.
Edit: Everything works! Thanks for yout help, SammysHP!
