High Efficiency BLF Switching Driver? - Request for Desired Features
91 posts / 0 new
loneoceans
loneoceans's picture
Last seen: 15 hours 37 min ago
Hi BLF,
As many of you may know, I've built a variety of different drivers, all fairly complicated and over-driven, compared to regular, sensible drivers sealed.
I thought perhaps it may be time to build one that's a little more sensible and accessible to everyone, well designed, and have some extra features over stock drivers.
Currently the idea is to create a open-source, efficient BLF buck-boost or switching driver.
The candidate target is the FW3x or 17/20mm form factor, and the goal is to design the driver so that it uses open sourced firmware like Anduril or similar, and be designed to be easy to assemble by hobbyists. This way all firmware for the driver will be based on existing designs, though this means it may not be able to support other outlandish features from my other flashlights. However, considering that the FW3A is a FET+7+1 driver, it looks like freeing up 2 pins will allow additional improvements, such as better auxiliary front lighting control, better thermal control, or something else. I'll however leave the firmware to folks who know better such as TK and the rest of the community.
I'm sure everyone here has a much better idea of what features would make a good driver, so I'm asking if anyone would like to contribute to a 'dream-list'. Obviously not all requests will work together, but I hope to be able to collate a nice feature set, and then design a nice driver from the distilled results.
Here are some preliminary ideas to kick things off (will be updated as we go along)...
  • High Efficiency Synchronous Switching Topology
    • Boost mode operation (e.g. with FET, with my caveat that I'm not a fan of unregulated FET drive!)
  • Minimal of 1S operation
  • 3-5A constant current regulated output, no PWM
  • Ultra-low firefly mode
  • Open-source BLF firmware
  • PogoProg programmable from bottom of driver
  • Designed to be as easy to assemble at home as possible
Finally, I understand that there may be variants of this driver, for example, if designed specifically for FW3x, then it will likely have slightly different feature set than say a 17mm driver for Convoy flashlights.
Or perhaps a driver like this exists already and I don't know about it. sealed
Cheers everyone.
www.loneoceans.com/labs/
lume1 - Constant Current BuckBoost + FET Anduril Driver for FW3x
High Power Boost Drivers - GXB100 100W GAN FET Driver // GXB172 50W 17mm Driver
GXF22 - CC+FET for Emisar D4 // GFS16 - 1milliOhm FET Switch System // Older: GXB17 & GXB20
Edited by: loneoceans on 08/14/2019 - 13:18
mattlward
mattlward's picture
I would like to see a 4 amp top end for trips and quads.
EDC rotation:
FW1A, LH351D 4000k (second favorite)
FW3A, LH351D 3500k
FW3A, SST20 FD2 4000k
FW3A, Nichia 4000k sw40 r9080 (favorite light!)
FW3A, Cree XP-L Hi 5A3
Emisar D4V2, SST20 4000k
S2+, XM-L2 T6 4C
DavidEF
DavidEF's picture
Last seen: 6 hours 37 min ago
I’d love to see a good reliable buck-boost driver for 17mm (most common) and/or 20mm size. The real killer feature would be to port Narsil and/or Andúril to a more modern and powerful MCU, so we have a modern base to move BLF driver designs into the future. ATtiny85 chips have served us well, but we’re at the end of their capability and needing more, especially more channels, now that we’re into CCT mixing. I realize that multiple output channels like FET +N +1 aren’t needed for a good buck/boost driver, but if you’d do this for us, it would be the greatest “feature” you could offer in a driver. Along that line, a great actual feature for the driver would be multi-emitter output, such as color RGBW and CCT mixing of cool and warm whites.
- The YKK Philosophy
bmengineer
bmengineer's picture
Last seen: 1 week 6 days ago
My biggest feature to request is that this exist, and fit in a reasonably small light.
I don’t even need Anduril, if this can nail a good Olight/ThruNite/Acebeam type UI.
Find all my reviews of flashlights and more gear at www.bmengineer.com
Parametrek
Parametrek's picture
Last seen: 1 week 5 hours ago
Please keep it at 3 amps. Increasing the output by 33% makes the design 78% more difficult. And don’t be afraid to take it lower than 3 amps. Trying to fit inductors and mosfets that can handle the demands onto a 17mm disk is by far the most difficult part.
I am excited to see what you come up with.
Try the largest, fastest, most flexible flashlight search engine: parametrek.com
43 brands, 2375 models and still growing!
NEW: US battery database and European battery database
BlueSwordM
BlueSwordM's picture
Last seen: 1 week 1 day ago
Yeah, just keep it at 3A max.
iamlucky13
Last seen: 2 hours 45 min ago
Interested. I’ve got a big soft spot in my heart for both high efficiency and flat regulation.
3A is fine for me.
Is there room in the FW3A for a big enough inductor to achieve good efficiency?
Support for Anduril and Bistro (for clickies) would be superb if that can be made to work, but the basic UI priorities are for me are short click to turn on/off, good mode spacing, and low moonlight.
If a 17mm version with decent mode options like Bistro becomes available, I’ll replace the drivers in my Convoys.
Scallywag
Scallywag's picture
Last seen: 1 day 2 hours ago
I want zebralight efficiency!
Seriously though, if I could buck drive my Luxeon Vs with a single cell…
I think moderate power at 17mm is by far the most important. High power in larger sizes could be interesting.
Old Lumens Contest 2020 - Hand-made light category
ZL SC62(w) | Jaxman E2L XP-G2 5A | Purple S2+ XPL-HI U6-3A | D4 w/ Luxeon V | RRT-01 | Purple FW3A, 4000K SST20 | Baton S1
Boruit D10 w/ Quadrupel Fet+1/Anduril | EagTac D25C Ti | DQG Slim AA Ti | Jaxman E3 | UF-T1 by CRX | Olight S15 Ti | Nitecore EX11.2
L6 XHP70.2 P2 4000K FET+7135 | Jaxman M8 | MF02 | Jaxman Z1 CULNM1.TG | Blue S2+ w/ ML Special | Thrunite T10Tv2
Supfire M6 3xXHP50.2, Sofirn C8F, Unfinished: Sofirn SP70, IYP07/Tool AAA hot-rods, Jetbeam E3S
Others: Nitecore EC23 | Nebo Twyst | Streamlight ProTac 1AA | TerraLux LightStar 100
iamlucky13
I’m curious what the response is on this, but as far as I think I understand boost/buck drivers, each channel would need its own inductor, which would be a problem for size and perhaps also for price. Perhaps that could be worth pursuing for 2-channel tint mixing, but I’ve got a strong suspicion RGBW is a bridge too far.
Either way, surely that’s a future project. What’s being described already sounds like a great step forward for the flashlight community.
MascaratumB
MascaratumB's picture
Last seen: 6 hours 4 min ago
I don’t have inputs, I’m just subscribing to see this happen Innocent
[REVIEWS] ACEBEAM: H20 / TK16 // AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 // BLITZWOLF: BW-ET1 // BRINYTE: T28 / PT18pro / PT28 // DQG: AA Slim Ti // FIREFLIES: ROT66 GEN II // HC-LIGHTS: SS AAA // KLARUS: XT1C // LIVARNOLUX: 314791 // LUMINTOP: Tool AA V2.0 + Tool 25 // NITEFOX: UT20 / ES10K / K3 // ODEPRO: KL52 / B108 // OLIGHT: M2R Warrior // ON THE ROAD: M1 / i3 / M3 Pro / 311 / Z821 / i5 // ROVYVON: A2 + A5R / E300S / A8 / A23 / E200u // SKILHUNT: M150 / M200 // SOFIRN: SF14 + SP10A / SP32A / SP10B // WUBEN: TO10R / E05 / T70 / E10 / TO50R / E19 / E12R // XTAR: PB2 Charger // Mods: 1 / 2 // TIR: 1 / 2 // Others: Biscotti 3 + 1*7135 / Triple TIR w/ XP-G2 /// My Collection /// My Review's Blog (PT) /// OL Contest 2019 /// GIVEAWAY: 1 / 2
DavidEF
DavidEF's picture
Sorry, I maybe followed my own rabbit trail too far and forgot to come back. All I really meant to ask for is that he port Andúril or Narsil to a MCU that has enough channels that can be PWM’d for RGBW and CCT mixing and other multi-emitter options for future BLF drivers. It was a software “feature” request despite what I actually said above. Big Smile
WTF
Anduril can do tint mixing and Toykeeper has the 1634 working. It would be interesting to hear if Gchart has one series firmware working for both clicky and e-switch lights.
Tint mixing for a buck/boost driver doesn’t seem like it would be any fun. There’s already extra components taking up space and making heat and now you need to make it a multichannel design. Cramming two switch converters on the same small board would make a lot of electrical noise and heat problems, going to smaller inductors to make space would mean even more heat and less efficiency.
Maybe its not so hard for Lone Oceans, but I can’t see it being done on that size board.
DavidEF
DavidEF's picture
Yeah, I know Andúril can do CCT mixing. The LT1 project uses Andúril. I want a port so future drivers can take advantage of more than just 3 channels of hardware PWM for CCT mixing, RGBW, and other interesting things the BLF community might come up with. Consider the possibility of two or more output channels, each having at least one high and one low channel from the driver (think FET+1) or more (FET+N+1). I’d love to see this come about. We need firmware support for the hardware to be useful. A buck-boost driver using Andúril or Narsil can already be useful without all those extra channels. But if loneoceans uses a MCU that supports several hardware PWM channels for this buck-boost driver, and ports Andúril or Narsil to it, then others can take it from there. Loneoceans doesn’t even need to do the multi-channel part on this driver, because a buck-boost doesn’t need that.
Pwsmith
Last seen: 18 hours 19 min ago
Subscribed. I would love for this to work with a prog key.
id30209
id30209's picture
Last seen: 3 min 29 sec ago
3amos are fine but in 15mm and 17mm would be awesome
WTB Titanium 4sevens 2xAA tube
Pavlo
Last seen: 1 day 3 hours ago
Subscribed.
Thermal regulation
Cct mix control if possible.
WTF
How efficient can a buck/boost be these days? I thought the extra components chewed up enough energy to make it not worth doing.
It does seem to be the perfect driver for Clemence’s latest project. http://budgetlightforum.com/node/68213
I’m trying to find a good way to run one of those emitter boards off of a 2.5a usb port, hoping to put it in a cheap 10 watt floodlight housing. This might be the perfect driver for it.
How hard would it be to put the mcu on a smaller board or make it so a different mcu on an adapter board could be soldered in place of the original?
Set it up with the 85 as a base, and have the ability to use the 841 and whatever you wind up using for the sound activated driver and the microphone. Or maybe check with Toykeeper to see how she’s doing with the 841 and skip the 85 altogether.
The FW3A might be a bit of a challenge for you. I does not deal with heat that well and there won’t be much height for the inductor.
Barkuti
Barkuti's picture
Last seen: 49 min 39 sec ago
3 amps? C'mon!
3 amps is pretty run-of-the-mill. What's the point? I think current output should be stretched as much as reasonably possible before exotic or too expensive components need to come into play. Maybe I could know better but I think letting it handle some more current (like 6 amps or up to ≈20W stock) can make it fit a broader design and user base without making it too bulky. Corners can always be cut at a later date is what I mean. Innocent
Current output can always be adjusted by swapping the sense resistor anyway.
The Light Innocent I am
Deleting a post and redoing it causes the forum thread answer notifications to become invalid. Thus, if you need to change your just published post, edit it. Thanks.
Please avoid quoting lenghty posts, namely with nested quotes. Trim the quote down to the essential. Helps with forum neatness and legibility. Thanks.
Localized AliExpress links mess up with the language setting of whoever clicks or taps on them. While this is a fault of the AliExpress system, turning localized links into global links helps and is easy; just change the locale letters in the url for www. Example:
https://es.aliexpress.com/item/bla-bla-bla.html turns into https://www.aliexpress.com/item/bla-bla-bla.html. Thumbs Up
WTF
I think Toykeeper can already do most of that with the 1634, someone just needs to make the driver. Lexel’s new buck converter design is probably perfect for it. Four channels of buck/boost won’t add that much runtime. The user interface might get a bit crazy, its a lot to do with one switch. Maybe an accelerometer seeing a sequence of moves could put it in the correct setup mode. Add in a crystal for more accurate click timings if need be.
If someone were to use that driver in a Q8 with a four channel round version of Clemence’s 36 × 3030 mcpcb it might be the ultimate flooder.
Mike C did 1634 driver years ago where every 7135 was on its own channel. Output was controlled by turning on one 7135 at time. Once Toykeeper isn’t stuck fighting for space with the 85 development pace will start to pick up. And its about time we moved on from the 7135. L.O.‘s constant current driver should help move that along.
Marc E
Last seen: 8 hours 2 min ago
Narsil/Anduril on an efficient buck/boost driver with good firefly mode, can’t think of anything i’d want to add to that.
Barkuti wrote:
3 amps is pretty run-of-the-mill. What’s the point?
You mean aside from being a replacement for the 7135 based drivers you tell people to replace?
Well, from the first post:
loneoceans wrote:
As many of you may know, I’ve built a variety of different drivers, all fairly complicated and over-driven, compared to regular, sensible drivers.
I thought perhaps it may be time to build one that’s a little more sensible and accessible to everyone, well designed, and have some extra features over stock drivers…
Agro
Agro's picture
Last seen: 2 min 41 sec ago
What would be the difference between buck-boost and a dedicated buck or dedicated boost when it comes to:
  • price
  • efficiency
  • board space
What use cases could it serve that are not achievable with buck or boost?
Could drive largely-outdated high Vf LEDs a little higher (XP-L, XM-L2, XP-G2).
Would better support multi-chemistry lights
Am I missing something?
Barkuti
Barkuti's picture
I didn't tell anyone to replace his/her 7135 board with this. They're always free to choose by themselves. Innocent
Why would someone want to replace a perfectly working 7135 driver with this? I mean, to replace a 7135 board there is already a step in between which is a MOSFET regulated linear driver (Convoy is offering many new boards of this class, for example).
Are we untapping a firmware addiction problem for many?
Windforce
Last seen: 7 months 2 days ago
If going sychronous buck-boost with four MOSFET bridge topology, you can try to implement bidirectional converter operation with integrated battery charger and powerbank function. Everything in one PWM control chip and one inductor.
Agro
Agro's picture
That would be awesome.
Windforce
The obvious drawback is the necessity of current path switching FET at the LED side of the converter. Converter direction switching can be solved automatically by plug insertion detection. Separate USB-C controller at the plug input can realise handshake with external devices and decide to act as a sink or a source…
KevinZA1988
KevinZA1988's picture
Last seen: 1 week 2 hours ago
Interesting… So max 900 – 1200 lumens depending on emitters used in the FW3A?
What can the possible efficiency increase of this driver be over the stock AMC only ramp configuration of the FW3A?
Armytek Prime C1 Pro, Armytek Prime C2 Pro, Armytek Tiara C1 Pro, Astrolux MF01 Mini, BLF Q8, BLF A6, BLF FW1A, BLF FW3A, BLF FW3C, BLF LT1, Convoy L6, Convoy C8+ , Convoy S3, Convoy M21A, Convoy S11, Emisar D4, Fireflies E07, Jaxman E2L, Lumintop EDC18, Manta Ray C8.2 long version, Olight S1R Baton II special edition series, S2R Baton II, Nitecore HC65, Olight H1R Nova.
https://photos.app.goo.gl/JaJaDv4V838AEJf39
bmengineer
Ohh boy, if both this and the FW1A come to realization, that would be an absolute dream light.
Barkuti
Barkuti's picture
Seriously? How about also adding dildo functionality a vibration motor, that's gonna be cool too. Smile
What are the implications of adding that much different functionality? Is this probably going off on a tangent? Not all flashlight hosts are designed with battery charging in mind, let alone power bank function. An USB connector takes up additional space. Concerning the power bank in a flashlight stuff, it is quite a superfluous thing imho. Any standard power bank does it a lot better.
CalvinIS
CalvinIS's picture
Last seen: 8 months 3 weeks ago
 Subbed
USA based seller of flashlights, batteries, and chargers.
Illumn Webstore
 /// Instagram /// BLF DEAL THREAD
Barkuti
Barkuti's picture
Windforce wrote:
If going sychronous buck-boost with four MOSFET bridge topology, …
That is single inductor and four switches.
SEPIC uses a single switch and dual inductors (which can be coupled for 2x effective inductance):
https://www.taiwantrade.com/product/high-and-low-current-coupled-inductors-420010.html
e1000
Last seen: 3 hours 7 min ago
Barkuti wrote:
Seriously? How about also adding dildo functionality a vibration motor, that’s gonna be cool too. Smile
this will for sure drive popularity of 21700’s, with 26650’s becoming true enthusiast cells. LOL
